barryb20
Install Updates Offline, OSD TS using USB
Hi All,
I have a working USB media deployment but need to add the install updates offline task as this is for a remote office.
I have added the Task in the Post Install section after my Driver installs but before the Setup Windows and ConfigMgr e.g.
Use Toolkit Package > Install Upates Offline > Setup Windows and ConfigMgr.
as per previous posts by AnyWeb.
I also tried it before the Driver installs but recieve the same error attached, I have no EXE's in the patch package they are all CAB files, any ideas?
Thanks,
Barry
0 answers to this question
