mapl
Standard Distribution Point in another Location
I have build an Windows 2008 R2 Server with SCCM 2007 R3.
Now I will create in another Location ( same AD ) an standard Distribution Server on a Windows 2008 R2 Fileserver but run everytime in errors that the Package ( Install Retrying). I found some installation guides with the settings for IIS / Webdav and change these settings.
I create a share on the Distribution Point and set the full permissions for the Server Account from the SCCM server to the share and security. ( I can´t find here any installation guide and hope that is correct ) What I saw is that in the IIS 7 in the default side there is nothing include from the SCCM like in Windows 2003.
Because I also try to install a standard distribution point in the same location on a windows 2003 Server. That works without any problems.
THe Config Status Message shows " Failed to create virtual directory on the defined share or volume on distribution point "["Display=\\Servername\SCCM$\"]MSWNET:["SMS_SITE=001"]\\Servername\SCCM$\". " Distribution Point : ["Display=\\Servername\SCCM$\"]MSWNET:["SMS_SITE=001"]\\Servername\SCCM$\"
Message ID 2344
Did someone know how to fix it ....
thanks
