i get also a problem deploying the captured image. I have no idea why it gets the pictured error while deploying the os to the system.
I also followed all steps. The only difference i am using SCCM 2012 SP1 with patched Config Manager Client. But the system doesn go so far...
Also there will no logs produced since the partition is not available. (No "C" Drive...)
Any hints and suggestion would be great!
How long does the Device Collection of Build and Capture Windows 7 x64 take to complete? Mines been running for quite some time and has no members and still has the hour glass. It's been there overnight. I have also noticed the same hourglass on 'All Systems' has been there for days! However 'All Systems' has members as this was run couple weeks back
what hardware are you PXE booting, those menu choices don't look familiar... are you PXE booting to a configuration manager server ?
I have a question about including the configmanager client in my build and capture task sequence.
Right now, I have an SCCM 2012 Sp1/MDT 2012 Update 1 UDI deployment task sequence. When I use that task sequence to deploy the install.wim from the Windows 7 DVD, it works great. When I use that task sequence to deploy the .WIM that I created using this guide, the deployment fails at installing the configmanager client.
During my build and capture, I am installing the "Microsoft Configuration Manager Client Upgrade 5.0 ALL" package that I created following these instructions. I am also installing this same package during my deployments.
Is that right? It seems like I should either drop the client from either the Build and Capture or the deployment task sequence.
Im having a pretty strange issue that I haven't found an answer to yet. Everything was working smoothly until I got to this portion of the guide. When I try to create the task sequence in SCCM I cannot see the distribution point. I can see and select the boot image, but when I try to select the operating system install package no distribution points are listed. The OS install package was distributed to the distribution point in a previous portion of this guide. When I look at the properties of the OS install package it shows the DP.
I tried uninstalling WDS and now I see a boatload of errors in my distmgr.log file
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\EFI\bootmgfw.efi SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:51 PM 6000 (0x1770)
RemoveFile failed; 0x80070005 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\EFI SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts\segmono_boot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts\segoen_slboot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts\segoe_slboot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts\wgl4_boot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\abortpxe.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\bootmgr.exe SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\pxeboot.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\pxeboot.n12 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\wdsmgfw.efi SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\wdsnbp.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
Processing CMS00005 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
Library path mismatch: \\?\D:\SCCMContentLib, D:\SCCMContentLib SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
Removing CMS00005 from D:\RemoteInstall\SMSImages SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
Removing D:\RemoteInstall\SMSTempBootFiles\CMS00005 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\EFI\bootmgfw.efi SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\EFI SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts\segmono_boot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts\segoen_slboot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts\segoe_slboot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts\wgl4_boot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\abortpxe.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:52 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\bootmgr.exe SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
RemoveFile failed; 0x80070005 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\pxeboot.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\pxeboot.n12 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\wdsmgfw.efi SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\wdsnbp.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00005 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
RegQueryValueExW failed for Software\Microsoft\SMS\DP, INST_WDSAUTO SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
RegReadDWord failed; 0x80070002 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
Machine is running Windows Server. (NTVersion=0X601, ServicePack=1) SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
WDS is INSTALLED SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
CcmUnregisterWDS SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
Removing SMSPXE provider. Performing an uninstall SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
PxeProviderUnRegister SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
PxeLoadWdsPxe SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
Loading wdspxe.dll from C:\Windows\system32\wdspxe.dll SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
wdspxe.dll is loaded SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:53 PM 6000 (0x1770)
WDSServer status is 4 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
WDSServer is STARTED SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
Removing existing PXE related directories SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
Removing PXE Boot directory: D:\RemoteInstall\SMSBoot SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
Removing PXE Temp directory: D:\RemoteInstall\SMSTemp SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
Removing PXE Images directory: D:\RemoteInstall\SMSImages SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
Removing PXE Images directory: D:\RemoteInstall\SMSTempBootFiles SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\EFI\bootmgfw.efi SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
RemoveFile failed; 0x80070005 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\EFI SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts\segmono_boot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts\segoen_slboot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts\segoe_slboot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts\wgl4_boot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\Fonts SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\abortpxe.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\bootmgr.exe SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\pxeboot.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\pxeboot.n12 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\wdsmgfw.efi SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:56 PM 6000 (0x1770)
RemoveFile failed; 0x80070005 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE\wdsnbp.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot\PXE SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows\Boot SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004\Windows SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00004 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\EFI\bootmgfw.efi SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\EFI SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts\segmono_boot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts\segoen_slboot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts\segoe_slboot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts\wgl4_boot.ttf SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
RemoveDirectoryW failed (0x80070091) for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\Fonts SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\abortpxe.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\bootmgr.exe SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\pxeboot.com SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\pxeboot.n12 SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
SetFileAttributesW failed for D:\RemoteInstall\SMSTempBootFiles\CMS00005\Windows\Boot\PXE\wdsmgfw.efi SMS_DISTRIBUTION_MANAGER 5/29/2013 2:12:57 PM 6000 (0x1770)
Here are some jpg's.
