bocarfofana
SMS_MP_CONTROL MANAGER dindn't work
Componet: SMS_MP_CONTROL_MANAGER
MP Control Manager detected MPsetup has failed to create the CCM_Incoming Virtual Directory.
Possible cause: The IIS IWAM account has expired, been disabled, or has invalid or too restrictive logon hours. You may verify this information by running the net user command line for the IWAM account. (i.e.: "net user IWAMMachineName)
Solution: Use the output to verify that the account is enabled, and logon is possible during the time of installation. Note: You can use "net user" to modify the account properties.
Possible cause: The IIS IUSR account has expired, been disabled, or has invalid or too restrictive logon hours. You may verify this information by running the net user command line for the IUSR account. (i.e.: "net user IWAMMachineName)
Possible cause: The designated Web Site is disabled in IIS.
Solution: Verify that the designated Web Site is enabled, and functioning properly.
