and, my logpath when I go into the registry and look is still not listing a full path to the SMSPXE.log file, just the filename itself and it is NOT being created. I've completely removed SCCM and started from scratch and it is still doing this once I install WDS via enabling PXE.
This software is still buggy glad MS hasn't released it yet
Is there a way to restore the Site System Roles that are listed at the bottom of Servers and Site System Roles section? I am missing the Distribution Point and even though I can create one, not sure of the steps to do so. Also, I do not see the Boot images (x64) & (x86) that you show in the boot images section of the Software library. Are these created when you add the OS?
I've followed your guide, but i must have made a mistake somewhere. I've added the smsts.log file in the code block.
The DHCP gives a valid IP in the range I put up. When i try to renew it i only get the following feedback.
Client2%20on%20localhost%20-%20Virtual%20Machine%20Connection_2012-02-23_12-51-32.png
I've also tried mapping a network share but then it only returns system error 67 has occurred.
Evryting else has worked perfectly, and im kinda lost on what to do next. Would appreciate a helping hand, since this has to do with my Bachelor degree.
<![LOG[LOGGING: Finalize process ID set to 812]LOG]!><time="13:21:32.256+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="816" file="tslogging.cpp:1495">
<![LOG[==============================[ TSBootShell.exe ]==============================]LOG]!><time="13:21:32.256+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="816" file="bootshell.cpp:956">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:21:32.256+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="816" file="util.cpp:910">
<![LOG[Debug shell is enabled]LOG]!><time="13:21:32.256+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="816" file="bootshell.cpp:967">
<![LOG[Waiting for PNP initialization...]LOG]!><time="13:21:32.256+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:60">
<![LOG[booted from network (PXE)]LOG]!><time="13:21:33.317+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="configpath.cpp:198">
<![LOG[Found config path X:\sms\data\]LOG]!><time="13:21:33.317+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:545">
<![LOG[booting from removable media, not restoring bootloaders on hard drive]LOG]!><time="13:21:33.317+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:556">
<![LOG[Executing command line: wpeinit.exe -winpe]LOG]!><time="13:21:33.317+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:761">
<![LOG[The command completed successfully.]LOG]!><time="13:21:50.508+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:843">
<![LOG[starting DNS client service.]LOG]!><time="13:21:50.508+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:589">
<![LOG[Executing command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="13:21:51.023+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:761">
<![LOG[The command completed successfully.]LOG]!><time="13:21:51.023+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="848" file="bootshell.cpp:843">
<![LOG[==============================[ TSMBootStrap.exe ]==============================]LOG]!><time="13:21:51.085+480" date="02-22-2012" component="TSMBootstrap" context="" type="1" thread="728" file="tsmbootstrap.cpp:966">
<![LOG[Command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="13:21:51.085+480" date="02-22-2012" component="TSMBootstrap" context="" type="0" thread="728" file="tsmbootstrap.cpp:967">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:21:51.085+480" date="02-22-2012" component="TSMBootstrap" context="" type="1" thread="728" file="util.cpp:910">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\TSRESNLC.DLL']LOG]!><time="13:21:51.085+480" date="02-22-2012" component="TSMBootstrap" context="" type="1" thread="728" file="resourceutils.cpp:152">
<![LOG[PXE Boot with Root = X:\]LOG]!><time="13:21:51.085+480" date="02-22-2012" component="TSMBootstrap" context="" type="1" thread="728" file="tsmbootstrap.cpp:899">
<![LOG[Executing from PXE in WinPE]LOG]!><time="13:21:51.085+480" date="02-22-2012" component="TSMBootstrap" context="" type="0" thread="728" file="tsmbootstrap.cpp:914">
<![LOG[Loading TsPxe.dll from X:\sms\bin\x64\TsPxe.dll]LOG]!><time="13:21:51.085+480" date="02-22-2012" component="TSMBootstrap" context="" type="0" thread="728" file="tsmbootstraputil.cpp:1274">
<![LOG[TsPxe.dll loaded]LOG]!><time="13:21:51.101+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmbootstraputil.cpp:1284">
<![LOG[Device has PXE booted]LOG]!><time="13:21:51.101+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tspxe.cpp:122">
<![LOG[Variable Path: \SMSTemp\2012.02.22.13.20.06.0001.{0996AA2B-4F50-4881-BE78-8B130A14F342}.boot.var]LOG]!><time="13:21:51.101+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tspxe.cpp:134">
<![LOG[succesfully added firewall rule for Tftp]LOG]!><time="13:21:51.101+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="fwopen.cpp:123">
<![LOG[Executing: X:\sms\bin\x64\smstftp.exe -i 192.168.1.91 get \SMSTemp\2012.02.22.13.20.06.0001.{0996AA2B-4F50-4881-BE78-8B130A14F342}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:21:51.101+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tspxe.cpp:177">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="13:21:51.163+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="commandline.cpp:228">
<![LOG[set command line: "X:\sms\bin\x64\smstftp.exe" -i 192.168.1.91 get \SMSTemp\2012.02.22.13.20.06.0001.{0996AA2B-4F50-4881-BE78-8B130A14F342}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:21:51.163+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="commandline.cpp:705">
<![LOG[Executing command line: "X:\sms\bin\x64\smstftp.exe" -i 192.168.1.91 get \SMSTemp\2012.02.22.13.20.06.0001.{0996AA2B-4F50-4881-BE78-8B130A14F342}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:21:51.163+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="commandline.cpp:801">
<![LOG[Process completed with exit code 0]LOG]!><time="13:21:51.210+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="commandline.cpp:1098">
<![LOG[succesfully removed firewall rule for Tftp]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="fwopen.cpp:146">
<![LOG[successfully downloaded pxe variable file.]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tspxe.cpp:187">
<![LOG[we are booted using PXE]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsmediawizardcontrol.cpp:2551">
<![LOG[we are booted using PXE and we don't use a password or the password is provided by the user]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsmediawizardcontrol.cpp:2567">
<![LOG[Found network adapter "Intel(R) 82579LM Gigabit Network Connection" with IP Address 192.168.1.100.]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmbootstraputil.cpp:426">
<![LOG[Run PXE Interactive]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediawizardcontrol.cpp:2699">
<![LOG[Running Wizard in Interactive mode]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsmediawizardcontrol.cpp:2701">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,150)]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="windes.cpp:150">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsremovablemedia.cpp:387">
<![LOG[Activating Welcome Page.]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediawelcomepage.cpp:131">
<![LOG[Loading bitmap]LOG]!><time="13:21:51.226+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsmbootstrap.cpp:1065">
<![LOG[WelcomePage::OnWizardNext()]LOG]!><time="13:22:02.177+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediawelcomepage.cpp:340">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:22:02.177+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,150)]LOG]!><time="13:22:02.177+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="windes.cpp:150">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:22:02.177+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsremovablemedia.cpp:387">
<![LOG[Verifying media password.]LOG]!><time="13:22:02.177+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsmediawizardcontrol.cpp:270">
<![LOG[spawned thread 912 to download policy.]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsmediawelcomepage.cpp:405">
<![LOG[Entering TSMediaWizardControl::GetPolicy.]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="tsmediawizardcontrol.cpp:511">
<![LOG[Environment scope "Global\{51A016B6-F0DE-4752-B97C-54E6F386A912}" successfully created]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="environmentscope.cpp:305">
<![LOG[Environment scope "Global\{BA3A3900-CA6D-4ac1-8C28-5073AFC22B03}" successfully created]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="environmentscope.cpp:305">
<![LOG[setting LogMaxSize to 1000000]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:539">
<![LOG[setting LogMaxHistory to 1]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:540">
<![LOG[setting LogLevel to 0]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:541">
<![LOG[setting LogEnabled to 1]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:542">
<![LOG[setting LogDebug to 1]LOG]!><time="13:22:02.192+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:543">
<![LOG[Loading variables from the Task Sequencing Removable Media.]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:563">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsremovablemedia.cpp:322">
<![LOG[setting SMSTSMP TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSMediaGuid TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSBootMediaPackageID TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSHTTPPort TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSHTTPSPort TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSIISSSLState TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSLaunchMode TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSMediaPFX TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSPublicRootKey TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSSiteCode TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSSiteSigningCertificate TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSUseFirstCert TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSx64UnknownMachineGUID TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSx86UnknownMachineGUID TS environment variable]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:580">
<![LOG[Root CA Public Certs=]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:591">
<![LOG[Missing root CA environment variable from variables file]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:597">
<![LOG[Custom hook from X:\\TSConfig.INI is ipconfig]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:646">
<![LOG[successfully registered Task Sequencing COM Interface.]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="environmentlib.cpp:798">
<![LOG[set command line: ipconfig]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="commandline.cpp:705">
<![LOG[Executing command line: ipconfig]LOG]!><time="13:22:02.364+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="commandline.cpp:801">
<![LOG[Process completed with exit code 0]LOG]!><time="13:22:02.395+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="commandline.cpp:1098">
<![LOG[successfully unregistered Task Sequencing Environment COM Interface.]LOG]!><time="13:22:02.395+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="environmentlib.cpp:885">
<![LOG[Authenticator from the environment is empty.]LOG]!><time="13:22:02.395+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:809">
<![LOG[Need to create Authenticator Info using PFX]LOG]!><time="13:22:02.395+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="tsmediawizardcontrol.cpp:821">
<![LOG[set media certificate in transport]LOG]!><time="13:22:02.426+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="libsmsmessaging.cpp:9202">
<![LOG[set authenticator in transport]LOG]!><time="13:22:02.426+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="libsmsmessaging.cpp:7574">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: SCCM.lab.local:80  GET /SMS_MP/.sms_aut?MPKEYINFORMATION]LOG]!><time="13:22:02.426+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="libsmsmessaging.cpp:8404">
<![LOG[Error. Received 0x80072ee7 from WinHttpSendRequest.]LOG]!><time="13:22:04.735+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="912" file="libsmsmessaging.cpp:8671">
[b]<![LOG[unknown host (gethostbyname failed)]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="3" thread="912" file="libsmsmessaging.cpp:691">[/b]
<![LOG[hr, HRESULT=80072ee7 (e:\nts_sccm_release\sms\framework\osdmessaging\libsmsmessaging.cpp,8720)]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="libsmsmessaging.cpp:8720">
[b]<![LOG[sending with winhttp failed; 80072ee7]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="3" thread="912" file="libsmsmessaging.cpp:8720">[/b]
<![LOG[m_pHttpTransport->Send (0, 0, pServerReply, nReplySize), HRESULT=80072ee7 (e:\nts_sccm_release\sms\framework\osdmessaging\libsmsmessaging.cpp,5150)]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="libsmsmessaging.cpp:5150">
<![LOG[MPKeyInformation.RequestMPKeyInformation(szTrustedRootKey), HRESULT=80072ee7 (e:\nts_sccm_release\sms\framework\osdmessaging\libsmsmessaging.cpp,9211)]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="libsmsmessaging.cpp:9211">
[b]<![LOG[Failed to get information for MP: http://SCCM.lab.local. 80072ee7.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="3" thread="912" file="tsmbootstraputil.cpp:1429">[/b]
<![LOG[sMP.length() > 0, HRESULT=80004005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmbootstraputil.cpp,1437)]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="tsmbootstraputil.cpp:1437">
<![LOG[TSMBootstrapUtil::SelectMP ( sSMSTSMP.c_str(), sMediaPfx.c_str(), sMediaGuid.c_str(), sAuthenticator.c_str(), sEnterpriseCert.c_str(), sServerCerts.c_str(), nHttpPort, nHttpsPort, bUseCRL, sSiteCode, sAssignedSiteCode, sMP, sCertificates, sX86UnknownMachineGUID, sX64UnknownMachineGUID), HRESULT=80004005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,871)]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="tsmediawizardcontrol.cpp:871">
<![LOG[Exiting TSMediaWizardControl::GetPolicy.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="tsmediawizardcontrol.cpp:1335">
<![LOG[pWelcomePage->m_pTSMediaWizardControl->GetPolicy(), HRESULT=80004005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawelcomepage.cpp,303)]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="912" file="tsmediawelcomepage.cpp:303">
<![LOG[setting wizard error: An error occurred while retrieving policy for this computer  (0x80004005). For more information, contact your system administrator or helpdesk operator.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediawizardcontrol.cpp:1504">
<![LOG[WelcomePage::OnWizardNext()]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediawelcomepage.cpp:340">
<![LOG[skipping Confirmation Page.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediaconfirmationpage.cpp:170">
<![LOG[skipping Task Sequence Selection Page.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediataskselectionpage.cpp:118">
<![LOG[skipping Variables Selection Page.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediavariablesselectionpage.cpp:155">
<![LOG[skipping Resolve Progress Page.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediaresolveprogresspage.cpp:96">
<![LOG[Activating Finish Page.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediafinishpage.cpp:107">
<![LOG[initializing the countdown timer.]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediafinishpage.cpp:197">
<![LOG[Loading bitmap]LOG]!><time="13:22:07.028+480" date="02-22-2012" component="TSPxe" context="" type="1" thread="728" file="tsmbootstrap.cpp:1065">
<![LOG[Executing command line: X:\WINDOWS\system32\cmd.exe /k]LOG]!><time="13:22:15.764+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="816" file="bootshell.cpp:761">
<![LOG[The command completed successfully.]LOG]!><time="13:22:15.764+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="816" file="bootshell.cpp:843">
<![LOG[successfully launched command shell.]LOG]!><time="13:22:15.764+480" date="02-22-2012" component="TSBootShell" context="" type="1" thread="816" file="bootshell.cpp:430">
<![LOG[suspending the countdown timer.]LOG]!><time="13:22:19.259+480" date="02-22-2012" component="TSPxe" context="" type="0" thread="728" file="tsmediafinishpage.cpp:384">
Found out my DHCP was configured wrong, had to change 127.0.0.1 in my scope to the 192.168.1.90 which is the ip for my dns server.
