kris00l
PSP issue - WDS and SCCM on different Servers
I have installed MDT Server with WDS on it and able to do Lite touch installations.
DHCP Server has
60 N/A due to different server than WDS
66 no entry
67 no entry
Now, I have installed SCCM on a different server in the hope for ZTI. After reading many blogs I found out that PSP needs to be installed on WDS Server. Therefore I went ahead with that process:
  • Under Site Settings, right clicked Site Systems
  • Clicked NEW, Server
  • Called PXEServer (made up name), FQDN - mdtsvr.mydomain.loc
  • checked PSP role
  • finish
PXESetup.log on SCCM server - no changes
Event viewer on SCCM server - nothing related to PSP
Under, boot image, Manage DP doesn't show PXE$ either.
I have also tried, uninstalled WDS role and reinstalled with no configuration. Deleted PSP role and then deleted PXEServer. Recreated again. Still NO go.
Please help.
so just to confirm, you have a Configmgr pxe service point role installed on the MDT server (can you show me a screenshot of it as you see it in your sccm sites sytems, select the mdt server and see what roles are listed)
ok good, go back to your mdtsvr computer and double check that there is a pxesetup.log file, it may be in a folder that you cannot access (UAC), if it doesnt exist does your SCCM computer account have local admin access on the other computer ?
i have searched under domain admin on MDTSvr ... no pxesetup.log.
i haven't checked sccm computer account access on MDTSvr therefore I think as you mentioned may not be able to install PSP. But wouldn't there be a log somewhere to say that?
Update:
Added SCCM computer account in MDTSvr Administrators group but still no go. Here's the screenshot:
(I did delete PSP then deleted PXEServer from the node and then re-added the server.)
