Hi:
My PXE setup is the following (not working):
- Enable PXE support for clients (checked)
- Allow the distribution point to respond to PXE requests (checked)
- Enable unknown computer support (checked)
- Require a password when computer use PXE (unchecked)
- User device affinity: Allow user device affinity with automatic approval
- Respond to PXE requests on all network interfaces
When PXE is enabled and I run netstat -ano I see UDP67, UDP6( and UDP4011 all listening.
When I unchecked PXE and reboot and then run netstat -ano only UDP69 is listening but WDS
service is started.
The Windows Firewall is off and no hardware firewall exists in front of the SCCM server.
The SCCM server is on a different VLAN than the client I am PXE booting. We use
Infoblox as our DHCP Appliance and out router is Cisco. My networking team configured
the ip-helper table to have the SCCM server's ip address.
Mark
Hi:
I get the following messages on my PXE client:
PXE-E53: No boot filename received
PXE-MOF: Exiting Intel PXE ROM
Operating System not found
As I mentioned above before I started testing SCCM 2012 RC I was testing the native WDS. The WDS server has/had the exact same IP address as the SCCM 2012
server. All my PXE clients were working against the WDS server without any issue. As soon as SCCM 2012 RC came out I shut down the WDS server and started
on my SCCM 2012 RC install. Everything in SCCM 2012 RC is working fine up to the PXE part. So just to verify I just shutdown my SCCM 2012 RC server and
started up my WDS server. Once WDS was up I started a PXE client and the PXE client was able to boot correctly and connect the WDS server and successfully
install an operating system. I shut down the WDS server and started the SCCM 2012 RC server again and same issue.
Mark
  On 11/23/2011 at 4:08 PM, anyweb said:
what happens when you try to pxe boot a client Mark ?
ah ok, if i'm understanding you correctly, you have a separate WDS server in this lab, which is powered off, but was in use before, that one may have configured some DHCP options...do you know ?
when you start sccm 2012 rc, does the WDS service itself start or not ?
Hi:
There are no DHCP Options configured because according to the Microsoft article (see below) these DHCP options are no longer preferred. This is why I asked my Networking team to use ip-helper tables.
Configuring Your Router to Forward Broadcasts (recommended)
You can update the routing tables for your networking equipment to make sure that DHCP traffic is directed correctly. For example, you can use the ip helper-address command if you have a Cisco router. When configured correctly, all DHCP broadcasts from the client computer will be directed to a DHCP server and a Windows Deployment Services server. (Note that the requirement is not to rebroadcast the packet onto other network segments, but rather to forward the packet to only the specified recipients.)
If the booting client, the DHCP server, and the Windows Deployment Services server are all located on the same network segment, you should not have to configure your router. The client’s DHCP broadcasts will reach both the DHCP server and the Windows Deployment Services server. However, if either the DHCP server or the Windows Deployment Services server are on a different network segment than the client (or if they are on the same network segment but the network is controlled by a switch or router), Microsoft recommends that you update your router. After the client computer has obtained its IP address, it contacts the Windows Deployment Services server directly (again using DHCP packets) to obtain the name and path of the NBP to be downloaded. The following are the specific changes that you need to make:
  • All DHCP broadcasts by client computers on User Data Protocol (UDP) port 67 should be forwarded directly to both the DHCP server and the Windows Deployment Services server.
  • If the router has a built in firewall, you need to allow traffic through UDP port 4011 (as well as any UDP ports used for TFTP and multicasting as specified on the Network Settings tab of server properties in the Windows Deployment Services MMC snap-in).
In SCCM 2012 RC the WDS service only starts when I have PXE disabled. If I keep PXE enabled and reboot the server WDS stays in a Starting state. Once I see that WDS is started I go
and enable PXE.
Mark
ok i missed that you said about ip-helpers earlier, my bad.
have you tried the following in this order:-
  • deselecting PXE on the dp,
  • uninstall the DP role,
  • uninstall WDS service,
  • reboot server,
  • re-enable the DP role,
  • re-enable PXE on that DP role,
  • monitor the distrmgr.log
to see what it says about the WDS service (which Enabling the PXE option will start in process).
Hi:
I really appreciate the help.
I have done what you recommended. Below is the contents of the distrmgr.log (I have hi-lighted some failed items):
Mark
ConfigureDP SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
DP registry settings have been successfully updated on SCCM.server2008r2.lab.local SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
STATMSG: ID=2373 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=3428 GMTDATE=Fri Nov 25 14:57:13.902 2011 ISTR0="Enabled" ISTR1="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=404 AVAL0="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
STATMSG: ID=2374 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=3428 GMTDATE=Fri Nov 25 14:57:13.903 2011 ISTR0="Disabled" ISTR1="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=404 AVAL0="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
ConfigurePXE SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
CcmInstallPXE SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
RegQueryValueExW failed for Software\Microsoft\SMS\DP, PxeInstalled SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
RegReadDWord failed; 0x80070002 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
Created the DP mutex key for WDS. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
Wimgapi.dll is already installed. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
Running: ServerManagerCmd.exe -i WDS -a SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
Waiting for completion of: ServerManagerCmd.exe -i WDS -a SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:13 AM 3428 (0x0D64)
Run completed for: ServerManagerCmd.exe -i WDS -a SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Failed to create Software\Microsoft\SMS\DP\Performance SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Failed to create Software\Microsoft\SMS\DP\Logging SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Machine is running Windows Server. (NTVersion=0X601, ServicePack=1) SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
WDS is INSTALLED SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Setting TFTP config key as: System\CurrentControlSet\Services\WDSSERVER\Providers\WDSTFTP SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Configuring TFTP read filters SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
SetupComplete is set to 0 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
RegQueryValueExW failed for Software\Microsoft\Windows\CurrentVersion\Setup, REMINST SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
RegReadDWord failed; 0x80070002 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
REMINST not set in WDS SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
WDS is NOT Configured SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
REMINST share already present pointing to D:\RemoteInstall SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Removing existing PXE related directories SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Registering WDS provider: SourceDir: D:\Program Files\Microsoft Configuration Manager\bin\x64 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Registering WDS provider: ProviderPath: D:\Program Files\Microsoft Configuration Manager\bin\x64\smspxe.dll SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
DoPxeProviderRegister SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
PxeLoadWdsPxe SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Loading wdspxe.dll from C:\Windows\system32\wdspxe.dll SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
wdspxe.dll is loaded SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
PxeProviderRegister has suceeded (0x00000000) SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Disabling WDS/RIS functionality SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
PxeProviderUnRegister SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Found privilege otifyPrivilege on service WDSServer SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Found privilege SeRestorePrivilege on service WDSServer SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Found privilege SeBackupPrivilege on service WDSServer SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Found privilege SeSecurityPrivilege on service WDSServer SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
Privilege SeTakeOwnershipPrivilege NOT found service WDSServer SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
ChangeServiceConfig2 succeeded for WDSServer. Added privilege SeTakeOwnershipPrivilege SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
ChangeServiceConfig succeeded for WDSServer. StartType: 0x2 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:25 AM 3428 (0x0D64)
WDSServer status is 4 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
WDSServer is STARTED SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
Machine is running Windows Server. (NTVersion=0X601, ServicePack=1) SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
No need to configure the firewall SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
CcmInstallPXE: Deleting the DP mutex key for WDS. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
DP monitoring task is disabed on server SCCM.server2008r2.lab.local SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
No need to initialize monitoring task on SCCM.server2008r2.lab.local SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
DP settings have been updated to SCCM.server2008r2.lab.local. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
Sleep 3600 seconds... SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:30 AM 3428 (0x0D64)
Created policy provider trigger for ID 16777219 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:32 AM 4332 (0x10EC)
Found notification for package 'P0100002' SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Found notification for package 'P0100003' SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Processing 16777219.INS SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
DPID 16777219 - NAL Path ["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\ , ServerName = SCCM.server2008r2.lab.local, DPDrive = , IsMulticast = 0, PXE = 1 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
user(NT AUTHORITY\SYSTEM) runing application(SMS_DISTRIBUTION_MANAGER) from machine (SCCM.server2008r2.lab.local) is submitting SDK changes from site(P01) SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
target processor architecture is x64 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
DP monitoring task is disabed on server SCCM.server2008r2.lab.local SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
No need to initialize monitoring task on SCCM.server2008r2.lab.local SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
DP settings have been updated to SCCM.server2008r2.lab.local. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Install Internet server= 0 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Skipping OS configuration SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
STATMSG: ID=2392 SEV=W LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=3428 GMTDATE=Fri Nov 25 14:57:40.587 2011 ISTR0="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" ISTR1="" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=404 AVAL0="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Creating, reading and or updating Operations Management server role registry keys for a Distribution Point ... SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Copied signature files to remote DP SCCM.server2008r2.lab.local successfully SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Compiling D:\Program Files\Microsoft Configuration Manager\bin\x64\_smsdpprov.mof SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
D:\Program Files\Microsoft Configuration Manager\bin\x64\_smsdpprov.mof is complied successfully SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Package Thread Limit: 3 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Retry interval: 30 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Successfully modified DP ["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\ Drizzle Role to 1 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
ConfigureDP SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
DP registry settings have been successfully updated on SCCM.server2008r2.lab.local SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
STATMSG: ID=2373 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=3428 GMTDATE=Fri Nov 25 14:57:40.771 2011 ISTR0="Enabled" ISTR1="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=404 AVAL0="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
STATMSG: ID=2374 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=3428 GMTDATE=Fri Nov 25 14:57:40.772 2011 ISTR0="Disabled" ISTR1="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=404 AVAL0="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
ConfigurePXE SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
CcmInstallPXE SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
PXE provider is already installed. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Used 0 out of 3 allowed processing threads. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Starting package processing thread, thread ID = 0xB80 (2944) SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Starting package processing thread, thread ID = 0xE68 (3688) SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
Sleep 3600 seconds... SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3428 (0x0D64)
STATMSG: ID=2300 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=2944 GMTDATE=Fri Nov 25 14:57:40.781 2011 ISTR0="Configuration Manager Client Package" ISTR1="P0100002" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=400 AVAL0="P0100002" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
No action specified for the package P0100002. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
STATMSG: ID=2300 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=3688 GMTDATE=Fri Nov 25 14:57:40.784 2011 ISTR0="Configuration Manager Client Upgrade Package" ISTR1="P0100003" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=400 AVAL0="P0100003" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
No action specified for the package P0100003. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
Updating package info for package P0100002 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
Updating package info for package P0100003 SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
Package P0100002 does not have a preferred sender. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
The package and/or program properties for package P0100002 have not changed, need to determine which site(s) need updated package info. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
StoredPkgVersion (1) of package P0100002. StoredPkgVersion in database is 1. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
SourceVersion (1) of package P0100002. SourceVersion in database is 1. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
STATMSG: ID=2301 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=2944 GMTDATE=Fri Nov 25 14:57:40.820 2011 ISTR0="Configuration Manager Client Package" ISTR1="P0100002" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=400 AVAL0="P0100002" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
Exiting package processing thread. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 2944 (0x0B80)
Package P0100003 does not have a preferred sender. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
The package and/or program properties for package P0100003 have not changed, need to determine which site(s) need updated package info. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
StoredPkgVersion (1) of package P0100003. StoredPkgVersion in database is 1. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
SourceVersion (1) of package P0100003. SourceVersion in database is 1. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
STATMSG: ID=2301 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=3688 GMTDATE=Fri Nov 25 14:57:40.829 2011 ISTR0="Configuration Manager Client Upgrade Package" ISTR1="P0100003" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=400 AVAL0="P0100003" SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
Exiting package processing thread. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:40 AM 3688 (0x0E68)
Used 0 out of 3 allowed processing threads. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:45 AM 3428 (0x0D64)
Sleep 3600 seconds... SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:45 AM 3428 (0x0D64)
Used 0 out of 3 allowed processing threads. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:50 AM 3428 (0x0D64)
Sleep 3600 seconds... SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:50 AM 3428 (0x0D64)
Used 0 out of 3 allowed processing threads. SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:55 AM 3428 (0x0D64)
Sleep 3600 seconds... SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:55 AM 3428 (0x0D64)
ConfigureDP SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:55 AM 3428 (0x0D64)
DP registry settings have been successfully updated on SCCM.server2008r2.lab.local SMS_DISTRIBUTION_MANAGER 11/25/2011 9:57:55 AM 3428 (0x0D64)
STATMSG: ID=2373 SEV=I LEV=M SOURCE="SMS Server" COMP="SMS_DISTRIBUTION_MANAGER" SYS=SCCM.server2008r2.lab.local SITE=P01 PID=2084 TID=3428 GMTDATE=Fri Nov 25 14:57:55.929 2011 ISTR0="Enabled" ISTR1="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" ISTR2="" ISTR3="" ISTR4="" ISTR5="" ISTR6="" ISTR7="" ISTR8="" ISTR9="" NUMATTRS=1 AID0=404 AVAL0="["Display=\\SCCM.server2008r2.lab.local\"]MSWNET:["SMS_SITE=P01"]\\SCCM.server2008r2.lab.local\" SMS_DISTRIBUTION_MANAGER 11
Well I was able to get this resolved by doing the following:
(1) after making the changes suggested I decided to roll back to a snapshot I did before I did the above changes.
(2) Then I went to each of the Boot images and clicked Update Distribution Points again
(3) booted my PXE client and it started to work
Wahoo!
Anyways I really appreciated the pointers and help you provided.
Thanks.
Mark
