lionsgarden
Application Catalog: Default Web Site Bindings configuration
Hi to all,
I have problem with AWEBSVC Service because it reports in AWEBSCTL.LOG the error "Call to HttpSendRequestSync failed for port 8080 with status code 500, text: Internal Server Error". After several tests I understood that this error could be resolved using a blank host name in Default Web Site Bindings on a different port from 80 (the port 80 already has other bindings).
If I use the SCCM 2012 ip address to browse the Application Catalog on port 8080 (i.e.) I can install also the applications published, but I can not configure that IP Address in Default Client settings to access to Application Catalog from Software Center on the client.
I am sorry for my English but I hope that it will be clear enough.
Thank you.
Cristiano
