jcboyer Posted January 15, 2012 Report post Posted January 15, 2012 Hi, When I'm trying to deploy the SCCM on a workstation it doesn't work due to SSL error. Even if I indicate (in the site properties) that HTTPS and HTTP can be used and that client do not use client certificates, I still have the same problem. If I install a client certificat on the targeted workstation, the SCCM client deployment is working fine. Certificates on client workstation is a requirement for SCCM agent deployment ? Best Regards JC Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted January 15, 2012 Report post Posted January 15, 2012 Depends.. are you running Native or Mixed mode? Quote Share this post Link to post Share on other sites More sharing options...
jcboyer Posted January 15, 2012 Report post Posted January 15, 2012 Hi Peter, Mixed mode. It was an error on my site. I changed the Distribution Point settings from HTTPS to HTTP but I forgot to modify the Management Point settings. So I modified the communication setting of the MP from HTTPS to HTTP and now it's working fine without client certificats. Sorry JC Quote Share this post Link to post Share on other sites More sharing options...
