using SCCM 2012 in a LAB - Part 2. Add SUP and WDS
We have an existing WSUS server and we are installing SCCM 2012 on a separate server(Primary site, no CAS). Is it possible to integrate the existing WSUS remotely into SCCM system?
And if yes, what's the best practice to do it?
Thank you in advance.
  Quote
The tile of this thread is wrong.
It should be using SCCM 2012 RC in a LAB - Part 2. Add SUP and WSUS
actually this post was originally about setting up the SUP (which involves WSUS) and Windows Deployment Services (WDS), so the Title is correct,
however this post has since been superseded with this one.
hello all,
I'm trying to setup my lab with SCCM 2012 RTM. So far i'm not able to get any Software Updates. Below is the error i got from the WCM.log file. Can anyone help me with this error?
System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 10.33.130.120:8082~~ at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)~~ at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& exception)~~ --- End of inner exception stack trace ---~~ at Microsoft.UpdateServices.Administration.AdminProxy.CreateUpdateServer(Object[] args)~~ at Microsoft.SystemsManagementServer.WSUS.WSUSServer.ConnectToWSUSServer(String ServerName, Boolean UseSSL, Int32 PortNumber) SMS_WSUS_CONFIGURATION_MANAGER 4/8/2013 10:36:48 AM 4816 (0x12D0)
Also here's the error from the wsyncmgr.log .
Sync failed: WSUS update source not found on site IVT. Please refer to WCM.log for configuration error details.. Source: getSiteUpdateSource SMS_WSUS_SYNC_MANAGER 4/8/2013 11:01:24 AM 4832 (0x12E0)
STATMSG: ID=6703 SEV=E LEV=M SOURCE="SMS Server" COMP="SMS_WSUS_SYNC_MANAGER" SYS=IRKWSCCM02.amno.corp.bshg.com SITE=IVT PID=2420 TID=4832 GMTDATE=Mon Apr 08 18:01:24.794 2013 ISTR0="getSiteUpdateSource" ISTR1="WSUS update source not found on site IVT. Please refer to WCM.log for configuration error details." ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=0 SMS_WSUS_SYNC_MANAGER 4/8/2013 11:01:24 AM 4832 (0x12E0)
  Quote
did you check the firewall and proxy settings ?
Hi Niall,
Thank you for response. I've checked the settings again and it was because i mistakenly enter the wrong port for WSUS configuration. It is now synchronizing. :)
sync: WSUS synchronizing updates, processed 1387 out of 60566 items (2%), ETA in 05:10:02 SMS_WSUS_SYNC_MANAGER 4/8/2013 3:06:46 PM 3168 (0x0C60)
Thank you very much for your help and for providing such a great and informative site.
