I have been using SCCM to deploy Win7 32bit to computers but just started to work on 64 bit OSD.
The problem that I have is that my 64 bit boot image continuously reboots, I don't even get to the point where I choose my task sequence.
What I have done is:
created new 64 bit boot image, enabled F8 command line support and injected network drivers.
also enabled F8 support on the default 64bit boot image.
Created bootable usb with both of the boot images (for testing).
However, when I use the boot images it will boot into Winpe but then it will just reboot again into the same winpe... and loop over and over until I just shutdown the computer.
The strange thing is that F8 support does not work, that is when I press F8 to troubleshoot the problem in Winpe, nothing happends.
I have tried to remove F8 support, build the boot image again and reenable F8 support (and build again), but no go.
My 32bit boot image works fine.
Any ideas on what could be happening?
GauiC
*edit:
forgot to mention. My setup is
SCCM 2007 SP2 R3
