DE_FreD_S
Build & Capture fails at Sysprep with auth fail
Hi everyone...
very interesting thing happening when building and capturing Windows 7 machine.
I used the Tutorial here with one exception - I integrated Intel e1000 NIC drivers.
So the task sequence uses this driver package, instead of the standard drivers.
The installation runs fine up to the point where SCCM wants to run sysprep.
The task sequence exits prematurly.
The logs show that apparently, the account I use for network access has no permission to access the boot image stored in smspkgd$\DEM00006.
But when opening the console, I can easily connect to that folder via net use AND copy it's contents to C:\_SMSTaskSequence.
The Account used is in the Administrators group AND in the Domain Admins group.
I've also tried creating a new account and explicitly adding it to the local admins group on the sccm server.
Logs are attached.
Maybe someone has an idea as to what could be causing this problem?
Cheers,
Fred
smsts.log
