using SCCM 2012 in a LAB - Part 2. Add SUP and WDS
what does the manual sync actually do..does it force the cas to go out to the internet and check for updates?...or just preform a sync of it's updates with the primary? I checked the wsus sources folder and there is no content..so nothing is being downloaded.
triggering a sync causes Configmgr to ask WSUS to sync with Microsoft Update, do you need to configure proxy settings or something ?
ok, well double check all my steps in the guide, you must have missed something or you are not telling me the whole story.
as a troubleshooting step, you can open the wsus console and trigger a sync in ConfigMgr, what you should see is WSUS starting a sync, do you ?
