Purity
Management Point not Receiving Hardware Inventory Bits Error 501 IIS Error
I'm receiving the following error in the IIS log on the Management Point:
2011-11-29 16:08:47 x1.x.x.x BITS_POST /CCM_Incoming/{9F4ADA79-C0BE-4B65-BF70-55EB0BFE6A0F} (bits_error:,501,0x80070005) 80 - x2.x.x.x Microsoft+BITS/7.5 501 0 0 1
x1.x.x.x = MP
x2.x.x.x = Client
This error resuls in the management point not recieving any hardware inventory information
I feel that I've tried everything to resolve this.
1) Removed BITS and Re-installed
2) Checked CCM_Incoming permissions and they are correct
3) Re-installed SCCM Client on Client PC
4) Cleared BITS Payload
5) Client MP check - This was ok
Please can anyone suggest anything else to try?
2 answers to this question
OK, found the issue. BITS was not enabled on the CCM_Incoming directory, hence the 501 error.
The hardware/software inventory info is still failing to come back to the site server, so I intend removing the management point and reinstalling it. Hopefully this will fix the issue
