I have sequenced Adobe reader 10.1 and it's working fine....there where some issue with the some file but they have been solved after disabling the protected mode option....now the problem is that when i try to open a password protected file using virtualized Adobe 10.1 it says:-
"THERE IS A PROBLEM OPENING THIS DOCUMENT,THERE IS A PROBLEM READING THIS DOCUMENT(57)"
and the document works fine in locally installed Adobe 10.1....is there any setting that needs to be done for password protected files....plz help...
hi all,
Thanks & regards,
Pranay.
