I have hundreds of Optiplex 755's, I have built my reference image using a vmware workstation. It is windows 7 enterprise x64. Before I seal the image I uninstall vmware tools.
When I deploy the image sysprep always crashes on the specialize pass
2011-08-08 16:44:14, Info SYSPRP ========================================================
2011-08-08 16:44:14, Info SYSPRP === Beginning of a new sysprep run ===
2011-08-08 16:44:14, Info [0x0f004d] SYSPRP The time is now 2011-08-08 16:44:14
2011-08-08 16:44:14, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\System32\Sysprep\Panther
2011-08-08 16:44:14, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine
2011-08-08 16:44:14, Info [0x0f007e] SYSPRP FCreateTagFile:Tag file C:\Windows\System32\Sysprep\Sysprep_succeeded.tag does not already exist, no need to delete anything
2011-08-08 16:44:14, Warning SYSPRP WinMain: File operations pending
2011-08-08 16:44:16, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'GENERALIZE'
2011-08-08 16:44:16, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'OOBE'
2011-08-08 16:44:16, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'QUIT'
2011-08-08 16:44:16, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'UNATTEND'
2011-08-08 16:44:16, Info [0x0f004a] SYSPRP WaitThread:Entering spawned waiting thread
2011-08-08 16:44:16, Info [sysprep.exe] UnattendFindAnswerFile: Looking at explicitly provided unattend file [C:\Windows\System32\Sysprep\sysprep64.xml]...
2011-08-08 16:44:16, Info [sysprep.exe] UnattendFindAnswerFile: [C:\Windows\System32\Sysprep\sysprep64.xml] meets criteria for an explicitly provided unattend file.
2011-08-08 16:44:16, Info SYSPRP SysprepSearchForUnattend: Using unattend file at [C:\Windows\System32\Sysprep\sysprep64.xml].
2011-08-08 16:44:16, Info SYSPRP SysprepSearchForUnattend: [generalize] pass in unattend file [C:\Windows\System32\Sysprep\sysprep64.xml] either doesn't exist or passed validation
2011-08-08 16:44:16, Info SYSPRP WinMain:Found unattend file at [C:\Windows\System32\Sysprep\sysprep64.xml]; caching...
2011-08-08 16:44:16, Info SYSPRP WinMain:Processing unattend file's 'generalize' pass...
2011-08-08 16:44:16, Info SYSPRP Sysprep is running a generalize pass with the following unattend file: [%windir%\panther\unattend.xml]
2011-08-08 16:44:16, Info SYSPRP RunUnattendGeneralizePass: Sysprep unattend generalize pass exits; hr = 0x0, hrResult = 0x0, bRebootRequired = 0x0
2011-08-08 16:44:16, Info [0x0f00ac] SYSPRP WinMain:Processing 'cleanup' external provider request.
2011-08-08 16:44:16, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3
2011-08-08 16:44:16, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup
2011-08-08 16:44:16, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Cleanup
2011-08-08 16:44:16, Info [0x0f00ad] SYSPRP WinMain:Processing 'generalize' extrenal provider request.
2011-08-08 16:44:16, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 1
2011-08-08 16:44:16, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Generalize
2011-08-08 16:44:16, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Generalize
2011-08-08 16:44:16, Info [0x0f003f] SYSPRP WinMain:Processing 'cleanup' internal provider request.
2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67196725-a666-73a6-a048-412e48a3b856}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'
2011-08-08 16:44:16, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'; executing it
2011-08-08 16:44:16, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' without error
2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1e7f4452-a4b4-5a32-d01e-70397b096ced}; will try to launch 'sqmapi.dll,SqmSysprepCleanup'
2011-08-08 16:44:16, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepCleanup'; executing it
2011-08-08 16:44:16, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepCleanup' without error
2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{2c8a362b-4dc1-38b9-c4d8-ce732ddcc48e}; will try to launch 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'
2011-08-08 16:44:16, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'; executing it
2011-08-08 16:44:16, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' without error
2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{86297dc3-52b0-7d4e-f9a8-572bb66ac5ae}; will try to launch 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'
2011-08-08 16:44:16, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'; executing it
2011-08-08 16:44:16, Info SYSPRP Sysprep_Generalize_MUILangCleanup Start.
2011-08-08 16:44:16, Info SYSPRP Disabling CMF cache SUCCEEDED
2011-08-08 16:44:16, Info SYSPRP Removing scheduled task for running lpremove.exe and all related data
2011-08-08 16:44:16, Info SYSPRP Removing scheduled task for lpremove.exe succeeed
2011-08-08 16:44:16, Info SYSPRP Removing MUIUnattend-OOBE handshake value
2011-08-08 16:44:16, Info SYSPRP MUIUnattend-OOBE handshake value is not present on the system
2011-08-08 16:44:16, Info SYSPRP Sysprep_Generalize_MUILangCleanup End.
2011-08-08 16:44:16, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' without error
2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{03513543-c453-2e4f-3200-c2f12d89732a}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'
2011-08-08 16:44:17, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'; executing it
2011-08-08 16:44:17, Info [shsetup] Sysprep_Cleanup_Shell entered
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipMachineOOBE' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipUserOOBE' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'HideEULAPage' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'NetworkLocation' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'ProtectYourPC' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'MediaBootInstall' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedProductKey' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedEula' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedLanguageSelection' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupSQMOptIn' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendCreatedUser' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetTimeZone' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetAutologon' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'AutoAdminLogon' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultUserName' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultDomainName' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'SOFTWARE\Policies\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\FirstNetwork' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'HideWizard' returned 0
2011-08-08 16:44:17, Info [shsetup] Deleting temp files for 'S-1-5-18'
2011-08-08 16:44:17, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent' (0x80070002)
2011-08-08 16:44:17, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Local\Temp' (0x80070002)
2011-08-08 16:44:17, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff
2011-08-08 16:44:17, Info [shsetup] Cleaning up user hive for 'S-1-5-19'
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2
2011-08-08 16:44:17, Info [shsetup] Deleting temp files for 'S-1-5-19'
2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Local\Temp'
2011-08-08 16:44:17, Info [shsetup] Cleaning up user hive for 'S-1-5-20'
2011-08-08 16:44:17, Info [shsetup] Deleting temp files for 'S-1-5-20'
2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp'
2011-08-08 16:44:17, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000
2011-08-08 16:44:17, Info [shsetup] Cleaning up user hive for 'S-1-5-21-2813110343-969295344-4049937527-500'
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 0
2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 0
2011-08-08 16:44:17, Info [shsetup] Deleting temp files for 'S-1-5-21-2813110343-969295344-4049937527-500'
2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Local\Temp'
2011-08-08 16:44:17, Info [shsetup] SanitizeDeskBands entered
2011-08-08 16:44:17, Info [shsetup] SanitizeDeskBands exit
2011-08-08 16:44:17, Info [shsetup] PrimeStartMenuShortcuts entered
2011-08-08 16:44:22, Info [shsetup] PrimeStartMenuShortcuts exit
2011-08-08 16:44:22, Info [shsetup] Sysprep_Cleanup_Shell exit
2011-08-08 16:44:22, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' without error
2011-08-08 16:44:22, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1f954290-a3bd-7c6b-ac99-fda4b6fe1603}; will try to launch 'wer.dll,WerSysprepCleanup'
2011-08-08 16:44:22, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepCleanup'; executing it
2011-08-08 16:44:22, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepCleanup' without error
2011-08-08 16:44:22, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67011352-10f6-73b5-0c1b-833a374ea884}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'
2011-08-08 16:44:22, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'; executing it
2011-08-08 16:44:22, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain
2011-08-08 16:44:22, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do
2011-08-08 16:44:22, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' without error
2011-08-08 16:44:22, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{d9d03ab7-c7a6-4587-1dcd-fb0609f92d84}; will try to launch 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'
2011-08-08 16:44:22, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'; executing it
2011-08-08 16:44:22, Info capisp.dll::DisableAdministratorIfApplicable disabled the admin account.
2011-08-08 16:44:23, Info capisp.dll::CryptoSysPrep_Clean: returning 0
2011-08-08 16:44:23, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' without error
2011-08-08 16:44:23, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{79b40229-f48c-7547-16d3-ec814bdc5adc}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'
2011-08-08 16:44:23, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'; executing it
2011-08-08 16:44:23, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' without error
2011-08-08 16:44:23, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{352676dd-145f-cf4f-feb3-aa882aa02408}; will try to launch 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'
2011-08-08 16:44:23, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'; executing it
2011-08-08 16:44:23, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _DisableService returned successfully.
2011-08-08 16:44:23, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _CreateBlockingRegKey returned successfully.
2011-08-08 16:44:23, Info SYSPRP MSS: _StopService status checking loop 0 round, QueryServiceStatus return TRUE, the status is 0x3
2011-08-08 16:44:24, Info SYSPRP MSS: _StopService status checking loop 1 round, QueryServiceStatus return TRUE, the status is 0x3
2011-08-08 16:44:25, Info SYSPRP MSS: _StopService status checking loop 2 round, QueryServiceStatus return TRUE, the status is 0x3
2011-08-08 16:44:26, Info SYSPRP MSS: _StopService status checking loop 3 round, QueryServiceStatus return TRUE, the status is 0x1
2011-08-08 16:44:26, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' without error
2011-08-08 16:44:26, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{f9e8597e-e3f1-9942-5fbc-2ce1ce25c0e2}; will try to launch 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'
2011-08-08 16:44:26, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'; executing it
2011-08-08 16:44:27, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' without error
2011-08-08 16:44:27, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{4aaf8557-52af-9241-b6bc-e36d2d203cef}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'
2011-08-08 16:44:27, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'; executing it
2011-08-08 16:44:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' without error
2011-08-08 16:44:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{ccf004d0-c18e-a2d4-b4ea-08ccb5259f11}; will try to launch 'srcore.dll,SysprepCleanup'
2011-08-08 16:44:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepCleanup'; executing it
2011-08-08 16:44:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepCleanup' without error
2011-08-08 16:44:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{de7df4f0-0ce9-ca23-6049-1807de6941d3}; will try to launch 'drmv2clt.dll,Sysprep'
2011-08-08 16:44:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'drmv2clt.dll,Sysprep'; executing it
2011-08-08 16:44:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'drmv2clt.dll,Sysprep' without error
2011-08-08 16:44:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{9733bd0b-72a8-af29-76ba-be8ae2c8be6f}; will try to launch 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'
2011-08-08 16:44:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'; executing it
2011-08-08 16:44:29, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:MOOBE==MOOBE_RUNNING_STATE_ALREADY_RAN
2011-08-08 16:44:29, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:found winsatapi\LastFormalAssessment key
2011-08-08 16:44:29, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:deleted winsat\MOOBE key
2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' without error
2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{b4db0c88-1c6a-c5e8-f385-df67f3f1f575}; will try to launch 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'
2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'; executing it
2011-08-08 16:44:30, Warning TapiSysPrep.dll:RetainTapiLocations:RegQueryValueEx() returned 2
2011-08-08 16:44:30, Info TapiSysPrep.dll:RetainTapiLocations:returning 1
2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' without error
2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{e0053bef-049c-9ba1-e7db-793f9e538edd}; will try to launch 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'
2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'; executing it
2011-08-08 16:44:30, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user registry data found to delete
2011-08-08 16:44:30, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user profile files to delete
2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' without error
2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\2D153B43-11B4-461f-AA43-832B2C8B8872; will try to launch 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'
2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'; executing it
2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' without error
2011-08-08 16:44:30, Info [0x0f0040] SYSPRP WinMain:Processing 'generalize' internal provider request.
2011-08-08 16:44:30, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 1
2011-08-08 16:44:30, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Generalize
2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{67196725-a666-73a6-07bd-00f3276e41cf}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk'
2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk'; executing it
2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk' without error
2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{899480af-8f8b-16c1-58aa-df121c7314ed}; will try to launch 'C:\Windows\System32\reagent.dll,WinRE_Generalize'
2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\reagent.dll,WinRE_Generalize'; executing it
2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\reagent.dll,WinRE_Generalize' without error
2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8bc7dae9-655e-8ca5-d3d1-771286930ef6}; will try to launch 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging'
2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging'; executing it
2011-08-08 16:44:33, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging' without error
2011-08-08 16:44:33, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{1e7f4452-a4b4-5a32-5cc0-12a85b132913}; will try to launch 'sqmapi.dll,SqmSysprepGeneralize'
2011-08-08 16:44:33, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepGeneralize'; executing it
2011-08-08 16:44:33, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepGeneralize' without error
2011-08-08 16:44:33, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{d0c365cf-6d23-9db2-b74d-4e1efd035af7}; will try to launch 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp'
2011-08-08 16:44:33, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp'; executing it
2011-08-08 16:44:33, Info SYSPRP SPPNP: Sysprep_Generalize_Pnp: Enter
2011-08-08 16:44:33, Info SYSPRP SPPNP: Retrieving the list of function drivers from the critical device database (CDDB).
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver i8042prt was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Serial was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver pcmcia was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver isapnp was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver nvraid was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Parport was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver fdc was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver flpydisk was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver msisadrv was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver pci was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ACPI was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver WmiAcpi was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Wd was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ErrDev was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver sermouse was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver sbp2port was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver CmBatt was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver AcpiPmi was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver AmdPPM was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver AmdK8 was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver intelppm was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver IPMIDRV was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Processor was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vmbus was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver WacomPen was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver hcw85cir was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver BTHMODEM was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HidBth was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HidIr was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Compbatt was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver UmPass was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver cdrom was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver disk was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HidUsb was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbprint was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver sfloppy was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver kbdhid was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver mouhid was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver MTConfig was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HidBatt was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver atapi was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver BrSerWdm was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver BrUsbMdm was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver pciide was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver msahci was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HDAudBus was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ohci1394 was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbuhci was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbohci was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbehci was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HpSAMD was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver LSI_SCSI was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver LSI_SAS was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver MegaSR was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver megasas was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver LSI_SAS2 was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver LSI_FC was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver amdsbs was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver amdsata was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver 1394ohci was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver nfrd960 was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver amdide was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver SiSRaid2 was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver SiSRaid4 was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver stexstor was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ql2300 was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ql40xx was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver cmdide was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver aliide was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver nvstor was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver elxstor was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver viaide was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vsmraid was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver iirsp was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver s3cap was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver b06bdrv was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ebdrv was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vmci was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver intelide was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver iaStorV was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver adpahci was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver arc was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver arcsas was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver adp94xx was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver adpu320 was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver blbdrive was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver circlass was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver CompositeBus was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver iScsiPrt was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver mpio was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver msdsm was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver mssmbios was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver rdpbus was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver TermDD was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver swenum was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver umbus was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vdrvroot was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver volmgr was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver sffdisk was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver volsnap was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver USBSTOR was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbhub was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbccgp was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbcir was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Brserid was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver storvsc was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver VMBusHID was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vhdmp was retrieved from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Finished retrieving the list of function drivers from the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Enabling the function drivers listed in the critical device database (CDDB) ...
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service vhdmp was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service VMBusHID was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service storvsc was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver storvsc has been enabled.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service Brserid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbcir was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbccgp was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbhub was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service USBSTOR was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service volsnap is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service sffdisk was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service volmgr is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service vdrvroot is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service umbus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service swenum was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service TermDD is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service rdpbus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service mssmbios is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service msdsm was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver msdsm has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service mpio was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver mpio has been enabled.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service iScsiPrt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service CompositeBus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service circlass was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service blbdrive is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service adpu320 was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver adpu320 has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service adp94xx was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver adp94xx has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service arcsas was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver arcsas has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service arc was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver arc has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service adpahci was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver adpahci has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service iaStorV was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver iaStorV has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service intelide is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service vmci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service ebdrv was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service b06bdrv was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service s3cap was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service iirsp was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver iirsp has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service vsmraid was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver vsmraid has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service viaide was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver viaide has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service elxstor was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver elxstor has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service nvstor was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver nvstor has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service aliide was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver aliide has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service cmdide was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver cmdide has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service ql40xx was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver ql40xx has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service ql2300 was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver ql2300 has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service stexstor was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver stexstor has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service SiSRaid4 was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver SiSRaid4 has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service SiSRaid2 was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver SiSRaid2 has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service amdide was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver amdide has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service nfrd960 was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver nfrd960 has been enabled.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service 1394ohci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service amdsata was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver amdsata has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service amdsbs was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver amdsbs has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service LSI_FC was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver LSI_FC has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service LSI_SAS2 was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver LSI_SAS2 has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service megasas was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver megasas has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service MegaSR was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver MegaSR has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service LSI_SAS is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service LSI_SCSI was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver LSI_SCSI has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service HpSAMD was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver HpSAMD has been enabled.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbehci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbohci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbuhci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service ohci1394 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HDAudBus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service msahci was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver msahci has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service pciide was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver pciide has been enabled.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service BrUsbMdm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service BrSerWdm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service atapi is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HidBatt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service MTConfig was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service mouhid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service kbdhid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service sfloppy was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbprint was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HidUsb was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service disk is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service cdrom is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service UmPass was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service Compbatt is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HidIr was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HidBth was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service BTHMODEM was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service hcw85cir was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service WacomPen was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service vmbus is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service Processor was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service IPMIDRV was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service intelppm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service AmdK8 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service AmdPPM was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service AcpiPmi was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service CmBatt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service sbp2port was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver sbp2port has been enabled.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service sermouse was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service ErrDev was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service Wd was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver Wd has been enabled.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service WmiAcpi was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service ACPI is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service pci is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service msisadrv is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service flpydisk was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service fdc was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service Parport was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service nvraid was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver nvraid has been enabled.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service isapnp was 0.
2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver isapnp has been enabled.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service pcmcia was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Service Serial is currently not disabled. Hence there is no need to re-enable it.
2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service i8042prt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Finished enabling the function drivers listed in the CDDB.
2011-08-08 16:44:33, Info SYSPRP SPPNP: Uninstalling all existing devices <full generalize>.
2011-08-08 16:44:34, Info SYSPRP SPPNP: Uninstalling device SW\{EEAB7790-C514-11D1-B42B-00805FC1270E}\ASYNCMAC failed with 0x5.
2011-08-08 16:44:34, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_AGILEVPNMINIPORT\0000.
2011-08-08 16:44:35, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\*ISATAP\0000.
2011-08-08 16:44:35, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_L2TPMINIPORT\0000.
2011-08-08 16:44:35, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\*TEREDO\0000.
2011-08-08 16:44:35, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANBH\0000.
2011-08-08 16:44:35, Info SYSPRP SPPNP: Uninstalling device ROOT\ACPI_HAL\0000 failed with 0xE0000231.
2011-08-08 16:44:36, Info SYSPRP SPPNP: Uninstalling device ROOT\BLBDRIVE\0000 failed with 0xE0000231.
2011-08-08 16:44:36, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANIP\0000.
2011-08-08 16:44:36, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\COMPOSITEBUS\0000.
2011-08-08 16:44:36, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANIPV6\0000.
2011-08-08 16:44:36, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\COMPOSITE_BATTERY\0000.
2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_PPPOEMINIPORT\0000.
2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_PPTPMINIPORT\0000.
2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_SSTPMINIPORT\0000.
2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDPBUS\0000.
2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDP_KBD\0000.
2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDP_MOU\0000.
2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\SYSTEM\0000.
2011-08-08 16:44:38, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\UMBUS\0000.
2011-08-08 16:44:38, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\VMWARE\0000.
2011-08-08 16:44:38, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\VMWARE\0001.
2011-08-08 16:44:38, Info SYSPRP SPPNP: Uninstalling device ROOT\VOLMGR\0000 failed with 0xE0000231.
2011-08-08 16:46:05, Info SYSPRP SPPNP: Reflected all boot critical driver packages (87094 ms).
2011-08-08 16:46:05, Error SYSPRP SPPNP: Error 0x2 setting SDDL on driver file C:\Windows\system32\drivers\vmaudio.sys!
2011-08-08 16:46:05, Error SYSPRP SPPNP: Error 0x2 setting SDDL on driver file C:\Windows\system32\DRIVERS\vmci.sys!
2011-08-08 16:46:06, Info SYSPRP SPPNP: Sysprep_Generalize_Pnp: Exit
2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp' without error
2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{960b724d-0479-6dd8-0470-6c42dc9b8f85}; will try to launch 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize'
2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize'; executing it
2011-08-08 16:46:06, Info SYSPRP iphlpsvc.dll: sysprep generalize called
2011-08-08 16:46:06, Info SYSPRP Found interface in scavenger.
2011-08-08 16:46:06, Info SYSPRP Successfully uninstalled interface in scavenger
2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize' without error
2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{243bb634-be68-0139-f4c8-f1c87dade9d7}; will try to launch 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup'
2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup'; executing it
2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup' without error
2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{df593d24-f963-8be2-86d6-c722da22bf5b}; will try to launch 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize'
2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize'; executing it
2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize' without error
2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{03513543-c453-2e4f-5ee6-b970cace3cd8}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell'
2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell'; executing it
2011-08-08 16:46:06, Info [shsetup] Sysprep_Generalize_Shell entered
2011-08-08 16:46:06, Info [shsetup] Sysprep_Generalize_Shell exit
2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell' without error
2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{1f954290-a3bd-7c6b-2062-3fd9d1266740}; will try to launch 'wer.dll,WerSysprepGeneralize'
2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepGeneralize'; executing it
2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepGeneralize' without error
2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{4840d621-1b47-334f-b1a6-321233838362}; will try to launch 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize'
2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize'; executing it
2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize' without error
2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{67011352-10f6-73b5-85e9-6064e10071b9}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net'
2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net'; executing it
2011-08-08 16:46:06, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain
2011-08-08 16:46:06, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do
2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net' without error
2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{3aa3f98d-491f-7656-533f-7db889fff253}; will try to launch 'C:\Windows\System32\slc.dll,SLReArmWindows'
2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\slc.dll,SLReArmWindows'; executing it
2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\slc.dll,SLReArmWindows' without error
2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{d9d03ab7-c7a6-4587-c28d-ccc47a787790}; will try to launch 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize'
2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize'; executing it
2011-08-08 16:46:08, Info capisp.dll::CAPISysPrep_Generalize: returning 0
2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize' without error
2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{6a6b0fac-5606-6e68-410d-e7bf974f5136}; will try to launch 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd'
2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd'; executing it
2011-08-08 16:46:08, Info TOOL Sysprep_Generalize_Bcd: Located BCD store on system drive. Generalizing it...
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Found the memory tester object.
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Found the Windows OS Loader object {d54562fb-41e1-11e0-9007-94b295923b48} for the currently running OS.
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Found the resume object {d54562fa-41e1-11e0-9007-94b295923b48} for the OS loader.
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: System drive backed by VHD = 0
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Generalizing object {9dea862c-5cdd-4e70-acc1-f32b344d4795}
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0]
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Generalizing object {b2721d73-1db4-4c62-bf78-c548a880142d}
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Generalizing object {d54562fb-41e1-11e0-9007-94b295923b48}
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized OS device. Status = [0x0]
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Generalizing object {d54562fa-41e1-11e0-9007-94b295923b48}
2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized hiberfile device. Status = [0x0]
2011-08-08 16:46:08, Info TOOL Sysprep_Generalize_Bcd: Successfully generalized the bcd store. Status=[0x0]
2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd' without error
2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8fd6ce7c-4301-d490-719b-d787d2bde1cd}; will try to launch 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize'
2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize'; executing it
2011-08-08 16:46:08, Info SYSPRP nlmsprep.dll: Generalize start
2011-08-08 16:46:08, Info SYSPRP nlmsprep.dll: Generalize finish
2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize' without error
2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{79b40229-f48c-7547-1eb2-96b7091aa28f}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize'
2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize'; executing it
2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize' without error
2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8dde3abb-19cb-88f8-4e07-05c697cc2872}; will try to launch 'RacEngn.dll,RacSysprepGeneralize'
2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'RacEngn.dll,RacSysprepGeneralize'; executing it
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'RacEngn.dll,RacSysprepGeneralize' without error
2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{20b6ca3b-166d-4e8d-af73-72df2987e480}; will try to launch 'msmmsp.dll,MountMgr_Generalize'
2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'msmmsp.dll,MountMgr_Generalize'; executing it
2011-08-08 16:46:09, Info msmmsp::MountMgr_Generalize ENTER
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'msmmsp.dll,MountMgr_Generalize' without error
2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{4aaf8557-52af-9241-469e-acbb347c3c07}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE'
2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE'; executing it
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE' without error
2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{71e01f6c-a271-b3b1-05f0-8c48a330cb4c}; will try to launch 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize'
2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize'; executing it
2011-08-08 16:46:09, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastFullScanID does not exist, skipping action.
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize' without error
2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{ccf004d0-c18e-a2d4-ee22-e585dac90889}; will try to launch 'srcore.dll,SysprepGeneralize'
2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepGeneralize'; executing it
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepGeneralize' without error
2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{68cac03c-b4c6-675e-1b30-cf21359228e2}; will try to launch 'spwmp.dll,Sysprep_Generalize_WMP'
2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'spwmp.dll,Sysprep_Generalize_WMP'; executing it
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'spwmp.dll,Sysprep_Generalize_WMP' without error
2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{b636fa27-124f-6436-6a6f-2fe2739a2b89}; will try to launch 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize'
2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize'; executing it
2011-08-08 16:46:09, Info SYSPRP WindowsSideShow: Enabling SystemDataProviders task returned 0x00000000
2011-08-08 16:46:09, Info SYSPRP WindowsSideShow: Enabling SessionAgent task returned 0x00000000
2011-08-08 16:46:09, Info SYSPRP WindowsSideShow: Enabling GadgetManager task returned 0x00000000
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize' without error
2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8a2650e9-70de-392f-5b09-34c3ac14764d}; will try to launch 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE'
2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE'; executing it
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE' without error
2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{cb71e18d-7833-6f0f-2d00-e35ade2ecb27}; will try to launch 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize'
2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize'; executing it
2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize' without error
2011-08-08 16:46:09, Info [0x0f004c] SYSPRP WaitThread:Exiting spawned waiting thread
2011-08-08 16:46:09, Info [0x0f007a] SYSPRP FCreateTagFile:Successfully created tag file C:\Windows\System32\Sysprep\Sysprep_succeeded.tag
2011-08-08 16:46:09, Info [0x0f0052] SYSPRP Shutting down SysPrep log
2011-08-08 16:46:09, Info [0x0f004d] SYSPRP The time is now 2011-08-08 16:46:09
2011-08-19 17:18:08, Info SYSPRP ========================================================
2011-08-19 17:18:08, Info SYSPRP === Beginning of a new sysprep run ===
2011-08-19 17:18:08, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:18:08
2011-08-19 17:18:08, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\System32\sysprep\Panther
2011-08-19 17:18:08, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine
2011-08-19 17:18:08, Info [0x0f007e] SYSPRP FCreateTagFile:Tag file C:\Windows\System32\sysprep\Sysprep_succeeded.tag does not already exist, no need to delete anything
2011-08-19 17:18:10, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'AUDIT'
2011-08-19 17:18:10, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'REBOOT'
2011-08-19 17:18:10, Info [0x0f004a] SYSPRP WaitThread:Entering spawned waiting thread
2011-08-19 17:18:10, Info [sysprep.exe] UnattendSearchExplicitPath: Found unattend file at [C:\Windows\Panther\unattend.xml]; examining for applicability.
2011-08-19 17:18:10, Info [sysprep.exe] UnattendSearchExplicitPath: [C:\Windows\Panther\unattend.xml] does not meet criteria to be used for this unattend pass.
2011-08-19 17:18:11, Info SYSPRP SysprepSearchForUnattend: No unattend file was specified or located; skipping unattend generalize pass.
2011-08-19 17:18:11, Info [0x0f00ac] SYSPRP WinMain:Processing 'cleanup' external provider request.
2011-08-19 17:18:11, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3
2011-08-19 17:18:11, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup
2011-08-19 17:18:11, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Cleanup
2011-08-19 17:18:11, Info [0x0f003f] SYSPRP WinMain:Processing 'cleanup' internal provider request.
2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67196725-a666-73a6-a048-412e48a3b856}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'
2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'; executing it
2011-08-19 17:18:11, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' without error
2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1e7f4452-a4b4-5a32-d01e-70397b096ced}; will try to launch 'sqmapi.dll,SqmSysprepCleanup'
2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepCleanup'; executing it
2011-08-19 17:18:11, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepCleanup' without error
2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{2c8a362b-4dc1-38b9-c4d8-ce732ddcc48e}; will try to launch 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'
2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'; executing it
2011-08-19 17:18:11, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' without error
2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{86297dc3-52b0-7d4e-f9a8-572bb66ac5ae}; will try to launch 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'
2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'; executing it
2011-08-19 17:18:11, Info SYSPRP Sysprep_Generalize_MUILangCleanup Start.
2011-08-19 17:18:11, Info SYSPRP Disabling CMF cache SUCCEEDED
2011-08-19 17:18:11, Info SYSPRP Removing scheduled task for running lpremove.exe and all related data
2011-08-19 17:18:11, Info SYSPRP Removing scheduled task for lpremove.exe succeeed
2011-08-19 17:18:11, Info SYSPRP Removing MUIUnattend-OOBE handshake value
2011-08-19 17:18:11, Info SYSPRP MUIUnattend-OOBE handshake value is present on the system
2011-08-19 17:18:11, Info SYSPRP Succeeded removing MUIUnattend-OOBE handshake value
2011-08-19 17:18:11, Info SYSPRP Sysprep_Generalize_MUILangCleanup End.
2011-08-19 17:18:11, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' without error
2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{03513543-c453-2e4f-3200-c2f12d89732a}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'
2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'; executing it
2011-08-19 17:18:11, Info [shsetup] Sysprep_Cleanup_Shell entered
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipMachineOOBE' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipUserOOBE' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'HideEULAPage' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'NetworkLocation' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'ProtectYourPC' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'MediaBootInstall' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedProductKey' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedEula' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedLanguageSelection' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupSQMOptIn' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendCreatedUser' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetTimeZone' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetAutologon' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'AutoAdminLogon' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultUserName' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultDomainName' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'SOFTWARE\Policies\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\FirstNetwork' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'HideWizard' returned 2
2011-08-19 17:18:11, Info [shsetup] Deleting temp files for 'S-1-5-18'
2011-08-19 17:18:11, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent' (0x80070002)
2011-08-19 17:18:11, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Local\Temp' (0x80070002)
2011-08-19 17:18:11, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff
2011-08-19 17:18:11, Info [shsetup] Cleaning up user hive for 'S-1-5-19'
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2
2011-08-19 17:18:11, Info [shsetup] Deleting temp files for 'S-1-5-19'
2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Local\Temp'
2011-08-19 17:18:11, Info [shsetup] Cleaning up user hive for 'S-1-5-20'
2011-08-19 17:18:11, Info [shsetup] Deleting temp files for 'S-1-5-20'
2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp'
2011-08-19 17:18:11, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000
2011-08-19 17:18:11, Info [shsetup] Cleaning up user hive for 'S-1-5-21-3007790038-290154040-4075851062-500'
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 0
2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 0
2011-08-19 17:18:11, Info [shsetup] Deleting temp files for 'S-1-5-21-3007790038-290154040-4075851062-500'
2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Local\Temp'
2011-08-19 17:18:11, Info [shsetup] SanitizeDeskBands entered
2011-08-19 17:18:11, Info [shsetup] SanitizeDeskBands exit
2011-08-19 17:18:11, Info [shsetup] PrimeStartMenuShortcuts entered
2011-08-19 17:18:25, Info [shsetup] PrimeStartMenuShortcuts exit
2011-08-19 17:18:25, Info [shsetup] Sysprep_Cleanup_Shell exit
2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' without error
2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1f954290-a3bd-7c6b-ac99-fda4b6fe1603}; will try to launch 'wer.dll,WerSysprepCleanup'
2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepCleanup'; executing it
2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepCleanup' without error
2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67011352-10f6-73b5-0c1b-833a374ea884}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'
2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'; executing it
2011-08-19 17:18:25, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain
2011-08-19 17:18:25, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do
2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' without error
2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{d9d03ab7-c7a6-4587-1dcd-fb0609f92d84}; will try to launch 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'
2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'; executing it
2011-08-19 17:18:25, Info capisp.dll::DisableAdministratorIfApplicable disabled the admin account.
2011-08-19 17:18:25, Info capisp.dll::CryptoSysPrep_Clean: returning 0
2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' without error
2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{79b40229-f48c-7547-16d3-ec814bdc5adc}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'
2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'; executing it
2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' without error
2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{352676dd-145f-cf4f-feb3-aa882aa02408}; will try to launch 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'
2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'; executing it
2011-08-19 17:18:25, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _DisableService returned successfully.
2011-08-19 17:18:25, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _CreateBlockingRegKey returned successfully.
2011-08-19 17:18:25, Info SYSPRP MSS: _StopService status checking loop 0 round, QueryServiceStatus return TRUE, the status is 0x3
2011-08-19 17:18:26, Info SYSPRP MSS: _StopService status checking loop 1 round, QueryServiceStatus return TRUE, the status is 0x1
2011-08-19 17:18:27, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' without error
2011-08-19 17:18:27, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{f9e8597e-e3f1-9942-5fbc-2ce1ce25c0e2}; will try to launch 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'
2011-08-19 17:18:27, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'; executing it
2011-08-19 17:18:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' without error
2011-08-19 17:18:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{4aaf8557-52af-9241-b6bc-e36d2d203cef}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'
2011-08-19 17:18:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'; executing it
2011-08-19 17:18:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' without error
2011-08-19 17:18:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{ccf004d0-c18e-a2d4-b4ea-08ccb5259f11}; will try to launch 'srcore.dll,SysprepCleanup'
2011-08-19 17:18:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepCleanup'; executing it
2011-08-19 17:18:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepCleanup' without error
2011-08-19 17:18:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{de7df4f0-0ce9-ca23-6049-1807de6941d3}; will try to launch 'drmv2clt.dll,Sysprep'
2011-08-19 17:18:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'drmv2clt.dll,Sysprep'; executing it
2011-08-19 17:18:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'drmv2clt.dll,Sysprep' without error
2011-08-19 17:18:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{9733bd0b-72a8-af29-76ba-be8ae2c8be6f}; will try to launch 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'
2011-08-19 17:18:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'; executing it
2011-08-19 17:18:28, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:MOOBE==MOOBE_RUNNING_STATE_ALREADY_RAN
2011-08-19 17:18:28, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:found winsatapi\LastFormalAssessment key
2011-08-19 17:18:28, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:deleted winsat\MOOBE key
2011-08-19 17:18:28, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:Unable to get a handle from FindFirstFile
2011-08-19 17:18:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' without error
2011-08-19 17:18:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{b4db0c88-1c6a-c5e8-f385-df67f3f1f575}; will try to launch 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'
2011-08-19 17:18:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'; executing it
2011-08-19 17:18:29, Warning TapiSysPrep.dll:RetainTapiLocations:RegQueryValueEx() returned 2
2011-08-19 17:18:29, Info TapiSysPrep.dll:RetainTapiLocations:returning 1
2011-08-19 17:18:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' without error
2011-08-19 17:18:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{e0053bef-049c-9ba1-e7db-793f9e538edd}; will try to launch 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'
2011-08-19 17:18:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'; executing it
2011-08-19 17:18:29, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user registry data found to delete
2011-08-19 17:18:29, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user profile files to delete
2011-08-19 17:18:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' without error
2011-08-19 17:18:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\2D153B43-11B4-461f-AA43-832B2C8B8872; will try to launch 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'
2011-08-19 17:18:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'; executing it
2011-08-19 17:18:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' without error
2011-08-19 17:18:29, Info [0x0f004c] SYSPRP WaitThread:Exiting spawned waiting thread
2011-08-19 17:18:29, Info [0x0f007a] SYSPRP FCreateTagFile:Successfully created tag file C:\Windows\System32\sysprep\Sysprep_succeeded.tag
2011-08-19 17:18:29, Info [0x0f0041] SYSPRP WinMain:Processing system shutdown request.
2011-08-19 17:18:29, Info [0x0f0074] SYSPRP ProcessShutdown:Successfully enabled the shutdown privilege
2011-08-19 17:18:29, Info [0x0f0076] SYSPRP ProcessShutdown:Successfully called InitiateSystemShutdownEx to reboot the computer
2011-08-19 17:18:29, Info [0x0f0052] SYSPRP Shutting down SysPrep log
2011-08-19 17:18:29, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:18:29
2011-08-19 17:20:30, Info SYSPRP ========================================================
2011-08-19 17:20:30, Info SYSPRP === Beginning of a new sysprep run ===
2011-08-19 17:20:30, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:20:30
2011-08-19 17:20:30, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\system32\sysprep\Panther
2011-08-19 17:20:30, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine
2011-08-19 17:20:30, Info [0x0f007c] SYSPRP FCreateTagFile:Successfully deleted tag file C:\Windows\system32\sysprep\Sysprep_succeeded.tag
2011-08-19 17:20:31, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'REBOOT'
2011-08-19 17:20:31, Info [0x0f003d] SYSPRP WinMain:Displaying dialog box for user to choose sysprep mode...
2011-08-19 17:20:39, Error [0x0f0043] SYSPRP WinMain:The sysprep dialog box returned FALSE
2011-08-19 17:20:39, Info [0x0f0052] SYSPRP Shutting down SysPrep log
2011-08-19 17:20:39, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:20:39
2011-08-19 17:24:43, Info SYSPRP ========================================================
2011-08-19 17:24:43, Info SYSPRP === Beginning of a new sysprep run ===
2011-08-19 17:24:43, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:24:43
2011-08-19 17:24:43, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\System32\Sysprep\Panther
2011-08-19 17:24:43, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine
2011-08-19 17:24:43, Info [0x0f007e] SYSPRP FCreateTagFile:Tag file C:\Windows\System32\Sysprep\Sysprep_succeeded.tag does not already exist, no need to delete anything
2011-08-19 17:24:43, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'GENERALIZE'
2011-08-19 17:24:43, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'OOBE'
2011-08-19 17:24:43, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'QUIT'
2011-08-19 17:24:43, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'UNATTEND'
2011-08-19 17:24:43, Info [0x0f004a] SYSPRP WaitThread:Entering spawned waiting thread
2011-08-19 17:24:43, Info [sysprep.exe] UnattendFindAnswerFile: Looking at explicitly provided unattend file [C:\Windows\System32\Sysprep\sysprep64.xml]...
2011-08-19 17:24:43, Info [sysprep.exe] UnattendFindAnswerFile: [C:\Windows\System32\Sysprep\sysprep64.xml] meets criteria for an explicitly provided unattend file.
2011-08-19 17:24:43, Info SYSPRP SysprepSearchForUnattend: Using unattend file at [C:\Windows\System32\Sysprep\sysprep64.xml].
2011-08-19 17:24:43, Info SYSPRP SysprepSearchForUnattend: [generalize] pass in unattend file [C:\Windows\System32\Sysprep\sysprep64.xml] either doesn't exist or passed validation
2011-08-19 17:24:43, Info SYSPRP WinMain:Found unattend file at [C:\Windows\System32\Sysprep\sysprep64.xml]; caching...
2011-08-19 17:24:43, Info SYSPRP WinMain:Processing unattend file's 'generalize' pass...
2011-08-19 17:24:43, Info SYSPRP Sysprep is running a generalize pass with the following unattend file: [%windir%\panther\unattend.xml]
2011-08-19 17:24:43, Info SYSPRP RunUnattendGeneralizePass: Sysprep unattend generalize pass exits; hr = 0x0, hrResult = 0x0, bRebootRequired = 0x0
2011-08-19 17:24:43, Info [0x0f00ac] SYSPRP WinMain:Processing 'cleanup' external provider request.
2011-08-19 17:24:43, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3
2011-08-19 17:24:43, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup
2011-08-19 17:24:43, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Cleanup
2011-08-19 17:24:43, Info [0x0f00ad] SYSPRP WinMain:Processing 'generalize' extrenal provider request.
2011-08-19 17:24:43, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 1
2011-08-19 17:24:43, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Generalize
2011-08-19 17:24:43, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Generalize
2011-08-19 17:24:43, Info [0x0f003f] SYSPRP WinMain:Processing 'cleanup' internal provider request.
2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67196725-a666-73a6-a048-412e48a3b856}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'
2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'; executing it
2011-08-19 17:24:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' without error
2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1e7f4452-a4b4-5a32-d01e-70397b096ced}; will try to launch 'sqmapi.dll,SqmSysprepCleanup'
2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepCleanup'; executing it
2011-08-19 17:24:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepCleanup' without error
2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{2c8a362b-4dc1-38b9-c4d8-ce732ddcc48e}; will try to launch 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'
2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'; executing it
2011-08-19 17:24:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' without error
2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{86297dc3-52b0-7d4e-f9a8-572bb66ac5ae}; will try to launch 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'
2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'; executing it
2011-08-19 17:24:43, Info SYSPRP Sysprep_Generalize_MUILangCleanup Start.
2011-08-19 17:24:43, Info SYSPRP Disabling CMF cache SUCCEEDED
2011-08-19 17:24:43, Info SYSPRP Removing scheduled task for running lpremove.exe and all related data
2011-08-19 17:24:43, Info SYSPRP Removing scheduled task for lpremove.exe succeeed
2011-08-19 17:24:43, Info SYSPRP Removing MUIUnattend-OOBE handshake value
2011-08-19 17:24:43, Info SYSPRP MUIUnattend-OOBE handshake value is not present on the system
2011-08-19 17:24:43, Info SYSPRP Sysprep_Generalize_MUILangCleanup End.
2011-08-19 17:24:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' without error
2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{03513543-c453-2e4f-3200-c2f12d89732a}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'
2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'; executing it
2011-08-19 17:24:43, Info [shsetup] Sysprep_Cleanup_Shell entered
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipMachineOOBE' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipUserOOBE' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'HideEULAPage' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'NetworkLocation' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'ProtectYourPC' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'MediaBootInstall' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedProductKey' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedEula' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedLanguageSelection' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupSQMOptIn' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendCreatedUser' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetTimeZone' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetAutologon' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'AutoAdminLogon' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultUserName' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultDomainName' returned 0
2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'SOFTWARE\Policies\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\FirstNetwork' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'HideWizard' returned 2
2011-08-19 17:24:43, Info [shsetup] Deleting temp files for 'S-1-5-18'
2011-08-19 17:24:43, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent' (0x80070002)
2011-08-19 17:24:43, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Local\Temp' (0x80070002)
2011-08-19 17:24:43, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff
2011-08-19 17:24:43, Info [shsetup] Cleaning up user hive for 'S-1-5-19'
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2
2011-08-19 17:24:43, Info [shsetup] Deleting temp files for 'S-1-5-19'
2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Local\Temp'
2011-08-19 17:24:43, Info [shsetup] Cleaning up user hive for 'S-1-5-20'
2011-08-19 17:24:43, Info [shsetup] Deleting temp files for 'S-1-5-20'
2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp'
2011-08-19 17:24:43, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000
2011-08-19 17:24:43, Info [shsetup] Cleaning up user hive for 'S-1-5-21-3007790038-290154040-4075851062-500'
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 0
2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 0
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 0
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 0
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 0
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 0
2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 0
2011-08-19 17:24:43, Info [shsetup] Deleting temp files for 'S-1-5-21-3007790038-290154040-4075851062-500'
2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent'
2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Local\Temp'
2011-08-19 17:24:43, Info [shsetup] SanitizeDeskBands entered
2011-08-19 17:24:43, Info [shsetup] SanitizeDeskBands exit
2011-08-19 17:24:43, Info [shsetup] PrimeStartMenuShortcuts entered
2011-08-19 17:24:58, Info [shsetup] PrimeStartMenuShortcuts exit
2011-08-19 17:24:58, Info [shsetup] Sysprep_Cleanup_Shell exit
2011-08-19 17:24:58, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' without error
2011-08-19 17:24:58, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1f954290-a3bd-7c6b-ac99-fda4b6fe1603}; will try to launch 'wer.dll,WerSysprepCleanup'
2011-08-19 17:24:58, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepCleanup'; executing it
2011-08-19 17:24:58, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepCleanup' without error
2011-08-19 17:24:58, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67011352-10f6-73b5-0c1b-833a374ea884}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'
2011-08-19 17:24:58, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'; executing it
2011-08-19 17:24:58, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain
2011-08-19 17:24:58, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do
2011-08-19 17:24:58, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' without error
2011-08-19 17:24:58, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{d9d03ab7-c7a6-4587-1dcd-fb0609f92d84}; will try to launch 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'
2011-08-19 17:24:58, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'; executing it
2011-08-19 17:24:58, Info capisp.dll::DisableAdministratorIfApplicable disabled the admin account.
2011-08-19 17:24:58, Info capisp.dll::CryptoSysPrep_Clean: returning 0
2011-08-19 17:24:58, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' without error
2011-08-19 17:24:58, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{79b40229-f48c-7547-16d3-ec814bdc5adc}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'
2011-08-19 17:24:58, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'; executing it
2011-08-19 17:24:59, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' without error
2011-08-19 17:24:59, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{352676dd-145f-cf4f-feb3-aa882aa02408}; will try to launch 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'
2011-08-19 17:24:59, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'; executing it
2011-08-19 17:24:59, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _DisableService returned successfully.
2011-08-19 17:24:59, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _CreateBlockingRegKey returned successfully.
2011-08-19 17:24:59, Info SYSPRP MSS: _StopService status checking loop 0 round, QueryServiceStatus return TRUE, the status is 0x3
2011-08-19 17:25:00, Info SYSPRP MSS: _StopService status checking loop 1 round, QueryServiceStatus return TRUE, the status is 0x3
2011-08-19 17:25:01, Info SYSPRP MSS: _StopService status checking loop 2 round, QueryServiceStatus return TRUE, the status is 0x3
2011-08-19 17:25:02, Info SYSPRP MSS: _StopService status checking loop 3 round, QueryServiceStatus return TRUE, the status is 0x1
2011-08-19 17:25:02, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' without error
2011-08-19 17:25:02, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{f9e8597e-e3f1-9942-5fbc-2ce1ce25c0e2}; will try to launch 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'
2011-08-19 17:25:02, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'; executing it
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{4aaf8557-52af-9241-b6bc-e36d2d203cef}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'; executing it
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{ccf004d0-c18e-a2d4-b4ea-08ccb5259f11}; will try to launch 'srcore.dll,SysprepCleanup'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepCleanup'; executing it
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepCleanup' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{de7df4f0-0ce9-ca23-6049-1807de6941d3}; will try to launch 'drmv2clt.dll,Sysprep'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'drmv2clt.dll,Sysprep'; executing it
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'drmv2clt.dll,Sysprep' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{9733bd0b-72a8-af29-76ba-be8ae2c8be6f}; will try to launch 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'; executing it
2011-08-19 17:25:03, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:Unable to get a handle from FindFirstFile
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{b4db0c88-1c6a-c5e8-f385-df67f3f1f575}; will try to launch 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'; executing it
2011-08-19 17:25:03, Warning TapiSysPrep.dll:RetainTapiLocations:RegQueryValueEx() returned 2
2011-08-19 17:25:03, Info TapiSysPrep.dll:RetainTapiLocations:returning 1
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{e0053bef-049c-9ba1-e7db-793f9e538edd}; will try to launch 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'; executing it
2011-08-19 17:25:03, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user registry data found to delete
2011-08-19 17:25:03, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user profile files to delete
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\2D153B43-11B4-461f-AA43-832B2C8B8872; will try to launch 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'; executing it
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' without error
2011-08-19 17:25:03, Info [0x0f0040] SYSPRP WinMain:Processing 'generalize' internal provider request.
2011-08-19 17:25:03, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 1
2011-08-19 17:25:03, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Generalize
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{67196725-a666-73a6-07bd-00f3276e41cf}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk'; executing it
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{899480af-8f8b-16c1-58aa-df121c7314ed}; will try to launch 'C:\Windows\System32\reagent.dll,WinRE_Generalize'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\reagent.dll,WinRE_Generalize'; executing it
2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\reagent.dll,WinRE_Generalize' without error
2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8bc7dae9-655e-8ca5-d3d1-771286930ef6}; will try to launch 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging'
2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging'; executing it
2011-08-19 17:25:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging' without error
2011-08-19 17:25:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{1e7f4452-a4b4-5a32-5cc0-12a85b132913}; will try to launch 'sqmapi.dll,SqmSysprepGeneralize'
2011-08-19 17:25:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepGeneralize'; executing it
2011-08-19 17:25:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepGeneralize' without error
2011-08-19 17:25:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{d0c365cf-6d23-9db2-b74d-4e1efd035af7}; will try to launch 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp'
2011-08-19 17:25:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp'; executing it
2011-08-19 17:25:06, Info SYSPRP SPPNP: Sysprep_Generalize_Pnp: Enter
2011-08-19 17:25:06, Info SYSPRP SPPNP: Retrieving the list of function drivers from the critical device database (CDDB).
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver i8042prt was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Serial was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver pcmcia was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver isapnp was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver nvraid was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Parport was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver fdc was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver flpydisk was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver msisadrv was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver pci was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ACPI was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver WmiAcpi was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Wd was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ErrDev was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver sermouse was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver sbp2port was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver CmBatt was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver AcpiPmi was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver AmdPPM was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver AmdK8 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver intelppm was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver IPMIDRV was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Processor was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vmbus was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver WacomPen was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver hcw85cir was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver BTHMODEM was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HidBth was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HidIr was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Compbatt was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver UmPass was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver cdrom was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver disk was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HidUsb was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbprint was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver sfloppy was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver kbdhid was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver mouhid was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver MTConfig was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HidBatt was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver atapi was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver BrSerWdm was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver BrUsbMdm was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver pciide was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver msahci was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HDAudBus was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ohci1394 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbuhci was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbohci was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbehci was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HpSAMD was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver LSI_SCSI was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver LSI_SAS was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver MegaSR was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver megasas was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver LSI_SAS2 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver LSI_FC was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver amdsbs was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver amdsata was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver 1394ohci was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver nfrd960 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver amdide was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver SiSRaid2 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver SiSRaid4 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver stexstor was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ql2300 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ql40xx was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver cmdide was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver aliide was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver nvstor was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver elxstor was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver viaide was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vsmraid was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver iirsp was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver s3cap was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver b06bdrv was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ebdrv was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vmci was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver pvscsi was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver intelide was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver iaStorV was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver adpahci was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver arc was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver arcsas was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver adp94xx was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver adpu320 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver blbdrive was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver circlass was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver CompositeBus was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver iScsiPrt was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver mpio was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver msdsm was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver mssmbios was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver rdpbus was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver TermDD was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver swenum was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver tsusbhub was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver umbus was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vdrvroot was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver volmgr was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver sffdisk was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver volsnap was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver terminpt was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver USBSTOR was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbhub was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbccgp was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver TsUsbGD was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbcir was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Brserid was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver USBAAPL64 was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vmusb was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver dmvsc was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Synth3dVsc was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver storvsc was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver VMBusHID was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vhdmp was retrieved from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Finished retrieving the list of function drivers from the CDDB.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Enabling the function drivers listed in the critical device database (CDDB) ...
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service vhdmp was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service VMBusHID was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service storvsc was 0.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver storvsc has been enabled.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service Synth3dVsc was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service dmvsc was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service vmusb was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service USBAAPL64 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service Brserid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service usbcir was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service TsUsbGD was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service usbccgp was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service usbhub was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service USBSTOR was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service terminpt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Service volsnap is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service sffdisk was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Service volmgr is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Service vdrvroot is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service umbus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service tsusbhub was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service swenum was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Service TermDD is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service rdpbus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Service mssmbios is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service msdsm was 0.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver msdsm has been enabled.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service mpio was 0.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver mpio has been enabled.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service iScsiPrt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service CompositeBus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service circlass was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:06, Info SYSPRP SPPNP: Service blbdrive is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service adpu320 was 0.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver adpu320 has been enabled.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service adp94xx was 0.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver adp94xx has been enabled.
2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service arcsas was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver arcsas has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service arc was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver arc has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service adpahci was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver adpahci has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service iaStorV was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver iaStorV has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service intelide is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service pvscsi was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver pvscsi has been enabled.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service vmci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service ebdrv was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service b06bdrv was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service s3cap was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service iirsp was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver iirsp has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service vsmraid was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver vsmraid has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service viaide was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver viaide has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service elxstor was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver elxstor has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service nvstor was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver nvstor has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service aliide was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver aliide has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service cmdide was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver cmdide has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service ql40xx was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver ql40xx has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service ql2300 was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver ql2300 has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service stexstor was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver stexstor has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service SiSRaid4 was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver SiSRaid4 has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service SiSRaid2 was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver SiSRaid2 has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service amdide was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver amdide has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service nfrd960 was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver nfrd960 has been enabled.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service 1394ohci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service amdsata was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver amdsata has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service amdsbs was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver amdsbs has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service LSI_FC was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver LSI_FC has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service LSI_SAS2 was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver LSI_SAS2 has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service megasas was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver megasas has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service MegaSR was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver MegaSR has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service LSI_SAS is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service LSI_SCSI was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver LSI_SCSI has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service HpSAMD was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver HpSAMD has been enabled.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service usbehci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service usbohci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service usbuhci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service ohci1394 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HDAudBus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service msahci was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver msahci has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service pciide was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver pciide has been enabled.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service BrUsbMdm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service BrSerWdm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service atapi is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HidBatt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service MTConfig was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service mouhid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service kbdhid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service sfloppy was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service usbprint was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HidUsb was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service disk is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service cdrom is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service UmPass was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service Compbatt is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HidIr was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HidBth was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service BTHMODEM was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service hcw85cir was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service WacomPen was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service vmbus was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver vmbus has been enabled.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service Processor was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service IPMIDRV was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service intelppm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service AmdK8 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service AmdPPM was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service AcpiPmi was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service CmBatt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service sbp2port was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver sbp2port has been enabled.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service sermouse was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service ErrDev was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service Wd was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver Wd has been enabled.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service WmiAcpi was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service ACPI is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service pci is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service msisadrv is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service flpydisk was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service fdc was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service Parport was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service nvraid was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver nvraid has been enabled.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service isapnp was 0.
2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver isapnp has been enabled.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service pcmcia was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Service Serial is currently not disabled. Hence there is no need to re-enable it.
2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service i8042prt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Finished enabling the function drivers listed in the CDDB.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Uninstalling all existing devices <full generalize>.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_AGILEVPNMINIPORT\0000.
2011-08-19 17:25:07, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_L2TPMINIPORT\0000.
2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANBH\0000.
2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANIP\0000.
2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANIPV6\0000.
2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_PPPOEMINIPORT\0000.
2011-08-19 17:25:08, Info SYSPRP SPPNP: Uninstalling device SW\{EEAB7790-C514-11D1-B42B-00805FC1270E}\ASYNCMAC failed with 0x5.
2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_PPTPMINIPORT\0000.
2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_SSTPMINIPORT\0000.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDPBUS\0000.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDP_KBD\0000.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDP_MOU\0000.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\SYSTEM\0000.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\*ISATAP\0000.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\UMBUS\0000.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\*TEREDO\0000.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Uninstalling device ROOT\ACPI_HAL\0000 failed with 0xE0000231.
2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\VMWARE\0000.
2011-08-19 17:25:10, Info SYSPRP SPPNP: Uninstalling device ROOT\BLBDRIVE\0000 failed with 0xE0000231.
2011-08-19 17:25:10, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\VMWARE\0001.
2011-08-19 17:25:10, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\COMPOSITEBUS\0000.
2011-08-19 17:25:10, Info SYSPRP SPPNP: Uninstalling device ROOT\VOLMGR\0000 failed with 0xE0000231.
2011-08-19 17:25:10, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\COMPOSITE_BATTERY\0000.
2011-08-19 17:26:42, Info SYSPRP SPPNP: Reflected all boot critical driver packages (91579 ms).
2011-08-19 17:26:42, Info SYSPRP SPPNP: Sysprep_Generalize_Pnp: Exit
2011-08-19 17:26:42, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp' without error
2011-08-19 17:26:42, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{960b724d-0479-6dd8-0470-6c42dc9b8f85}; will try to launch 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize'
2011-08-19 17:26:42, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize'; executing it
2011-08-19 17:26:42, Info SYSPRP iphlpsvc.dll: sysprep generalize called
2011-08-19 17:26:42, Info SYSPRP Found interface in scavenger.
2011-08-19 17:26:43, Info SYSPRP Successfully uninstalled interface in scavenger
2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize' without error
2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{243bb634-be68-0139-f4c8-f1c87dade9d7}; will try to launch 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup'
2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup'; executing it
2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup' without error
2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{df593d24-f963-8be2-86d6-c722da22bf5b}; will try to launch 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize'
2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize'; executing it
2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize' without error
2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{03513543-c453-2e4f-5ee6-b970cace3cd8}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell'
2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell'; executing it
2011-08-19 17:26:43, Info [shsetup] Sysprep_Generalize_Shell entered
2011-08-19 17:26:43, Info [shsetup] Sysprep_Generalize_Shell exit
2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell' without error
2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{1f954290-a3bd-7c6b-2062-3fd9d1266740}; will try to launch 'wer.dll,WerSysprepGeneralize'
2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepGeneralize'; executing it
2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepGeneralize' without error
2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{4840d621-1b47-334f-b1a6-321233838362}; will try to launch 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize'
2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize'; executing it
2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize' without error
2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{67011352-10f6-73b5-85e9-6064e10071b9}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net'
2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net'; executing it
2011-08-19 17:26:43, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain
2011-08-19 17:26:43, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do
2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net' without error
2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{3aa3f98d-491f-7656-533f-7db889fff253}; will try to launch 'C:\Windows\System32\slc.dll,SLReArmWindows'
2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\slc.dll,SLReArmWindows'; executing it
2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\slc.dll,SLReArmWindows' without error
2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{d9d03ab7-c7a6-4587-c28d-ccc47a787790}; will try to launch 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize'
2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize'; executing it
2011-08-19 17:26:44, Info capisp.dll::CAPISysPrep_Generalize: returning 0
2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize' without error
2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{6a6b0fac-5606-6e68-410d-e7bf974f5136}; will try to launch 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd'
2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd'; executing it
2011-08-19 17:26:44, Info TOOL Sysprep_Generalize_Bcd: Located BCD store on system drive. Generalizing it...
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Found the memory tester object.
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Found the Windows OS Loader object {d54562fb-41e1-11e0-9007-94b295923b48} for the currently running OS.
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Found the resume object {d54562fa-41e1-11e0-9007-94b295923b48} for the OS loader.
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: System drive backed by VHD = 0
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Generalizing object {9dea862c-5cdd-4e70-acc1-f32b344d4795}
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0]
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Generalizing object {b2721d73-1db4-4c62-bf78-c548a880142d}
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Generalizing object {d54562fb-41e1-11e0-9007-94b295923b48}
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized OS device. Status = [0x0]
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Generalizing object {d54562fa-41e1-11e0-9007-94b295923b48}
2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized hiberfile device. Status = [0x0]
2011-08-19 17:26:44, Info TOOL Sysprep_Generalize_Bcd: Successfully generalized the bcd store. Status=[0x0]
2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd' without error
2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8fd6ce7c-4301-d490-719b-d787d2bde1cd}; will try to launch 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize'
2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize'; executing it
2011-08-19 17:26:44, Info SYSPRP nlmsprep.dll: Generalize start
2011-08-19 17:26:44, Info SYSPRP nlmsprep.dll: Generalize finish
2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize' without error
2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{79b40229-f48c-7547-1eb2-96b7091aa28f}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize'
2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize'; executing it
2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize' without error
2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8dde3abb-19cb-88f8-4e07-05c697cc2872}; will try to launch 'RacEngn.dll,RacSysprepGeneralize'
2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'RacEngn.dll,RacSysprepGeneralize'; executing it
2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'RacEngn.dll,RacSysprepGeneralize' without error
2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{20b6ca3b-166d-4e8d-af73-72df2987e480}; will try to launch 'msmmsp.dll,MountMgr_Generalize'
2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'msmmsp.dll,MountMgr_Generalize'; executing it
2011-08-19 17:26:44, Info msmmsp::MountMgr_Generalize ENTER
2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'msmmsp.dll,MountMgr_Generalize' without error
2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{4aaf8557-52af-9241-469e-acbb347c3c07}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE'
2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE'; executing it
2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE' without error
2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{71e01f6c-a271-b3b1-05f0-8c48a330cb4c}; will try to launch 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize'
2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize'; executing it
2011-08-19 17:26:45, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastScanRun does not exist, skipping action.
2011-08-19 17:26:45, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastScanType does not exist, skipping action.
2011-08-19 17:26:45, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastQuickScanID does not exist, skipping action.
2011-08-19 17:26:45, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastFullScanID does not exist, skipping action.
2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize' without error
2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{ccf004d0-c18e-a2d4-ee22-e585dac90889}; will try to launch 'srcore.dll,SysprepGeneralize'
2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepGeneralize'; executing it
2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepGeneralize' without error
2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{68cac03c-b4c6-675e-1b30-cf21359228e2}; will try to launch 'spwmp.dll,Sysprep_Generalize_WMP'
2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'spwmp.dll,Sysprep_Generalize_WMP'; executing it
2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'spwmp.dll,Sysprep_Generalize_WMP' without error
2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{b636fa27-124f-6436-6a6f-2fe2739a2b89}; will try to launch 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize'
2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize'; executing it
2011-08-19 17:26:45, Info SYSPRP WindowsSideShow: Enabling SystemDataProviders task returned 0x00000000
2011-08-19 17:26:45, Info SYSPRP WindowsSideShow: Enabling SessionAgent task returned 0x00000000
2011-08-19 17:26:45, Info SYSPRP WindowsSideShow: Enabling GadgetManager task returned 0x00000000
2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize' without error
2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8a2650e9-70de-392f-5b09-34c3ac14764d}; will try to launch 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE'
2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE'; executing it
2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE' without error
2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{cb71e18d-7833-6f0f-2d00-e35ade2ecb27}; will try to launch 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize'
2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize'; executing it
2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize' without error
2011-08-19 17:26:45, Info [0x0f004c] SYSPRP WaitThread:Exiting spawned waiting thread
2011-08-19 17:26:45, Info [0x0f007a] SYSPRP FCreateTagFile:Successfully created tag file C:\Windows\System32\Sysprep\Sysprep_succeeded.tag
2011-08-19 17:26:45, Info [0x0f0052] SYSPRP Shutting down SysPrep log
2011-08-19 17:26:45, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:26:45
Hi
I have hundreds of Optiplex 755's, I have built my reference image using a vmware workstation. It is windows 7 enterprise x64. Before I seal the image I uninstall vmware tools.
When I deploy the image sysprep always crashes on the specialize pass
Here is my sysprep.xml answer file.
?xml version="1.0" encoding="utf-8"?> <unattend xmlns="urn:schemas-microsoft-com:unattend"> <settings pass="specialize"> <component name="Microsoft-Windows-UnattendedJoin" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State"> <Identification> <JoinWorkgroup>LABS</JoinWorkgroup> </Identification> </component> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State"> <ComputerName>*</ComputerName> <RegisteredOrganization>My Organization</RegisteredOrganization> <RegisteredOwner>My Organization</RegisteredOwner> <CopyProfile>true</CopyProfile> </component> <component name="Microsoft-Windows-Deployment" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State"> <RunSynchronous> <RunSynchronousCommand wcm:action="add"> <Description>UIU-COMMAND-ID={4dec1d91-5b7c-4f41-91e1-ee8d57db943e}</Description> <Order>1</Order> <Path>reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\NewNetworks" /v NetworkList /t REG_MULTI_SZ /d "" /f</Path> </RunSynchronousCommand> <RunSynchronousCommand wcm:action="add"> <Path>net user administrator /active:yes</Path> <Order>2</Order> </RunSynchronousCommand> </RunSynchronous> </component> </settings> <settings pass="oobeSystem"> <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State"> <UserAccounts> <AdministratorPassword> <Value>aABjAG0AaABzAD8AQQBkAG0AaQBuAGkAcwB0AHIAYQB0AG8AcgBQAGEAcwBzAHcAbwByAGQA</Value> <PlainText>false</PlainText> </AdministratorPassword> <LocalAccounts> <LocalAccount wcm:action="add"> <Password> <Value>dABlAGEAYwBoAGUAcgBQAGEAcwBzAHcAbwByAGQA</Value> <PlainText>false</PlainText> </Password> <Description>Faculty</Description> <DisplayName>Faculty</DisplayName> <Group>Administrator</Group> <Name>Faculty</Name> </LocalAccount> <LocalAccount wcm:action="add"> <Password> <Value>aABjAG0AaABzAD8AUABhAHMAcwB3AG8AcgBkAA==</Value> <PlainText>false</PlainText> </Password> <Description>Admin</Description> <DisplayName>Admin</DisplayName> <Group>Administrator</Group> <Name>Admin</Name> </LocalAccount> </LocalAccounts> </UserAccounts> <OOBE> <HideEULAPage>true</HideEULAPage> <SkipMachineOOBE>true</SkipMachineOOBE> <SkipUserOOBE>true</SkipUserOOBE> <NetworkLocation>Work</NetworkLocation> <ProtectYourPC>3</ProtectYourPC> </OOBE> <TimeZone>Eastern Standard Time</TimeZone> <AutoLogon> <Password> <Value>aABjAG0AaABzAD8AUABhAHMAcwB3AG8AcgBkAA==</Value> <PlainText>false</PlainText> </Password> <Enabled>true</Enabled> <Username>Administrator</Username> </AutoLogon> </component> <component name="Microsoft-Windows-International-Core" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SystemLocale>en-US</SystemLocale> <InputLocale>0409:00000409;1009:00001009;0c0c:00000c0c</InputLocale> <UILanguage>en-US</UILanguage> <UserLocale>en-US</UserLocale> </component> </settings> <cpi:offlineImage cpi:source="wim:c:/winpro764bit/install.wim#Windows 7 ENTERPRISE" xmlns:cpi="urn:schemas-microsoft-com:cpi" /> </unattend>Here is my setupact.log
2011-08-08 16:44:14, Info SYSPRP ======================================================== 2011-08-08 16:44:14, Info SYSPRP === Beginning of a new sysprep run === 2011-08-08 16:44:14, Info SYSPRP ======================================================== 2011-08-08 16:44:14, Info [0x0f004d] SYSPRP The time is now 2011-08-08 16:44:14 2011-08-08 16:44:14, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\System32\Sysprep\Panther 2011-08-08 16:44:14, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine 2011-08-08 16:44:14, Info [0x0f007e] SYSPRP FCreateTagFile:Tag file C:\Windows\System32\Sysprep\Sysprep_succeeded.tag does not already exist, no need to delete anything 2011-08-08 16:44:14, Warning SYSPRP WinMain: File operations pending 2011-08-08 16:44:16, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'GENERALIZE' 2011-08-08 16:44:16, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'OOBE' 2011-08-08 16:44:16, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'QUIT' 2011-08-08 16:44:16, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'UNATTEND' 2011-08-08 16:44:16, Info [0x0f004a] SYSPRP WaitThread:Entering spawned waiting thread 2011-08-08 16:44:16, Info [sysprep.exe] UnattendFindAnswerFile: Looking at explicitly provided unattend file [C:\Windows\System32\Sysprep\sysprep64.xml]... 2011-08-08 16:44:16, Info [sysprep.exe] UnattendFindAnswerFile: [C:\Windows\System32\Sysprep\sysprep64.xml] meets criteria for an explicitly provided unattend file. 2011-08-08 16:44:16, Info SYSPRP SysprepSearchForUnattend: Using unattend file at [C:\Windows\System32\Sysprep\sysprep64.xml]. 2011-08-08 16:44:16, Info SYSPRP SysprepSearchForUnattend: [generalize] pass in unattend file [C:\Windows\System32\Sysprep\sysprep64.xml] either doesn't exist or passed validation 2011-08-08 16:44:16, Info SYSPRP WinMain:Found unattend file at [C:\Windows\System32\Sysprep\sysprep64.xml]; caching... 2011-08-08 16:44:16, Info SYSPRP WinMain:Processing unattend file's 'generalize' pass... 2011-08-08 16:44:16, Info SYSPRP Sysprep is running a generalize pass with the following unattend file: [%windir%\panther\unattend.xml] 2011-08-08 16:44:16, Info SYSPRP RunUnattendGeneralizePass: Sysprep unattend generalize pass exits; hr = 0x0, hrResult = 0x0, bRebootRequired = 0x0 2011-08-08 16:44:16, Info [0x0f00ac] SYSPRP WinMain:Processing 'cleanup' external provider request. 2011-08-08 16:44:16, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3 2011-08-08 16:44:16, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup 2011-08-08 16:44:16, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Cleanup 2011-08-08 16:44:16, Info [0x0f00ad] SYSPRP WinMain:Processing 'generalize' extrenal provider request. 2011-08-08 16:44:16, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 1 2011-08-08 16:44:16, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Generalize 2011-08-08 16:44:16, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Generalize 2011-08-08 16:44:16, Info [0x0f003f] SYSPRP WinMain:Processing 'cleanup' internal provider request. 2011-08-08 16:44:16, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3 2011-08-08 16:44:16, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup 2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67196725-a666-73a6-a048-412e48a3b856}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' 2011-08-08 16:44:16, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'; executing it 2011-08-08 16:44:16, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' without error 2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1e7f4452-a4b4-5a32-d01e-70397b096ced}; will try to launch 'sqmapi.dll,SqmSysprepCleanup' 2011-08-08 16:44:16, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepCleanup'; executing it 2011-08-08 16:44:16, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepCleanup' without error 2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{2c8a362b-4dc1-38b9-c4d8-ce732ddcc48e}; will try to launch 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' 2011-08-08 16:44:16, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'; executing it 2011-08-08 16:44:16, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' without error 2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{86297dc3-52b0-7d4e-f9a8-572bb66ac5ae}; will try to launch 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' 2011-08-08 16:44:16, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'; executing it 2011-08-08 16:44:16, Info SYSPRP Sysprep_Generalize_MUILangCleanup Start. 2011-08-08 16:44:16, Info SYSPRP Disabling CMF cache SUCCEEDED 2011-08-08 16:44:16, Info SYSPRP Removing scheduled task for running lpremove.exe and all related data 2011-08-08 16:44:16, Info SYSPRP Removing scheduled task for lpremove.exe succeeed 2011-08-08 16:44:16, Info SYSPRP Removing MUIUnattend-OOBE handshake value 2011-08-08 16:44:16, Info SYSPRP MUIUnattend-OOBE handshake value is not present on the system 2011-08-08 16:44:16, Info SYSPRP Sysprep_Generalize_MUILangCleanup End. 2011-08-08 16:44:16, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' without error 2011-08-08 16:44:16, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{03513543-c453-2e4f-3200-c2f12d89732a}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' 2011-08-08 16:44:17, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'; executing it 2011-08-08 16:44:17, Info [shsetup] Sysprep_Cleanup_Shell entered 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipMachineOOBE' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipUserOOBE' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'HideEULAPage' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'NetworkLocation' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'ProtectYourPC' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'MediaBootInstall' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedProductKey' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedEula' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedLanguageSelection' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupSQMOptIn' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendCreatedUser' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetTimeZone' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetAutologon' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'AutoAdminLogon' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultUserName' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultDomainName' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'SOFTWARE\Policies\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\FirstNetwork' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'HideWizard' returned 0 2011-08-08 16:44:17, Info [shsetup] Deleting temp files for 'S-1-5-18' 2011-08-08 16:44:17, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent' (0x80070002) 2011-08-08 16:44:17, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Local\Temp' (0x80070002) 2011-08-08 16:44:17, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff 2011-08-08 16:44:17, Info [shsetup] Cleaning up user hive for 'S-1-5-19' 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-08 16:44:17, Info [shsetup] Deleting temp files for 'S-1-5-19' 2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Local\Temp' 2011-08-08 16:44:17, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff 2011-08-08 16:44:17, Info [shsetup] Cleaning up user hive for 'S-1-5-20' 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-08 16:44:17, Info [shsetup] Deleting temp files for 'S-1-5-20' 2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp' 2011-08-08 16:44:17, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000 2011-08-08 16:44:17, Info [shsetup] Cleaning up user hive for 'S-1-5-21-2813110343-969295344-4049937527-500' 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 0 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-08 16:44:17, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-08 16:44:17, Info [shsetup] Deleting temp files for 'S-1-5-21-2813110343-969295344-4049937527-500' 2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-08 16:44:17, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Local\Temp' 2011-08-08 16:44:17, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000 2011-08-08 16:44:17, Info [shsetup] SanitizeDeskBands entered 2011-08-08 16:44:17, Info [shsetup] SanitizeDeskBands exit 2011-08-08 16:44:17, Info [shsetup] PrimeStartMenuShortcuts entered 2011-08-08 16:44:22, Info [shsetup] PrimeStartMenuShortcuts exit 2011-08-08 16:44:22, Info [shsetup] Sysprep_Cleanup_Shell exit 2011-08-08 16:44:22, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' without error 2011-08-08 16:44:22, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1f954290-a3bd-7c6b-ac99-fda4b6fe1603}; will try to launch 'wer.dll,WerSysprepCleanup' 2011-08-08 16:44:22, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepCleanup'; executing it 2011-08-08 16:44:22, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepCleanup' without error 2011-08-08 16:44:22, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67011352-10f6-73b5-0c1b-833a374ea884}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' 2011-08-08 16:44:22, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'; executing it 2011-08-08 16:44:22, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain 2011-08-08 16:44:22, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do 2011-08-08 16:44:22, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' without error 2011-08-08 16:44:22, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{d9d03ab7-c7a6-4587-1dcd-fb0609f92d84}; will try to launch 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' 2011-08-08 16:44:22, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'; executing it 2011-08-08 16:44:22, Info capisp.dll::DisableAdministratorIfApplicable disabled the admin account. 2011-08-08 16:44:23, Info capisp.dll::CryptoSysPrep_Clean: returning 0 2011-08-08 16:44:23, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' without error 2011-08-08 16:44:23, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{79b40229-f48c-7547-16d3-ec814bdc5adc}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' 2011-08-08 16:44:23, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'; executing it 2011-08-08 16:44:23, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' without error 2011-08-08 16:44:23, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{352676dd-145f-cf4f-feb3-aa882aa02408}; will try to launch 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' 2011-08-08 16:44:23, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'; executing it 2011-08-08 16:44:23, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _DisableService returned successfully. 2011-08-08 16:44:23, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _CreateBlockingRegKey returned successfully. 2011-08-08 16:44:23, Info SYSPRP MSS: _StopService status checking loop 0 round, QueryServiceStatus return TRUE, the status is 0x3 2011-08-08 16:44:24, Info SYSPRP MSS: _StopService status checking loop 1 round, QueryServiceStatus return TRUE, the status is 0x3 2011-08-08 16:44:25, Info SYSPRP MSS: _StopService status checking loop 2 round, QueryServiceStatus return TRUE, the status is 0x3 2011-08-08 16:44:26, Info SYSPRP MSS: _StopService status checking loop 3 round, QueryServiceStatus return TRUE, the status is 0x1 2011-08-08 16:44:26, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' without error 2011-08-08 16:44:26, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{f9e8597e-e3f1-9942-5fbc-2ce1ce25c0e2}; will try to launch 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' 2011-08-08 16:44:26, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'; executing it 2011-08-08 16:44:27, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' without error 2011-08-08 16:44:27, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{4aaf8557-52af-9241-b6bc-e36d2d203cef}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' 2011-08-08 16:44:27, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'; executing it 2011-08-08 16:44:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' without error 2011-08-08 16:44:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{ccf004d0-c18e-a2d4-b4ea-08ccb5259f11}; will try to launch 'srcore.dll,SysprepCleanup' 2011-08-08 16:44:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepCleanup'; executing it 2011-08-08 16:44:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepCleanup' without error 2011-08-08 16:44:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{de7df4f0-0ce9-ca23-6049-1807de6941d3}; will try to launch 'drmv2clt.dll,Sysprep' 2011-08-08 16:44:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'drmv2clt.dll,Sysprep'; executing it 2011-08-08 16:44:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'drmv2clt.dll,Sysprep' without error 2011-08-08 16:44:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{9733bd0b-72a8-af29-76ba-be8ae2c8be6f}; will try to launch 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' 2011-08-08 16:44:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'; executing it 2011-08-08 16:44:29, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:MOOBE==MOOBE_RUNNING_STATE_ALREADY_RAN 2011-08-08 16:44:29, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:found winsatapi\LastFormalAssessment key 2011-08-08 16:44:29, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:deleted winsat\MOOBE key 2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' without error 2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{b4db0c88-1c6a-c5e8-f385-df67f3f1f575}; will try to launch 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' 2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'; executing it 2011-08-08 16:44:30, Warning TapiSysPrep.dll:RetainTapiLocations:RegQueryValueEx() returned 2 2011-08-08 16:44:30, Info TapiSysPrep.dll:RetainTapiLocations:returning 1 2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' without error 2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{e0053bef-049c-9ba1-e7db-793f9e538edd}; will try to launch 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' 2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'; executing it 2011-08-08 16:44:30, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user registry data found to delete 2011-08-08 16:44:30, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user profile files to delete 2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' without error 2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\2D153B43-11B4-461f-AA43-832B2C8B8872; will try to launch 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' 2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'; executing it 2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' without error 2011-08-08 16:44:30, Info [0x0f0040] SYSPRP WinMain:Processing 'generalize' internal provider request. 2011-08-08 16:44:30, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 1 2011-08-08 16:44:30, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Generalize 2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{67196725-a666-73a6-07bd-00f3276e41cf}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk' 2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk'; executing it 2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk' without error 2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{899480af-8f8b-16c1-58aa-df121c7314ed}; will try to launch 'C:\Windows\System32\reagent.dll,WinRE_Generalize' 2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\reagent.dll,WinRE_Generalize'; executing it 2011-08-08 16:44:30, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\reagent.dll,WinRE_Generalize' without error 2011-08-08 16:44:30, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8bc7dae9-655e-8ca5-d3d1-771286930ef6}; will try to launch 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging' 2011-08-08 16:44:30, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging'; executing it 2011-08-08 16:44:33, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging' without error 2011-08-08 16:44:33, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{1e7f4452-a4b4-5a32-5cc0-12a85b132913}; will try to launch 'sqmapi.dll,SqmSysprepGeneralize' 2011-08-08 16:44:33, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepGeneralize'; executing it 2011-08-08 16:44:33, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepGeneralize' without error 2011-08-08 16:44:33, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{d0c365cf-6d23-9db2-b74d-4e1efd035af7}; will try to launch 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp' 2011-08-08 16:44:33, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp'; executing it 2011-08-08 16:44:33, Info SYSPRP SPPNP: Sysprep_Generalize_Pnp: Enter 2011-08-08 16:44:33, Info SYSPRP SPPNP: Retrieving the list of function drivers from the critical device database (CDDB). 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver i8042prt was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Serial was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver pcmcia was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver isapnp was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver nvraid was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Parport was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver fdc was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver flpydisk was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver msisadrv was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver pci was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ACPI was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver WmiAcpi was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Wd was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ErrDev was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver sermouse was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver sbp2port was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver CmBatt was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver AcpiPmi was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver AmdPPM was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver AmdK8 was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver intelppm was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver IPMIDRV was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Processor was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vmbus was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver WacomPen was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver hcw85cir was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver BTHMODEM was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HidBth was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HidIr was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Compbatt was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver UmPass was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver cdrom was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver disk was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HidUsb was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbprint was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver sfloppy was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver kbdhid was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver mouhid was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver MTConfig was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HidBatt was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver atapi was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver BrSerWdm was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver BrUsbMdm was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver pciide was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver msahci was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HDAudBus was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ohci1394 was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbuhci was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbohci was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbehci was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver HpSAMD was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver LSI_SCSI was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver LSI_SAS was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver MegaSR was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver megasas was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver LSI_SAS2 was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver LSI_FC was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver amdsbs was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver amdsata was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver 1394ohci was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver nfrd960 was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver amdide was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver SiSRaid2 was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver SiSRaid4 was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver stexstor was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ql2300 was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ql40xx was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver cmdide was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver aliide was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver nvstor was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver elxstor was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver viaide was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vsmraid was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver iirsp was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver s3cap was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver b06bdrv was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver ebdrv was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vmci was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver intelide was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver iaStorV was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver adpahci was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver arc was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver arcsas was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver adp94xx was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver adpu320 was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver blbdrive was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver circlass was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver CompositeBus was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver iScsiPrt was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver mpio was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver msdsm was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver mssmbios was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver rdpbus was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver TermDD was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver swenum was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver umbus was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vdrvroot was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver volmgr was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver sffdisk was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver volsnap was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver USBSTOR was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbhub was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbccgp was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver usbcir was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver Brserid was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver storvsc was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver VMBusHID was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Driver vhdmp was retrieved from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Finished retrieving the list of function drivers from the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Enabling the function drivers listed in the critical device database (CDDB) ... 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service vhdmp was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service VMBusHID was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service storvsc was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver storvsc has been enabled. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service Brserid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbcir was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbccgp was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbhub was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service USBSTOR was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service volsnap is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service sffdisk was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service volmgr is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service vdrvroot is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service umbus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service swenum was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service TermDD is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service rdpbus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service mssmbios is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service msdsm was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver msdsm has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service mpio was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver mpio has been enabled. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service iScsiPrt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service CompositeBus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service circlass was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service blbdrive is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service adpu320 was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver adpu320 has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service adp94xx was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver adp94xx has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service arcsas was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver arcsas has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service arc was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver arc has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service adpahci was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver adpahci has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service iaStorV was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver iaStorV has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service intelide is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service vmci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service ebdrv was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service b06bdrv was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service s3cap was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service iirsp was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver iirsp has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service vsmraid was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver vsmraid has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service viaide was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver viaide has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service elxstor was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver elxstor has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service nvstor was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver nvstor has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service aliide was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver aliide has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service cmdide was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver cmdide has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service ql40xx was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver ql40xx has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service ql2300 was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver ql2300 has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service stexstor was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver stexstor has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service SiSRaid4 was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver SiSRaid4 has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service SiSRaid2 was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver SiSRaid2 has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service amdide was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver amdide has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service nfrd960 was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver nfrd960 has been enabled. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service 1394ohci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service amdsata was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver amdsata has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service amdsbs was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver amdsbs has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service LSI_FC was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver LSI_FC has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service LSI_SAS2 was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver LSI_SAS2 has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service megasas was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver megasas has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service MegaSR was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver MegaSR has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service LSI_SAS is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service LSI_SCSI was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver LSI_SCSI has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service HpSAMD was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver HpSAMD has been enabled. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbehci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbohci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbuhci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service ohci1394 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HDAudBus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service msahci was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver msahci has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service pciide was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver pciide has been enabled. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service BrUsbMdm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service BrSerWdm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service atapi is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HidBatt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service MTConfig was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service mouhid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service kbdhid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service sfloppy was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service usbprint was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HidUsb was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service disk is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service cdrom is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service UmPass was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service Compbatt is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HidIr was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service HidBth was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service BTHMODEM was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service hcw85cir was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service WacomPen was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service vmbus is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service Processor was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service IPMIDRV was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service intelppm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service AmdK8 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service AmdPPM was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service AcpiPmi was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service CmBatt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service sbp2port was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver sbp2port has been enabled. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service sermouse was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service ErrDev was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service Wd was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver Wd has been enabled. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service WmiAcpi was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service ACPI is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service pci is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service msisadrv is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service flpydisk was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service fdc was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service Parport was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service nvraid was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver nvraid has been enabled. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The original start type of service isapnp was 0. 2011-08-08 16:44:33, Info SYSPRP SPPNP: The driver isapnp has been enabled. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service pcmcia was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Service Serial is currently not disabled. Hence there is no need to re-enable it. 2011-08-08 16:44:33, Warning SYSPRP SPPNP: The original start type of service i8042prt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Finished enabling the function drivers listed in the CDDB. 2011-08-08 16:44:33, Info SYSPRP SPPNP: Uninstalling all existing devices <full generalize>. 2011-08-08 16:44:34, Info SYSPRP SPPNP: Uninstalling device SW\{EEAB7790-C514-11D1-B42B-00805FC1270E}\ASYNCMAC failed with 0x5. 2011-08-08 16:44:34, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_AGILEVPNMINIPORT\0000. 2011-08-08 16:44:35, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\*ISATAP\0000. 2011-08-08 16:44:35, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_L2TPMINIPORT\0000. 2011-08-08 16:44:35, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\*TEREDO\0000. 2011-08-08 16:44:35, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANBH\0000. 2011-08-08 16:44:35, Info SYSPRP SPPNP: Uninstalling device ROOT\ACPI_HAL\0000 failed with 0xE0000231. 2011-08-08 16:44:36, Info SYSPRP SPPNP: Uninstalling device ROOT\BLBDRIVE\0000 failed with 0xE0000231. 2011-08-08 16:44:36, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANIP\0000. 2011-08-08 16:44:36, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\COMPOSITEBUS\0000. 2011-08-08 16:44:36, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANIPV6\0000. 2011-08-08 16:44:36, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\COMPOSITE_BATTERY\0000. 2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_PPPOEMINIPORT\0000. 2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_PPTPMINIPORT\0000. 2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_SSTPMINIPORT\0000. 2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDPBUS\0000. 2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDP_KBD\0000. 2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDP_MOU\0000. 2011-08-08 16:44:37, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\SYSTEM\0000. 2011-08-08 16:44:38, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\UMBUS\0000. 2011-08-08 16:44:38, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\VMWARE\0000. 2011-08-08 16:44:38, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\VMWARE\0001. 2011-08-08 16:44:38, Info SYSPRP SPPNP: Uninstalling device ROOT\VOLMGR\0000 failed with 0xE0000231. 2011-08-08 16:46:05, Info SYSPRP SPPNP: Reflected all boot critical driver packages (87094 ms). 2011-08-08 16:46:05, Error SYSPRP SPPNP: Error 0x2 setting SDDL on driver file C:\Windows\system32\drivers\vmaudio.sys! 2011-08-08 16:46:05, Error SYSPRP SPPNP: Error 0x2 setting SDDL on driver file C:\Windows\system32\DRIVERS\vmci.sys! 2011-08-08 16:46:06, Info SYSPRP SPPNP: Sysprep_Generalize_Pnp: Exit 2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp' without error 2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{960b724d-0479-6dd8-0470-6c42dc9b8f85}; will try to launch 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize' 2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize'; executing it 2011-08-08 16:46:06, Info SYSPRP iphlpsvc.dll: sysprep generalize called 2011-08-08 16:46:06, Info SYSPRP Found interface in scavenger. 2011-08-08 16:46:06, Info SYSPRP Successfully uninstalled interface in scavenger 2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize' without error 2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{243bb634-be68-0139-f4c8-f1c87dade9d7}; will try to launch 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup' 2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup'; executing it 2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup' without error 2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{df593d24-f963-8be2-86d6-c722da22bf5b}; will try to launch 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize' 2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize'; executing it 2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize' without error 2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{03513543-c453-2e4f-5ee6-b970cace3cd8}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell' 2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell'; executing it 2011-08-08 16:46:06, Info [shsetup] Sysprep_Generalize_Shell entered 2011-08-08 16:46:06, Info [shsetup] Sysprep_Generalize_Shell exit 2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell' without error 2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{1f954290-a3bd-7c6b-2062-3fd9d1266740}; will try to launch 'wer.dll,WerSysprepGeneralize' 2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepGeneralize'; executing it 2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepGeneralize' without error 2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{4840d621-1b47-334f-b1a6-321233838362}; will try to launch 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize' 2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize'; executing it 2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize' without error 2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{67011352-10f6-73b5-85e9-6064e10071b9}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net' 2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net'; executing it 2011-08-08 16:46:06, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain 2011-08-08 16:46:06, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do 2011-08-08 16:46:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net' without error 2011-08-08 16:46:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{3aa3f98d-491f-7656-533f-7db889fff253}; will try to launch 'C:\Windows\System32\slc.dll,SLReArmWindows' 2011-08-08 16:46:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\slc.dll,SLReArmWindows'; executing it 2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\slc.dll,SLReArmWindows' without error 2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{d9d03ab7-c7a6-4587-c28d-ccc47a787790}; will try to launch 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize' 2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize'; executing it 2011-08-08 16:46:08, Info capisp.dll::CAPISysPrep_Generalize: returning 0 2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize' without error 2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{6a6b0fac-5606-6e68-410d-e7bf974f5136}; will try to launch 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd' 2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd'; executing it 2011-08-08 16:46:08, Info TOOL Sysprep_Generalize_Bcd: Located BCD store on system drive. Generalizing it... 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Found the memory tester object. 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Found the Windows OS Loader object {d54562fb-41e1-11e0-9007-94b295923b48} for the currently running OS. 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Found the resume object {d54562fa-41e1-11e0-9007-94b295923b48} for the OS loader. 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: System drive backed by VHD = 0 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Generalizing object {9dea862c-5cdd-4e70-acc1-f32b344d4795} 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0] 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Generalizing object {b2721d73-1db4-4c62-bf78-c548a880142d} 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0] 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Generalizing object {d54562fb-41e1-11e0-9007-94b295923b48} 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0] 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized OS device. Status = [0x0] 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Generalizing object {d54562fa-41e1-11e0-9007-94b295923b48} 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0] 2011-08-08 16:46:08, Info TOOL GeneralizeBcdStore: Successfully generalized hiberfile device. Status = [0x0] 2011-08-08 16:46:08, Info TOOL Sysprep_Generalize_Bcd: Successfully generalized the bcd store. Status=[0x0] 2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd' without error 2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8fd6ce7c-4301-d490-719b-d787d2bde1cd}; will try to launch 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize' 2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize'; executing it 2011-08-08 16:46:08, Info SYSPRP nlmsprep.dll: Generalize start 2011-08-08 16:46:08, Info SYSPRP nlmsprep.dll: Generalize finish 2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize' without error 2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{79b40229-f48c-7547-1eb2-96b7091aa28f}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize' 2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize'; executing it 2011-08-08 16:46:08, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize' without error 2011-08-08 16:46:08, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8dde3abb-19cb-88f8-4e07-05c697cc2872}; will try to launch 'RacEngn.dll,RacSysprepGeneralize' 2011-08-08 16:46:08, Info [0x0f0080] SYSPRP LaunchDll:Found 'RacEngn.dll,RacSysprepGeneralize'; executing it 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'RacEngn.dll,RacSysprepGeneralize' without error 2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{20b6ca3b-166d-4e8d-af73-72df2987e480}; will try to launch 'msmmsp.dll,MountMgr_Generalize' 2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'msmmsp.dll,MountMgr_Generalize'; executing it 2011-08-08 16:46:09, Info msmmsp::MountMgr_Generalize ENTER 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'msmmsp.dll,MountMgr_Generalize' without error 2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{4aaf8557-52af-9241-469e-acbb347c3c07}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE' 2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE'; executing it 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE' without error 2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{71e01f6c-a271-b3b1-05f0-8c48a330cb4c}; will try to launch 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize' 2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize'; executing it 2011-08-08 16:46:09, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastFullScanID does not exist, skipping action. 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize' without error 2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{ccf004d0-c18e-a2d4-ee22-e585dac90889}; will try to launch 'srcore.dll,SysprepGeneralize' 2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepGeneralize'; executing it 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepGeneralize' without error 2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{68cac03c-b4c6-675e-1b30-cf21359228e2}; will try to launch 'spwmp.dll,Sysprep_Generalize_WMP' 2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'spwmp.dll,Sysprep_Generalize_WMP'; executing it 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'spwmp.dll,Sysprep_Generalize_WMP' without error 2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{b636fa27-124f-6436-6a6f-2fe2739a2b89}; will try to launch 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize' 2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize'; executing it 2011-08-08 16:46:09, Info SYSPRP WindowsSideShow: Enabling SystemDataProviders task returned 0x00000000 2011-08-08 16:46:09, Info SYSPRP WindowsSideShow: Enabling SessionAgent task returned 0x00000000 2011-08-08 16:46:09, Info SYSPRP WindowsSideShow: Enabling GadgetManager task returned 0x00000000 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize' without error 2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8a2650e9-70de-392f-5b09-34c3ac14764d}; will try to launch 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE' 2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE'; executing it 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE' without error 2011-08-08 16:46:09, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{cb71e18d-7833-6f0f-2d00-e35ade2ecb27}; will try to launch 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize' 2011-08-08 16:46:09, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize'; executing it 2011-08-08 16:46:09, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize' without error 2011-08-08 16:46:09, Info [0x0f004c] SYSPRP WaitThread:Exiting spawned waiting thread 2011-08-08 16:46:09, Info [0x0f007a] SYSPRP FCreateTagFile:Successfully created tag file C:\Windows\System32\Sysprep\Sysprep_succeeded.tag 2011-08-08 16:46:09, Info [0x0f0052] SYSPRP Shutting down SysPrep log 2011-08-08 16:46:09, Info [0x0f004d] SYSPRP The time is now 2011-08-08 16:46:09 2011-08-19 17:18:08, Info SYSPRP ======================================================== 2011-08-19 17:18:08, Info SYSPRP === Beginning of a new sysprep run === 2011-08-19 17:18:08, Info SYSPRP ======================================================== 2011-08-19 17:18:08, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:18:08 2011-08-19 17:18:08, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\System32\sysprep\Panther 2011-08-19 17:18:08, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine 2011-08-19 17:18:08, Info [0x0f007e] SYSPRP FCreateTagFile:Tag file C:\Windows\System32\sysprep\Sysprep_succeeded.tag does not already exist, no need to delete anything 2011-08-19 17:18:10, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'AUDIT' 2011-08-19 17:18:10, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'REBOOT' 2011-08-19 17:18:10, Info [0x0f004a] SYSPRP WaitThread:Entering spawned waiting thread 2011-08-19 17:18:10, Info [sysprep.exe] UnattendSearchExplicitPath: Found unattend file at [C:\Windows\Panther\unattend.xml]; examining for applicability. 2011-08-19 17:18:10, Info [sysprep.exe] UnattendSearchExplicitPath: [C:\Windows\Panther\unattend.xml] does not meet criteria to be used for this unattend pass. 2011-08-19 17:18:11, Info SYSPRP SysprepSearchForUnattend: No unattend file was specified or located; skipping unattend generalize pass. 2011-08-19 17:18:11, Info [0x0f00ac] SYSPRP WinMain:Processing 'cleanup' external provider request. 2011-08-19 17:18:11, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3 2011-08-19 17:18:11, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup 2011-08-19 17:18:11, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Cleanup 2011-08-19 17:18:11, Info [0x0f003f] SYSPRP WinMain:Processing 'cleanup' internal provider request. 2011-08-19 17:18:11, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3 2011-08-19 17:18:11, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup 2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67196725-a666-73a6-a048-412e48a3b856}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' 2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'; executing it 2011-08-19 17:18:11, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' without error 2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1e7f4452-a4b4-5a32-d01e-70397b096ced}; will try to launch 'sqmapi.dll,SqmSysprepCleanup' 2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepCleanup'; executing it 2011-08-19 17:18:11, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepCleanup' without error 2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{2c8a362b-4dc1-38b9-c4d8-ce732ddcc48e}; will try to launch 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' 2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'; executing it 2011-08-19 17:18:11, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' without error 2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{86297dc3-52b0-7d4e-f9a8-572bb66ac5ae}; will try to launch 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' 2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'; executing it 2011-08-19 17:18:11, Info SYSPRP Sysprep_Generalize_MUILangCleanup Start. 2011-08-19 17:18:11, Info SYSPRP Disabling CMF cache SUCCEEDED 2011-08-19 17:18:11, Info SYSPRP Removing scheduled task for running lpremove.exe and all related data 2011-08-19 17:18:11, Info SYSPRP Removing scheduled task for lpremove.exe succeeed 2011-08-19 17:18:11, Info SYSPRP Removing MUIUnattend-OOBE handshake value 2011-08-19 17:18:11, Info SYSPRP MUIUnattend-OOBE handshake value is present on the system 2011-08-19 17:18:11, Info SYSPRP Succeeded removing MUIUnattend-OOBE handshake value 2011-08-19 17:18:11, Info SYSPRP Sysprep_Generalize_MUILangCleanup End. 2011-08-19 17:18:11, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' without error 2011-08-19 17:18:11, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{03513543-c453-2e4f-3200-c2f12d89732a}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' 2011-08-19 17:18:11, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'; executing it 2011-08-19 17:18:11, Info [shsetup] Sysprep_Cleanup_Shell entered 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipMachineOOBE' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipUserOOBE' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'HideEULAPage' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'NetworkLocation' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'ProtectYourPC' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'MediaBootInstall' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedProductKey' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedEula' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedLanguageSelection' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupSQMOptIn' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendCreatedUser' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetTimeZone' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetAutologon' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'AutoAdminLogon' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultUserName' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultDomainName' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'SOFTWARE\Policies\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\FirstNetwork' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'HideWizard' returned 2 2011-08-19 17:18:11, Info [shsetup] Deleting temp files for 'S-1-5-18' 2011-08-19 17:18:11, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent' (0x80070002) 2011-08-19 17:18:11, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Local\Temp' (0x80070002) 2011-08-19 17:18:11, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff 2011-08-19 17:18:11, Info [shsetup] Cleaning up user hive for 'S-1-5-19' 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-19 17:18:11, Info [shsetup] Deleting temp files for 'S-1-5-19' 2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Local\Temp' 2011-08-19 17:18:11, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff 2011-08-19 17:18:11, Info [shsetup] Cleaning up user hive for 'S-1-5-20' 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-19 17:18:11, Info [shsetup] Deleting temp files for 'S-1-5-20' 2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp' 2011-08-19 17:18:11, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000 2011-08-19 17:18:11, Info [shsetup] Cleaning up user hive for 'S-1-5-21-3007790038-290154040-4075851062-500' 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 0 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-19 17:18:11, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-19 17:18:11, Info [shsetup] Deleting temp files for 'S-1-5-21-3007790038-290154040-4075851062-500' 2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-19 17:18:11, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Local\Temp' 2011-08-19 17:18:11, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000 2011-08-19 17:18:11, Info [shsetup] SanitizeDeskBands entered 2011-08-19 17:18:11, Info [shsetup] SanitizeDeskBands exit 2011-08-19 17:18:11, Info [shsetup] PrimeStartMenuShortcuts entered 2011-08-19 17:18:25, Info [shsetup] PrimeStartMenuShortcuts exit 2011-08-19 17:18:25, Info [shsetup] Sysprep_Cleanup_Shell exit 2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' without error 2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1f954290-a3bd-7c6b-ac99-fda4b6fe1603}; will try to launch 'wer.dll,WerSysprepCleanup' 2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepCleanup'; executing it 2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepCleanup' without error 2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67011352-10f6-73b5-0c1b-833a374ea884}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' 2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'; executing it 2011-08-19 17:18:25, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain 2011-08-19 17:18:25, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do 2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' without error 2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{d9d03ab7-c7a6-4587-1dcd-fb0609f92d84}; will try to launch 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' 2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'; executing it 2011-08-19 17:18:25, Info capisp.dll::DisableAdministratorIfApplicable disabled the admin account. 2011-08-19 17:18:25, Info capisp.dll::CryptoSysPrep_Clean: returning 0 2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' without error 2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{79b40229-f48c-7547-16d3-ec814bdc5adc}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' 2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'; executing it 2011-08-19 17:18:25, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' without error 2011-08-19 17:18:25, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{352676dd-145f-cf4f-feb3-aa882aa02408}; will try to launch 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' 2011-08-19 17:18:25, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'; executing it 2011-08-19 17:18:25, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _DisableService returned successfully. 2011-08-19 17:18:25, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _CreateBlockingRegKey returned successfully. 2011-08-19 17:18:25, Info SYSPRP MSS: _StopService status checking loop 0 round, QueryServiceStatus return TRUE, the status is 0x3 2011-08-19 17:18:26, Info SYSPRP MSS: _StopService status checking loop 1 round, QueryServiceStatus return TRUE, the status is 0x1 2011-08-19 17:18:27, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' without error 2011-08-19 17:18:27, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{f9e8597e-e3f1-9942-5fbc-2ce1ce25c0e2}; will try to launch 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' 2011-08-19 17:18:27, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'; executing it 2011-08-19 17:18:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' without error 2011-08-19 17:18:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{4aaf8557-52af-9241-b6bc-e36d2d203cef}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' 2011-08-19 17:18:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'; executing it 2011-08-19 17:18:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' without error 2011-08-19 17:18:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{ccf004d0-c18e-a2d4-b4ea-08ccb5259f11}; will try to launch 'srcore.dll,SysprepCleanup' 2011-08-19 17:18:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepCleanup'; executing it 2011-08-19 17:18:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepCleanup' without error 2011-08-19 17:18:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{de7df4f0-0ce9-ca23-6049-1807de6941d3}; will try to launch 'drmv2clt.dll,Sysprep' 2011-08-19 17:18:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'drmv2clt.dll,Sysprep'; executing it 2011-08-19 17:18:28, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'drmv2clt.dll,Sysprep' without error 2011-08-19 17:18:28, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{9733bd0b-72a8-af29-76ba-be8ae2c8be6f}; will try to launch 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' 2011-08-19 17:18:28, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'; executing it 2011-08-19 17:18:28, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:MOOBE==MOOBE_RUNNING_STATE_ALREADY_RAN 2011-08-19 17:18:28, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:found winsatapi\LastFormalAssessment key 2011-08-19 17:18:28, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:deleted winsat\MOOBE key 2011-08-19 17:18:28, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:Unable to get a handle from FindFirstFile 2011-08-19 17:18:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' without error 2011-08-19 17:18:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{b4db0c88-1c6a-c5e8-f385-df67f3f1f575}; will try to launch 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' 2011-08-19 17:18:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'; executing it 2011-08-19 17:18:29, Warning TapiSysPrep.dll:RetainTapiLocations:RegQueryValueEx() returned 2 2011-08-19 17:18:29, Info TapiSysPrep.dll:RetainTapiLocations:returning 1 2011-08-19 17:18:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' without error 2011-08-19 17:18:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{e0053bef-049c-9ba1-e7db-793f9e538edd}; will try to launch 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' 2011-08-19 17:18:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'; executing it 2011-08-19 17:18:29, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user registry data found to delete 2011-08-19 17:18:29, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user profile files to delete 2011-08-19 17:18:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' without error 2011-08-19 17:18:29, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\2D153B43-11B4-461f-AA43-832B2C8B8872; will try to launch 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' 2011-08-19 17:18:29, Info [0x0f0080] SYSPRP LaunchDll:Found 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'; executing it 2011-08-19 17:18:29, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' without error 2011-08-19 17:18:29, Info [0x0f004c] SYSPRP WaitThread:Exiting spawned waiting thread 2011-08-19 17:18:29, Info [0x0f007a] SYSPRP FCreateTagFile:Successfully created tag file C:\Windows\System32\sysprep\Sysprep_succeeded.tag 2011-08-19 17:18:29, Info [0x0f0041] SYSPRP WinMain:Processing system shutdown request. 2011-08-19 17:18:29, Info [0x0f0074] SYSPRP ProcessShutdown:Successfully enabled the shutdown privilege 2011-08-19 17:18:29, Info [0x0f0076] SYSPRP ProcessShutdown:Successfully called InitiateSystemShutdownEx to reboot the computer 2011-08-19 17:18:29, Info [0x0f0052] SYSPRP Shutting down SysPrep log 2011-08-19 17:18:29, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:18:29 2011-08-19 17:20:30, Info SYSPRP ======================================================== 2011-08-19 17:20:30, Info SYSPRP === Beginning of a new sysprep run === 2011-08-19 17:20:30, Info SYSPRP ======================================================== 2011-08-19 17:20:30, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:20:30 2011-08-19 17:20:30, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\system32\sysprep\Panther 2011-08-19 17:20:30, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine 2011-08-19 17:20:30, Info [0x0f007c] SYSPRP FCreateTagFile:Successfully deleted tag file C:\Windows\system32\sysprep\Sysprep_succeeded.tag 2011-08-19 17:20:31, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'REBOOT' 2011-08-19 17:20:31, Info [0x0f003d] SYSPRP WinMain:Displaying dialog box for user to choose sysprep mode... 2011-08-19 17:20:39, Error [0x0f0043] SYSPRP WinMain:The sysprep dialog box returned FALSE 2011-08-19 17:20:39, Info [0x0f0052] SYSPRP Shutting down SysPrep log 2011-08-19 17:20:39, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:20:39 2011-08-19 17:24:43, Info SYSPRP ======================================================== 2011-08-19 17:24:43, Info SYSPRP === Beginning of a new sysprep run === 2011-08-19 17:24:43, Info SYSPRP ======================================================== 2011-08-19 17:24:43, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:24:43 2011-08-19 17:24:43, Info [0x0f004e] SYSPRP Initialized SysPrep log at C:\Windows\System32\Sysprep\Panther 2011-08-19 17:24:43, Info [0x0f0054] SYSPRP ValidateUser:User has required privileges to sysprep machine 2011-08-19 17:24:43, Info [0x0f007e] SYSPRP FCreateTagFile:Tag file C:\Windows\System32\Sysprep\Sysprep_succeeded.tag does not already exist, no need to delete anything 2011-08-19 17:24:43, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'GENERALIZE' 2011-08-19 17:24:43, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'OOBE' 2011-08-19 17:24:43, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'QUIT' 2011-08-19 17:24:43, Info [0x0f005f] SYSPRP ParseCommands:Found supported command line option 'UNATTEND' 2011-08-19 17:24:43, Info [0x0f004a] SYSPRP WaitThread:Entering spawned waiting thread 2011-08-19 17:24:43, Info [sysprep.exe] UnattendFindAnswerFile: Looking at explicitly provided unattend file [C:\Windows\System32\Sysprep\sysprep64.xml]... 2011-08-19 17:24:43, Info [sysprep.exe] UnattendFindAnswerFile: [C:\Windows\System32\Sysprep\sysprep64.xml] meets criteria for an explicitly provided unattend file. 2011-08-19 17:24:43, Info SYSPRP SysprepSearchForUnattend: Using unattend file at [C:\Windows\System32\Sysprep\sysprep64.xml]. 2011-08-19 17:24:43, Info SYSPRP SysprepSearchForUnattend: [generalize] pass in unattend file [C:\Windows\System32\Sysprep\sysprep64.xml] either doesn't exist or passed validation 2011-08-19 17:24:43, Info SYSPRP WinMain:Found unattend file at [C:\Windows\System32\Sysprep\sysprep64.xml]; caching... 2011-08-19 17:24:43, Info SYSPRP WinMain:Processing unattend file's 'generalize' pass... 2011-08-19 17:24:43, Info SYSPRP Sysprep is running a generalize pass with the following unattend file: [%windir%\panther\unattend.xml] 2011-08-19 17:24:43, Info SYSPRP RunUnattendGeneralizePass: Sysprep unattend generalize pass exits; hr = 0x0, hrResult = 0x0, bRebootRequired = 0x0 2011-08-19 17:24:43, Info [0x0f00ac] SYSPRP WinMain:Processing 'cleanup' external provider request. 2011-08-19 17:24:43, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3 2011-08-19 17:24:43, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup 2011-08-19 17:24:43, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Cleanup 2011-08-19 17:24:43, Info [0x0f00ad] SYSPRP WinMain:Processing 'generalize' extrenal provider request. 2011-08-19 17:24:43, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 1 2011-08-19 17:24:43, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Generalize 2011-08-19 17:24:43, Warning [0x0f008f] SYSPRP RunRegistryDlls:Registry key is either empty or malformed: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrepExternal\Generalize 2011-08-19 17:24:43, Info [0x0f003f] SYSPRP WinMain:Processing 'cleanup' internal provider request. 2011-08-19 17:24:43, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 3 2011-08-19 17:24:43, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Cleanup 2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67196725-a666-73a6-a048-412e48a3b856}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' 2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk'; executing it 2011-08-19 17:24:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Clean_Opk' without error 2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1e7f4452-a4b4-5a32-d01e-70397b096ced}; will try to launch 'sqmapi.dll,SqmSysprepCleanup' 2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepCleanup'; executing it 2011-08-19 17:24:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepCleanup' without error 2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{2c8a362b-4dc1-38b9-c4d8-ce732ddcc48e}; will try to launch 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' 2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup'; executing it 2011-08-19 17:24:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wevtapi.dll,EvtIntSysprepCleanup' without error 2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{86297dc3-52b0-7d4e-f9a8-572bb66ac5ae}; will try to launch 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' 2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup'; executing it 2011-08-19 17:24:43, Info SYSPRP Sysprep_Generalize_MUILangCleanup Start. 2011-08-19 17:24:43, Info SYSPRP Disabling CMF cache SUCCEEDED 2011-08-19 17:24:43, Info SYSPRP Removing scheduled task for running lpremove.exe and all related data 2011-08-19 17:24:43, Info SYSPRP Removing scheduled task for lpremove.exe succeeed 2011-08-19 17:24:43, Info SYSPRP Removing MUIUnattend-OOBE handshake value 2011-08-19 17:24:43, Info SYSPRP MUIUnattend-OOBE handshake value is not present on the system 2011-08-19 17:24:43, Info SYSPRP Sysprep_Generalize_MUILangCleanup End. 2011-08-19 17:24:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\LangCleanupSysprepAction.dll,Sysprep_Generalize_MUILangCleanup' without error 2011-08-19 17:24:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{03513543-c453-2e4f-3200-c2f12d89732a}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' 2011-08-19 17:24:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell'; executing it 2011-08-19 17:24:43, Info [shsetup] Sysprep_Cleanup_Shell entered 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipMachineOOBE' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'SkipUserOOBE' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'HideEULAPage' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'NetworkLocation' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\OOBE' + 'ProtectYourPC' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'MediaBootInstall' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedProductKey' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedEula' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupDisplayedLanguageSelection' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'SetupSQMOptIn' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendCreatedUser' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetTimeZone' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Setup\OOBE' + 'UnattendSetAutologon' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'AutoAdminLogon' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultUserName' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows NT\CurrentVersion\WinLogon' + 'DefaultDomainName' returned 0 2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'SOFTWARE\Policies\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\FirstNetwork' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'HideWizard' returned 2 2011-08-19 17:24:43, Info [shsetup] Deleting temp files for 'S-1-5-18' 2011-08-19 17:24:43, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent' (0x80070002) 2011-08-19 17:24:43, Info [shsetup] SHCreateItemFromParsingName failed on 'C:\Windows\system32\config\systemprofile\AppData\Local\Temp' (0x80070002) 2011-08-19 17:24:43, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff 2011-08-19 17:24:43, Info [shsetup] Cleaning up user hive for 'S-1-5-19' 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-19 17:24:43, Info [shsetup] Deleting temp files for 'S-1-5-19' 2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\LocalService\AppData\Local\Temp' 2011-08-19 17:24:43, Info [shsetup] IFileOperation::PerformOperations returned 0x8000ffff 2011-08-19 17:24:43, Info [shsetup] Cleaning up user hive for 'S-1-5-20' 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-19 17:24:43, Info [shsetup] Deleting temp files for 'S-1-5-20' 2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp' 2011-08-19 17:24:43, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000 2011-08-19 17:24:43, Info [shsetup] Cleaning up user hive for 'S-1-5-21-3007790038-290154040-4075851062-500' 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer' + 'ExplorerStartupTraceRecorded' returned 0 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'System\CurrentControlSet\Control\Network\NetworkLocationWizard' + 'ShowCount' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteKey on 'Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU' returned 0 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced' + 'StartMenuInit' returned 0 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'Favorites' returned 0 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesChanges' returned 0 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesVersion' returned 0 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband' + 'FavoritesResolve' returned 0 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'Favorites' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesChanges' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesVersion' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage' + 'FavoritesResolve' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\VisualEffects\Fontsmoothing' + 'DefaultApplied' returned 2 2011-08-19 17:24:43, Info [shsetup] SHDeleteValue on 'Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz' + 'Last used time' returned 2 2011-08-19 17:24:43, Info [shsetup] Deleting temp files for 'S-1-5-21-3007790038-290154040-4075851062-500' 2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent' 2011-08-19 17:24:43, Info [shsetup] Deleting contents of 'C:\Users\Administrator\AppData\Local\Temp' 2011-08-19 17:24:43, Info [shsetup] IFileOperation::PerformOperations returned 0x00000000 2011-08-19 17:24:43, Info [shsetup] SanitizeDeskBands entered 2011-08-19 17:24:43, Info [shsetup] SanitizeDeskBands exit 2011-08-19 17:24:43, Info [shsetup] PrimeStartMenuShortcuts entered 2011-08-19 17:24:58, Info [shsetup] PrimeStartMenuShortcuts exit 2011-08-19 17:24:58, Info [shsetup] Sysprep_Cleanup_Shell exit 2011-08-19 17:24:58, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Cleanup_Shell' without error 2011-08-19 17:24:58, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{1f954290-a3bd-7c6b-ac99-fda4b6fe1603}; will try to launch 'wer.dll,WerSysprepCleanup' 2011-08-19 17:24:58, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepCleanup'; executing it 2011-08-19 17:24:58, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepCleanup' without error 2011-08-19 17:24:58, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{67011352-10f6-73b5-0c1b-833a374ea884}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' 2011-08-19 17:24:58, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net'; executing it 2011-08-19 17:24:58, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain 2011-08-19 17:24:58, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do 2011-08-19 17:24:58, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Clean_Net' without error 2011-08-19 17:24:58, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{d9d03ab7-c7a6-4587-1dcd-fb0609f92d84}; will try to launch 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' 2011-08-19 17:24:58, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean'; executing it 2011-08-19 17:24:58, Info capisp.dll::DisableAdministratorIfApplicable disabled the admin account. 2011-08-19 17:24:58, Info capisp.dll::CryptoSysPrep_Clean: returning 0 2011-08-19 17:24:58, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CryptoSysPrep_Clean' without error 2011-08-19 17:24:58, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{79b40229-f48c-7547-16d3-ec814bdc5adc}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' 2011-08-19 17:24:58, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup'; executing it 2011-08-19 17:24:59, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcCleanup' without error 2011-08-19 17:24:59, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{352676dd-145f-cf4f-feb3-aa882aa02408}; will try to launch 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' 2011-08-19 17:24:59, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup'; executing it 2011-08-19 17:24:59, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _DisableService returned successfully. 2011-08-19 17:24:59, Info SYSPRP MSS: MSSrch_SysPrep_Cleanup _CreateBlockingRegKey returned successfully. 2011-08-19 17:24:59, Info SYSPRP MSS: _StopService status checking loop 0 round, QueryServiceStatus return TRUE, the status is 0x3 2011-08-19 17:25:00, Info SYSPRP MSS: _StopService status checking loop 1 round, QueryServiceStatus return TRUE, the status is 0x3 2011-08-19 17:25:01, Info SYSPRP MSS: _StopService status checking loop 2 round, QueryServiceStatus return TRUE, the status is 0x3 2011-08-19 17:25:02, Info SYSPRP MSS: _StopService status checking loop 3 round, QueryServiceStatus return TRUE, the status is 0x1 2011-08-19 17:25:02, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\mssrch.dll,MSSrch_SysPrep_Cleanup' without error 2011-08-19 17:25:02, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{f9e8597e-e3f1-9942-5fbc-2ce1ce25c0e2}; will try to launch 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' 2011-08-19 17:25:02, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup'; executing it 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysmain.dll,PfSvSysprepCleanup' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{4aaf8557-52af-9241-b6bc-e36d2d203cef}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE'; executing it 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Cleanup_IE' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{ccf004d0-c18e-a2d4-b4ea-08ccb5259f11}; will try to launch 'srcore.dll,SysprepCleanup' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepCleanup'; executing it 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepCleanup' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{de7df4f0-0ce9-ca23-6049-1807de6941d3}; will try to launch 'drmv2clt.dll,Sysprep' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'drmv2clt.dll,Sysprep'; executing it 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'drmv2clt.dll,Sysprep' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{9733bd0b-72a8-af29-76ba-be8ae2c8be6f}; will try to launch 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT'; executing it 2011-08-19 17:25:03, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:Unable to get a handle from FindFirstFile 2011-08-19 17:25:03, Info SYSPRP spwinsat.dll::Sysprep_Clean_WinSAT:Unable to get a handle from FindFirstFile 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spwinsat.dll,Sysprep_Clean_WinSAT' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{b4db0c88-1c6a-c5e8-f385-df67f3f1f575}; will try to launch 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\tapisysprep,TapiSysPrepClean'; executing it 2011-08-19 17:25:03, Warning TapiSysPrep.dll:RetainTapiLocations:RegQueryValueEx() returned 2 2011-08-19 17:25:03, Info TapiSysPrep.dll:RetainTapiLocations:returning 1 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\tapisysprep,TapiSysPrepClean' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\{e0053bef-049c-9ba1-e7db-793f9e538edd}; will try to launch 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS'; executing it 2011-08-19 17:25:03, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user registry data found to delete 2011-08-19 17:25:03, Info SYSPRP Sysprep_Cleanup_IPS: No IPS user profile files to delete 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Program Files\Common Files\Microsoft Shared\Ink\IpsMigrationPlugin.dll,Sysprep_Cleanup_IPS' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Cleanup\2D153B43-11B4-461f-AA43-832B2C8B8872; will try to launch 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup'; executing it 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'c:\Program Files\Microsoft Security Client\MSESysprep.dll,DllSysprep_Cleanup' without error 2011-08-19 17:25:03, Info [0x0f0040] SYSPRP WinMain:Processing 'generalize' internal provider request. 2011-08-19 17:25:03, Info [0x0f006c] SYSPRP RunExternalDlls:Running DLLs listed in registry for phase 1 2011-08-19 17:25:03, Info [0x0f008a] SYSPRP RunRegistryDlls:Retrieved section name for this phase as Generalize 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{67196725-a666-73a6-07bd-00f3276e41cf}; will try to launch 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk'; executing it 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spopk.dll,Sysprep_Generalize_Opk' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{899480af-8f8b-16c1-58aa-df121c7314ed}; will try to launch 'C:\Windows\System32\reagent.dll,WinRE_Generalize' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\reagent.dll,WinRE_Generalize'; executing it 2011-08-19 17:25:03, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\reagent.dll,WinRE_Generalize' without error 2011-08-19 17:25:03, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8bc7dae9-655e-8ca5-d3d1-771286930ef6}; will try to launch 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging' 2011-08-19 17:25:03, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging'; executing it 2011-08-19 17:25:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\wuaueng.dll,GeneralizeForImaging' without error 2011-08-19 17:25:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{1e7f4452-a4b4-5a32-5cc0-12a85b132913}; will try to launch 'sqmapi.dll,SqmSysprepGeneralize' 2011-08-19 17:25:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'sqmapi.dll,SqmSysprepGeneralize'; executing it 2011-08-19 17:25:06, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'sqmapi.dll,SqmSysprepGeneralize' without error 2011-08-19 17:25:06, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{d0c365cf-6d23-9db2-b74d-4e1efd035af7}; will try to launch 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp' 2011-08-19 17:25:06, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp'; executing it 2011-08-19 17:25:06, Info SYSPRP SPPNP: Sysprep_Generalize_Pnp: Enter 2011-08-19 17:25:06, Info SYSPRP SPPNP: Retrieving the list of function drivers from the critical device database (CDDB). 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver i8042prt was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Serial was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver pcmcia was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver isapnp was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver nvraid was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Parport was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver fdc was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver flpydisk was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver msisadrv was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver pci was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ACPI was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver WmiAcpi was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Wd was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ErrDev was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver sermouse was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver sbp2port was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver CmBatt was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver AcpiPmi was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver AmdPPM was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver AmdK8 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver intelppm was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver IPMIDRV was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Processor was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vmbus was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver WacomPen was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver hcw85cir was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver BTHMODEM was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HidBth was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HidIr was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Compbatt was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver UmPass was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver cdrom was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver disk was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HidUsb was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbprint was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver sfloppy was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver kbdhid was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver mouhid was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver MTConfig was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HidBatt was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver atapi was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver BrSerWdm was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver BrUsbMdm was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver pciide was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver msahci was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HDAudBus was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ohci1394 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbuhci was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbohci was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbehci was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver HpSAMD was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver LSI_SCSI was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver LSI_SAS was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver MegaSR was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver megasas was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver LSI_SAS2 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver LSI_FC was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver amdsbs was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver amdsata was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver 1394ohci was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver nfrd960 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver amdide was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver SiSRaid2 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver SiSRaid4 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver stexstor was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ql2300 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ql40xx was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver cmdide was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver aliide was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver nvstor was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver elxstor was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver viaide was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vsmraid was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver iirsp was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver s3cap was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver b06bdrv was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver ebdrv was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vmci was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver pvscsi was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver intelide was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver iaStorV was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver adpahci was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver arc was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver arcsas was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver adp94xx was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver adpu320 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver blbdrive was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver circlass was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver CompositeBus was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver iScsiPrt was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver mpio was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver msdsm was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver mssmbios was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver rdpbus was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver TermDD was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver swenum was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver tsusbhub was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver umbus was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vdrvroot was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver volmgr was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver sffdisk was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver volsnap was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver terminpt was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver USBSTOR was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbhub was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbccgp was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver TsUsbGD was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver usbcir was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Brserid was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver USBAAPL64 was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vmusb was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver dmvsc was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver Synth3dVsc was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver storvsc was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver VMBusHID was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Driver vhdmp was retrieved from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Finished retrieving the list of function drivers from the CDDB. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Enabling the function drivers listed in the critical device database (CDDB) ... 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service vhdmp was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service VMBusHID was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service storvsc was 0. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver storvsc has been enabled. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service Synth3dVsc was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service dmvsc was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service vmusb was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service USBAAPL64 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service Brserid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service usbcir was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service TsUsbGD was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service usbccgp was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service usbhub was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service USBSTOR was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service terminpt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Service volsnap is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service sffdisk was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Service volmgr is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Service vdrvroot is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service umbus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service tsusbhub was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service swenum was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Service TermDD is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service rdpbus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Service mssmbios is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service msdsm was 0. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver msdsm has been enabled. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service mpio was 0. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver mpio has been enabled. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service iScsiPrt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service CompositeBus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Warning SYSPRP SPPNP: The original start type of service circlass was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:06, Info SYSPRP SPPNP: Service blbdrive is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service adpu320 was 0. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver adpu320 has been enabled. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service adp94xx was 0. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The driver adp94xx has been enabled. 2011-08-19 17:25:06, Info SYSPRP SPPNP: The original start type of service arcsas was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver arcsas has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service arc was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver arc has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service adpahci was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver adpahci has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service iaStorV was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver iaStorV has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service intelide is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service pvscsi was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver pvscsi has been enabled. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service vmci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service ebdrv was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service b06bdrv was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service s3cap was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service iirsp was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver iirsp has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service vsmraid was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver vsmraid has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service viaide was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver viaide has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service elxstor was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver elxstor has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service nvstor was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver nvstor has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service aliide was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver aliide has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service cmdide was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver cmdide has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service ql40xx was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver ql40xx has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service ql2300 was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver ql2300 has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service stexstor was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver stexstor has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service SiSRaid4 was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver SiSRaid4 has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service SiSRaid2 was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver SiSRaid2 has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service amdide was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver amdide has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service nfrd960 was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver nfrd960 has been enabled. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service 1394ohci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service amdsata was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver amdsata has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service amdsbs was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver amdsbs has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service LSI_FC was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver LSI_FC has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service LSI_SAS2 was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver LSI_SAS2 has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service megasas was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver megasas has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service MegaSR was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver MegaSR has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service LSI_SAS is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service LSI_SCSI was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver LSI_SCSI has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service HpSAMD was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver HpSAMD has been enabled. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service usbehci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service usbohci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service usbuhci was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service ohci1394 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HDAudBus was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service msahci was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver msahci has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service pciide was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver pciide has been enabled. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service BrUsbMdm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service BrSerWdm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service atapi is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HidBatt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service MTConfig was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service mouhid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service kbdhid was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service sfloppy was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service usbprint was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HidUsb was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service disk is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service cdrom is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service UmPass was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service Compbatt is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HidIr was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service HidBth was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service BTHMODEM was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service hcw85cir was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service WacomPen was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service vmbus was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver vmbus has been enabled. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service Processor was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service IPMIDRV was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service intelppm was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service AmdK8 was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service AmdPPM was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service AcpiPmi was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service CmBatt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service sbp2port was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver sbp2port has been enabled. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service sermouse was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service ErrDev was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service Wd was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver Wd has been enabled. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service WmiAcpi was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service ACPI is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service pci is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service msisadrv is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service flpydisk was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service fdc was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service Parport was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service nvraid was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver nvraid has been enabled. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The original start type of service isapnp was 0. 2011-08-19 17:25:07, Info SYSPRP SPPNP: The driver isapnp has been enabled. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service pcmcia was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Service Serial is currently not disabled. Hence there is no need to re-enable it. 2011-08-19 17:25:07, Warning SYSPRP SPPNP: The original start type of service i8042prt was not found in its expected back-up location. Hence we will not be re-enabling this service. This is not necessarily an error. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Finished enabling the function drivers listed in the CDDB. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Uninstalling all existing devices <full generalize>. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_AGILEVPNMINIPORT\0000. 2011-08-19 17:25:07, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_L2TPMINIPORT\0000. 2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANBH\0000. 2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANIP\0000. 2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_NDISWANIPV6\0000. 2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_PPPOEMINIPORT\0000. 2011-08-19 17:25:08, Info SYSPRP SPPNP: Uninstalling device SW\{EEAB7790-C514-11D1-B42B-00805FC1270E}\ASYNCMAC failed with 0x5. 2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_PPTPMINIPORT\0000. 2011-08-19 17:25:08, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\MS_SSTPMINIPORT\0000. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDPBUS\0000. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDP_KBD\0000. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\RDP_MOU\0000. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\SYSTEM\0000. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\*ISATAP\0000. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\UMBUS\0000. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\*TEREDO\0000. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Uninstalling device ROOT\ACPI_HAL\0000 failed with 0xE0000231. 2011-08-19 17:25:09, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\VMWARE\0000. 2011-08-19 17:25:10, Info SYSPRP SPPNP: Uninstalling device ROOT\BLBDRIVE\0000 failed with 0xE0000231. 2011-08-19 17:25:10, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\VMWARE\0001. 2011-08-19 17:25:10, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\COMPOSITEBUS\0000. 2011-08-19 17:25:10, Info SYSPRP SPPNP: Uninstalling device ROOT\VOLMGR\0000 failed with 0xE0000231. 2011-08-19 17:25:10, Info SYSPRP SPPNP: Skipping uninstall of root enumerated device ROOT\COMPOSITE_BATTERY\0000. 2011-08-19 17:26:42, Info SYSPRP SPPNP: Reflected all boot critical driver packages (91579 ms). 2011-08-19 17:26:42, Info SYSPRP SPPNP: Sysprep_Generalize_Pnp: Exit 2011-08-19 17:26:42, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sppnp.dll,Sysprep_Generalize_Pnp' without error 2011-08-19 17:26:42, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{960b724d-0479-6dd8-0470-6c42dc9b8f85}; will try to launch 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize' 2011-08-19 17:26:42, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize'; executing it 2011-08-19 17:26:42, Info SYSPRP iphlpsvc.dll: sysprep generalize called 2011-08-19 17:26:42, Info SYSPRP Found interface in scavenger. 2011-08-19 17:26:43, Info SYSPRP Successfully uninstalled interface in scavenger 2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iphlpsvc.dll,IphlpsvcSysprepGeneralize' without error 2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{243bb634-be68-0139-f4c8-f1c87dade9d7}; will try to launch 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup' 2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup'; executing it 2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\setup\tssysprep.dll,LSMSysPrepBackup' without error 2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{df593d24-f963-8be2-86d6-c722da22bf5b}; will try to launch 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize' 2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize'; executing it 2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\setup\tssysprep.dll,RdpSysPrepGeneralize' without error 2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{03513543-c453-2e4f-5ee6-b970cace3cd8}; will try to launch 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell' 2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell'; executing it 2011-08-19 17:26:43, Info [shsetup] Sysprep_Generalize_Shell entered 2011-08-19 17:26:43, Info [shsetup] Sysprep_Generalize_Shell exit 2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\shsetup.dll,Sysprep_Generalize_Shell' without error 2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{1f954290-a3bd-7c6b-2062-3fd9d1266740}; will try to launch 'wer.dll,WerSysprepGeneralize' 2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'wer.dll,WerSysprepGeneralize'; executing it 2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'wer.dll,WerSysprepGeneralize' without error 2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{4840d621-1b47-334f-b1a6-321233838362}; will try to launch 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize' 2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize'; executing it 2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\dhcpcsvc.dll,DhcpClient_Generalize' without error 2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{67011352-10f6-73b5-85e9-6064e10071b9}; will try to launch 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net' 2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net'; executing it 2011-08-19 17:26:43, Info [0x0f0008] SYSPRP spnet.dll::IsDomainMember:This machine is not joined to a domain 2011-08-19 17:26:43, Info [0x0f000e] SYSPRP spnet.dll::UnjoinNetworkDomain:Not a domain member, nothing to do 2011-08-19 17:26:43, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spnet.dll,Sysprep_Generalize_Net' without error 2011-08-19 17:26:43, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{3aa3f98d-491f-7656-533f-7db889fff253}; will try to launch 'C:\Windows\System32\slc.dll,SLReArmWindows' 2011-08-19 17:26:43, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\slc.dll,SLReArmWindows'; executing it 2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\slc.dll,SLReArmWindows' without error 2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{d9d03ab7-c7a6-4587-c28d-ccc47a787790}; will try to launch 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize' 2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize'; executing it 2011-08-19 17:26:44, Info capisp.dll::CAPISysPrep_Generalize: returning 0 2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\capisp.dll,CAPISysPrep_Generalize' without error 2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{6a6b0fac-5606-6e68-410d-e7bf974f5136}; will try to launch 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd' 2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd'; executing it 2011-08-19 17:26:44, Info TOOL Sysprep_Generalize_Bcd: Located BCD store on system drive. Generalizing it... 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Found the memory tester object. 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Found the Windows OS Loader object {d54562fb-41e1-11e0-9007-94b295923b48} for the currently running OS. 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Found the resume object {d54562fa-41e1-11e0-9007-94b295923b48} for the OS loader. 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: System drive backed by VHD = 0 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Generalizing object {9dea862c-5cdd-4e70-acc1-f32b344d4795} 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0] 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Generalizing object {b2721d73-1db4-4c62-bf78-c548a880142d} 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0] 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Generalizing object {d54562fb-41e1-11e0-9007-94b295923b48} 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0] 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized OS device. Status = [0x0] 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Generalizing object {d54562fa-41e1-11e0-9007-94b295923b48} 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized application device. Status = [0x0] 2011-08-19 17:26:44, Info TOOL GeneralizeBcdStore: Successfully generalized hiberfile device. Status = [0x0] 2011-08-19 17:26:44, Info TOOL Sysprep_Generalize_Bcd: Successfully generalized the bcd store. Status=[0x0] 2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\spbcd.dll,Sysprep_Generalize_Bcd' without error 2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8fd6ce7c-4301-d490-719b-d787d2bde1cd}; will try to launch 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize' 2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize'; executing it 2011-08-19 17:26:44, Info SYSPRP nlmsprep.dll: Generalize start 2011-08-19 17:26:44, Info SYSPRP nlmsprep.dll: Generalize finish 2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\nlmsprep.dll,NetworkListManager_Generalize' without error 2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{79b40229-f48c-7547-1eb2-96b7091aa28f}; will try to launch 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize' 2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize'; executing it 2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\system32\msdtcprx.dll,SysPrepDtcGeneralize' without error 2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8dde3abb-19cb-88f8-4e07-05c697cc2872}; will try to launch 'RacEngn.dll,RacSysprepGeneralize' 2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'RacEngn.dll,RacSysprepGeneralize'; executing it 2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'RacEngn.dll,RacSysprepGeneralize' without error 2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{20b6ca3b-166d-4e8d-af73-72df2987e480}; will try to launch 'msmmsp.dll,MountMgr_Generalize' 2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'msmmsp.dll,MountMgr_Generalize'; executing it 2011-08-19 17:26:44, Info msmmsp::MountMgr_Generalize ENTER 2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'msmmsp.dll,MountMgr_Generalize' without error 2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{4aaf8557-52af-9241-469e-acbb347c3c07}; will try to launch 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE' 2011-08-19 17:26:44, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE'; executing it 2011-08-19 17:26:44, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\iesysprep.dll,Sysprep_Generalize_IE' without error 2011-08-19 17:26:44, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{71e01f6c-a271-b3b1-05f0-8c48a330cb4c}; will try to launch 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize' 2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize'; executing it 2011-08-19 17:26:45, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastScanRun does not exist, skipping action. 2011-08-19 17:26:45, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastScanType does not exist, skipping action. 2011-08-19 17:26:45, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastQuickScanID does not exist, skipping action. 2011-08-19 17:26:45, Info SYSPRP 㩤睜爷浴摜屳敳畣楲祴牰摯捵獴晜汩桥獡潣敤瑜扡敬浜瑲敧敮慲楬敺挮灰:敄敬整敒噧污敵:115 - Windows Defender value HKLM\SOFTWARE\Microsoft\Windows Defender\Scan\LastFullScanID does not exist, skipping action. 2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\winshfhc.dll,MRTComponent_Generalize' without error 2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{ccf004d0-c18e-a2d4-ee22-e585dac90889}; will try to launch 'srcore.dll,SysprepGeneralize' 2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'srcore.dll,SysprepGeneralize'; executing it 2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'srcore.dll,SysprepGeneralize' without error 2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{68cac03c-b4c6-675e-1b30-cf21359228e2}; will try to launch 'spwmp.dll,Sysprep_Generalize_WMP' 2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'spwmp.dll,Sysprep_Generalize_WMP'; executing it 2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'spwmp.dll,Sysprep_Generalize_WMP' without error 2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{b636fa27-124f-6436-6a6f-2fe2739a2b89}; will try to launch 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize' 2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize'; executing it 2011-08-19 17:26:45, Info SYSPRP WindowsSideShow: Enabling SystemDataProviders task returned 0x00000000 2011-08-19 17:26:45, Info SYSPRP WindowsSideShow: Enabling SessionAgent task returned 0x00000000 2011-08-19 17:26:45, Info SYSPRP WindowsSideShow: Enabling GadgetManager task returned 0x00000000 2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\AuxiliaryDisplayClassInstaller.dll,WindowsSideShow_Sysprep_Generalize' without error 2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{8a2650e9-70de-392f-5b09-34c3ac14764d}; will try to launch 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE' 2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE'; executing it 2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\sysprepMCE.dll,Sysprep_Generalize_MCE' without error 2011-08-19 17:26:45, Info [0x0f008b] SYSPRP RunRegistryDlls:Found entrypoint in registry at SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SysPrep\Generalize\{cb71e18d-7833-6f0f-2d00-e35ade2ecb27}; will try to launch 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize' 2011-08-19 17:26:45, Info [0x0f0080] SYSPRP LaunchDll:Found 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize'; executing it 2011-08-19 17:26:45, Info [0x0f0081] SYSPRP LaunchDll:Successfully executed 'C:\Windows\System32\inetsrv\iissyspr.dll,IIS_Generalize' without error 2011-08-19 17:26:45, Info [0x0f004c] SYSPRP WaitThread:Exiting spawned waiting thread 2011-08-19 17:26:45, Info [0x0f007a] SYSPRP FCreateTagFile:Successfully created tag file C:\Windows\System32\Sysprep\Sysprep_succeeded.tag 2011-08-19 17:26:45, Info [0x0f0052] SYSPRP Shutting down SysPrep log 2011-08-19 17:26:45, Info [0x0f004d] SYSPRP The time is now 2011-08-19 17:26:45Here is the setuperr.log
2011-08-08 16:46:05, Error SYSPRP SPPNP: Error 0x2 setting SDDL on driver file C:\Windows\system32\drivers\vmaudio.sys!
2011-08-08 16:46:05, Error SYSPRP SPPNP: Error 0x2 setting SDDL on driver file C:\Windows\system32\DRIVERS\vmci.sys!
2011-08-19 17:20:39, Error [0x0f0043] SYSPRP WinMain:The sysprep dialog box returned FALSE
