R_G_I
Advertised Programs wont run or even appear for Clients
Hi all,
First of all im very new to the world of SCCM and im currently testing how this software deploys applications and operating systems in a lab environment.
My basic setup is 2 server VM’s. One is an Windows server 2007 Active Directory Domain controller and the other is a Windows server 2003 VM running SCCM 2007 R2 and SQL server.
I have managed to successfully install all of my clients and the SCCM server has also discovered the client VM’s. When I view them in different collections I can see that it says “YES” where the Client installed column is.
My problem is however, I have packaged Office 2010 and created an advertisement for the “All Systems” collection. As I wanted to see results very soon, I created a mandatory assignment to run immediately. All of my client agents poll the SCCM server every 20 minutes. I left the VM’s running over night and found that none of them had installed Office 2010, also when I checked in control panel on the client VM’s for “advertised programs” nothing was there. It even still said “IT organisation” which I had changed to something custom.
A quick check of the execmgr logs on the clients show these errors repeating:
<![LOG[Common Client Agent Settings for the client are missing from WMI.]LOG]!>
<![LOG[software Distribution Site Settings for the client are missing from WMI.]LOG]!>
Any idea what the problem is here? As this is a test environment, all server and client firewalls are turned off and my entire SCCM folder which I have been using is shared out to “Everyone” with read/write access.
Any pointers would be very much appreciated thanks in advance!
R
0 answers to this question
