Thebeats2009
Integrate MDT12 with SCCM12
Hallo,
When i try to create a new MDT 2012 Task in SCCM 2012, i became an Error: Error while importing Microsoft Deployment Toolkit Task Sequence.
Started processing.
Creating boot image.
Generating boot image.
Capturing new boot image WIM file.
Copying WIM image to package source directory.
Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlQueryException: The SMS Provider reported an error. ---> System.Management.ManagementException: Generic failure
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObject.Put(PutOptions options)
at Microsoft.ConfigurationManagement.ManagementProvider.WqlQueryEngine.WqlResultObject.Put(ReportProgress progressReport)
--- End of inner exception stack trace ---
at Microsoft.BDD.Wizards.SCCM_ImportTaskSequenceTask.DoWork(SmsPageData smspageData, Dictionary`2 data)
Did Someone have an Idea?
Thank you
did you use mdt 2012 beta 1 ? when integrating it with CM12 did you run the command in the start menu by right clicking it and choosing Run As Administrator ?
