smallc Posted October 9, 2011 Report post Posted October 9, 2011 Hi guys, i'm coming again, i have read the anyweb's article and step by step do it, but i got a error when i deploy osd, i don't know what the problem is hope someone can help me ? thanks you all Quote Share this post Link to post Share on other sites More sharing options...
Prajwal Desai Posted October 9, 2011 Report post Posted October 9, 2011 where have you copied the OS ?? Quote Share this post Link to post Share on other sites More sharing options...
smallc Posted October 9, 2011 Report post Posted October 9, 2011 where have you copied the OS ?? i copy it from the ISO, the ISO is download from msdn Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted October 9, 2011 Report post Posted October 9, 2011 and where are you getting the error above ? at what stage in the Build and Capture process was it ? Quote Share this post Link to post Share on other sites More sharing options...
smallc Posted October 9, 2011 Report post Posted October 9, 2011 and where are you getting the error above ? at what stage in the Build and Capture process was it ? I'm getting the error from destination computer which is no operate system, I don't capture the image, and I deploy ISO' wim file directly, it appears the message when i start the computer. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted October 10, 2011 Report post Posted October 10, 2011 follow the guide instead, then tell me what fails. Quote Share this post Link to post Share on other sites More sharing options...
