using SCCM 2012 RC in a LAB - Part 10. Using Prestart and Extrafiles to get more out of UDA
i didnt see any reference to UDA in your smsts.log file, check again, verify it's being set in your task sequence like i've specified in the guide ok ?
In Part 9, I deployed the PXE on the second VM. Was stuck on the PXE not progressing to the F12 button. I went back thru all the steps in Part 9 and it finally worked.
Readin Part 10, I went and deleted that VM from SCCM, redid the import to that Deploy Group, but am still getting just the PXE not progressing to the point that I can press F12.
Any ideas?
This is what repeats in the SMSPXE.log:
Set media certificate in transport SMSPXE 2/23/2012 6:54:43 PM 3400 (0x0D48)
Set authenticator in transport SMSPXE 2/23/2012 6:54:43 PM 3400 (0x0D48)
PXE::CBootImageManager::FindMatchingArchitectureBootImage SMSPXE 2/23/2012 6:55:15 PM 3400 (0x0D48)
Set media certificate in transport SMSPXE 2/23/2012 6:55:15 PM 3400 (0x0D48)
Set authenticator in transport SMSPXE 2/23/2012 6:55:15 PM 3400 (0x0D48)
Client boot action reply: <ClientIDReply><Identification Unknown="0" ItemKey="16777239" ServerName="" ServerRemoteName=""><Machine><ClientID/><NetbiosName/></Machine></Identification><PXEBootAction LastPXEAdvertisementID="" LastPXEAdvertisementTime="" OfferID="" OfferIDTime="" PkgID="" PackageVersion="" PackagePath="" BootImageID="" Mandatory=""/></ClientIDReply>
Client Identity: {38B78A4C-E32A-4DA9-A26B-E317B43F895D} SMSPXE 2/23/2012 6:55:15 PM 3400 (0x0D48)
Seems like the Client ID is missing.
DISREGARD THIS.
After being able to redo the PXE I ran into a few issues. I was unable to press the F8 key to copy the CMTrace program over during the installation. Upon completed and going to the My Devices section, the message I received stated: This setting cannot be configured because of a network communications or a configuration problem.
Once the system completed the installation and I logged in, I copied the CMTrace program to the root of the C:\ drive. Browsing to the C:\Windows\CCM\Logs directory, there is no log titled AppEnforce.log. The first log is titled CAS.log Firefox is not installed either.
Just after enter the username, I get this message:
I press "OK" the message disappears, then I can't do nothing!
When I press "NEXT" on the "Welcome to the task sequence wizard" nothing happens.
I don't why, do you've an idea?
Thank's in advance.
