cmnd_ctrl
Repost Success or Failure notification in sccm need urgent help
I need to repost as I still need help with this as it is not working.
Found this in regards to Configmgr OSD Task sequence ; Success or Failure notification which is something I really need and I attempted the instructions exactly as listed down to the file names. After I have ran numerous successful osd deployments I've received no emails. What is missing because I can't see it?
http://scug.be/blogs...tification.aspx
