on my second attempt at capturing a reference machine, vista x86 oem, i find the "Prepare OS for Capture" task is taking wayyyy tooo long to complete and restert into WinPE.
i's been running now 20-30 minutes showing a dialog as :
Running Action : Prepare windows for Capture
Running sysprep command
and every few seconds <10, the dialog seems to shrink and grow, like theres some sub-task that needs interaction.
on yesterdays first attempt at some point i got it to show me a new screen with an interaction and then said once i'm done to click a button to go back to the desktop. cant remeber how i got on to it.
it eventually rebooted and started winpe and the iniital dialogs and ended with (080070056).
Hi ,
today im not even getting that far.
any ideas,?
build001-capture-smsts.log
