Orlax
Problem refreshing a PC from WinXp to Win7 using OSD with SCCM 2007 R3
Hi There!
I installed a SCCM 2007 R3 in a test Windows Server 2008 R2 Domain, I configured without problems all the setting of SCCM 2007, including Software Update Point, State Migration Point and so on.
I tried to test the process of refreshing a Windows XP Machine to Windows 7, using the Operating System Deployment functionallity of SCCM 2007 R3, WAIK 2.0 is installed in the SCCM 2007 R3 Machine, I can generate a Package of USMT 4.0 without problems. I Generate a Capture Media using the Create Task Sequence Media Option in SCCM 2007, burn it to a CD an use it to capture a Windows 7 image from a reference Computer with a fresh install of Windows 7, this computer is in a Workgroup and have blank local administrator password, then y copy the *.wim image to a folder in my SCCM 2007 R3 Server and load as an Operating System Image to the SCCM Server.
I created a Task Sequence to Intall an existing Image Package, can Add the Advanced SCCM Client Package and the USMT 4.0 package, after I advertised this task sequence to a Test Computer Collection, the Windows XP computer receive the advertised Task Sequence in seconds when I refresh the Machine Policy Interval.
I CLick the advertisement in the Windows XP Machine, and start to Run Without Problems nad capture state of the machine and download some files without problems (I correct the prblem of the NULL Certificate Subject Names applying the correct update on Server an Fixing the certificate on the Windows XP Machine) but in a few seconds the porcess stop and rolled back, because an error.
I monitor the advertisement Status, and see that all the first steeps start OK, but when try to excetute the Scanstate the followin error show:
The task sequence execution engine failed executing the action (Capture User Files and Settings) in the group (Capture User Files and Settings) with the error code 2147942426
Action output: ssful
Building user defined params successful
Building USMT command successful
Successfully connected to "\\SCCM.UCDOM.LAN\SMPSTOREf_7B3EA745$\7832E390CA301C2A19FDF8BA88E34D1014999431BC23ED77C5796C7CE598FE6B"
Executing command line: "C:\_SMSTaskSequence\Packages\S0100006\x86\scanstate.exe" "\\SCCM.UCDOM.LAN\SMPSTOREf_7B3EA745$\7832E390CA301C2A19FDF8BA88E34D1014999431BC23ED77C5796C7CE598FE6B" /o /localonly /encrypt /key:*** /c /efs:copyraw /all /l:"C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstate.log"progress:"C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstateprogress.log" /i:"C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml" /i:"C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml"
Log messages are being sent to 'C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstate.log'
Starting the migration process
Abnormal Termination.
ScanState return code: 26
USMT returned exit code (0x0000001a). Look USMT log file scanstate.log for detail error message.
POSDMigrateUserState finished: 0x8007001a. The operating system reported error 2147942426: The specified disk or diskette cannot be accessed.
I open the Log Files in the Windows XP Machine I am trying to refreshing to Windows 7, the scanstateprogress.log is empty but the scanstate.log is the following
2012-01-19 09:49:54, Info [0x000000] USMT Started at 2012/01/19:09:49:54.264
2012-01-19 09:49:54, Info [0x000000] Command line: C:\_SMSTaskSequence\Packages\S0100006\x86\scanstate.exe \\SCCM.UCDOM.LAN\SMPSTOREf_7B3EA745$\7832E390CA301C2A19FDF8BA88E34D1014999431BC23ED77C5796C7CE598FE6B /o /localonly /encrypt /key:**** /c /efs:copyraw /all /l:C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstate.log /progress:C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstateprogress.log /i:C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml /i:C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml
2012-01-19 09:49:54, Info [0x000000] Script file specified: C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml[gle=0x00000002]
2012-01-19 09:49:54, Info [0x000000] Script file specified: C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml[gle=0x00000002]
2012-01-19 09:49:54, Info [0x000000] Starting the migration process[gle=0x00000006]
2012-01-19 09:49:54, Warning [0x08040c] Failed to create SMI engine
2012-01-19 09:49:54, Warning [0x08066d] GAC data store: mscoree.dll is not found. (hr = 0x0000007E)
2012-01-19 09:49:56, Warning [0x080462] CListSysFileFilter::BuildTree: could not create FileList object for C:\_SMSTaskSequence\Packages\S0100006\x86\SFLISTXP.DAT: Win32Exception: \\?\C:\_SMSTaskSequence\Packages\S0100006\x86\SFLISTXP.DAT: El sistema no puede hallar el archivo especificado. [0x00000002] __thiscall UnBCL::FileStream::FileStream(const class UnBCL::String *,enum UnBCL::FileMode,enum UnBCL::FileAccess,enum UnBCL::FileShare,unsigned long)
2012-01-19 09:49:57, Error [0x000000] Unhandled exception: OutOfMemoryException: (no exception message provided) class UnBCL::String *__stdcall Mig::pGetDateAndTime(void)[gle=0x00000091]
2012-01-19 09:49:57, Error [0x000000] Unhandled exception, abnormal termination[gle=0x00000091]
2012-01-19 09:49:57, Info [0x000000] USMT Completed at 2012/01/19:09:49:57.608[gle=0x00000006]
2012-01-19 10:34:30, Info [0x000000] USMT Started at 2012/01/19:10:34:30.335
2012-01-19 10:34:30, Info [0x000000] Command line: C:\_SMSTaskSequence\Packages\S0100006\x86\scanstate.exe \\SCCM.UCDOM.LAN\SMPSTOREf_7B3EA745$\7832E390CA301C2A19FDF8BA88E34D1014999431BC23ED77C5796C7CE598FE6B /o /localonly /encrypt /key:**** /c /efs:copyraw /all /l:C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstate.log /progress:C:\WINDOWS\system32\CCM\Logs\SMSTSLog\scanstateprogress.log /i:C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml /i:C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml
2012-01-19 10:34:30, Info [0x000000] Script file specified: C:\_SMSTaskSequence\Packages\S0100006\x86\miguser.xml[gle=0x00000002]
2012-01-19 10:34:30, Info [0x000000] Script file specified: C:\_SMSTaskSequence\Packages\S0100006\x86\migapp.xml[gle=0x00000002]
2012-01-19 10:34:30, Info [0x000000] Starting the migration process[gle=0x00000006]
2012-01-19 10:34:30, Warning [0x08040c] Failed to create SMI engine
2012-01-19 10:34:30, Warning [0x08066d] GAC data store: mscoree.dll is not found. (hr = 0x0000007E)
2012-01-19 10:34:32, Warning [0x080462] CListSysFileFilter::BuildTree: could not create FileList object for C:\_SMSTaskSequence\Packages\S0100006\x86\SFLISTXP.DAT: Win32Exception: \\?\C:\_SMSTaskSequence\Packages\S0100006\x86\SFLISTXP.DAT: El sistema no puede hallar el archivo especificado. [0x00000002] __thiscall UnBCL::FileStream::FileStream(const class UnBCL::String *,enum UnBCL::FileMode,enum UnBCL::FileAccess,enum UnBCL::FileShare,unsigned long)
2012-01-19 10:34:33, Error [0x000000] Unhandled exception: OutOfMemoryException: (no exception message provided) class UnBCL::String *__stdcall Mig::pGetDateAndTime(void)[gle=0x00000091]
2012-01-19 10:34:33, Error [0x000000] Unhandled exception, abnormal termination[gle=0x00000091]
2012-01-19 10:34:33, Info [0x000000] USMT Completed at 2012/01/19:10:34:33.070[gle=0x00000006]
I can´t continue with my test, because I´m Stucked here! I don´t Know what´s happening !!!
Can you Help me with a possible solution ?
Thanks a Lot
Orlando
Have you resolved your problem? If not, you may want to temporarily disable any user state actions and ensure that you can deploy your Windows 7 image out to a machine. once you know all that works, then you can tackle USMT. And have you checked out the guides pinned to the top of the USMT forum? http://www.windows-noob.com/forums/index.php?/forum/78-usmt/
