marculos
Unable to start Build and Capture Task Sequence
I have tried to set up a build and capture task sequence. After I boot from a prepared boot disk it gets to "Preparing Network Connections" then just reboots each time. The virtual pc I am testing on has an ip address. Any ideas what else it could be. In the smsts.log I see Failed to run unattended because media requires a password
Any ideas would be appreciated,
<![LOG[succeeded loading resource DLL 'X:\sms\bin\i386\TSRESNLC.DLL']LOG]!><time="09:43:54.490+480" date="10-13-2011" component="TSMBootstrap" context="" type="1" thread="1104" file="resourceutils.cpp:152">
<![LOG[Failed to open PXE registry key. Not a PXE boot.]LOG]!><time="09:43:54.530+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="tsmbootstrap.cpp:687">
<![LOG[Media Root = D:\]LOG]!><time="09:43:54.530+480" date="10-13-2011" component="TSMBootstrap" context="" type="1" thread="1104" file="tsmbootstrap.cpp:828">
<![LOG[Executing from Media in WinPE]LOG]!><time="09:43:54.530+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="tsmbootstrap.cpp:831">
<![LOG[Verifying Media Layout.]LOG]!><time="09:43:54.540+480" date="10-13-2011" component="TSMBootstrap" context="" type="1" thread="1104" file="tsmediawizardcontrol.cpp:1534">
<![LOG[MediaType = BootMedia]LOG]!><time="09:43:54.540+480" date="10-13-2011" component="TSMBootstrap" context="" type="1" thread="1104" file="tsmediawizardcontrol.cpp:2447">
<![LOG[PasswordRequired = true]LOG]!><time="09:43:54.550+480" date="10-13-2011" component="TSMBootstrap" context="" type="1" thread="1104" file="tsmediawizardcontrol.cpp:2473">
<![LOG[Found network adapter "Intel® PRO/1000 MT Desktop Adapter" with IP Address 10.56.1.104.]LOG]!><time="09:43:54.560+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="tsmbootstraputil.cpp:429">
<![LOG[Running Wizard in Unattended mode]LOG]!><time="09:43:54.560+480" date="10-13-2011" component="TSMBootstrap" context="" type="1" thread="1104" file="tsmediawizardcontrol.cpp:2642">
<![LOG[Loading Media Variables from "D:\sms\data\variables.dat"]LOG]!><time="09:43:54.560+480" date="10-13-2011" component="TSMBootstrap" context="" type="1" thread="1104" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_retail\sms\framework\smscrypt\windes.cpp,150)]LOG]!><time="09:43:54.600+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="windes.cpp:150">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_retail\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="09:43:54.600+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="tsremovablemedia.cpp:387">
<![LOG[!IsPasswordRequired(), HRESULT=80004005 (e:\nts_sccm_retail\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2296)]LOG]!><time="09:43:54.600+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="tsmediawizardcontrol.cpp:2296">
<![LOG[Failed to run unattended because media requires a password.]LOG]!><time="09:43:54.600+480" date="10-13-2011" component="TSMBootstrap" context="" type="3" thread="1104" file="tsmediawizardcontrol.cpp:2296">
<![LOG[unattended(), HRESULT=80004005 (e:\nts_sccm_retail\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2643)]LOG]!><time="09:43:54.600+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="tsmediawizardcontrol.cpp:2643">
<![LOG[oTSMediaWizardControl.Run( sMediaRoot, true ), HRESULT=80004005 (e:\nts_sccm_retail\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,832)]LOG]!><time="09:43:54.610+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="tsmbootstrap.cpp:832">
<![LOG[Execute( eExecutionEnv, sConfigPath, sTSXMLFile, uBootCount, &uExitCode ), HRESULT=80004005 (e:\nts_sccm_retail\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,977)]LOG]!><time="09:43:54.610+480" date="10-13-2011" component="TSMBootstrap" context="" type="0" thread="1104" file="tsmbootstrap.cpp:977">
<![LOG[Exiting with return code 0x80004005]LOG]!><time="09:43:54.610+480" date="10-13-2011" component="TSMBootstrap" context="" type="1" thread="1104" file="tsmbootstrap.cpp:989">
<![LOG[Execution complete.]LOG]!><time="09:43:54.630+480" date="10-13-2011" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:623">
<![LOG[Finalizing logging from process 724]LOG]!><time="09:43:54.630+480" date="10-13-2011" component="TSBootShell" context="" type="1" thread="736" file="tslogging.cpp:1742">
<![LOG[Finalizing logs to root of first available drive]LOG]!><time="09:43:54.630+480" date="10-13-2011" component="TSBootShell" context="" type="1" thread="736" file="tslogging.cpp:1584">
<![LOG[successfully finalized logs to X:\SMSTSLog]LOG]!><time="09:43:54.690+480" date="10-13-2011" component="TSBootShell" context="" type="1" thread="736" file="tslogging.cpp:1641">
<![LOG[Cleaning up task sequencing logging configuration.]LOG]!><time="09:43:54.690+480" date="10-13-2011" component="TSBootShell" context="" type="0" thread="736" file="tslogging.cpp:584">
