wmmayms Posted January 24, 2012 Report post Posted January 24, 2012 Is your PXE point installed on your site server or on a DP? If it´s installed on a DP you need to check the log locally on that DP. Quote Share this post Link to post Share on other sites More sharing options...
StefanWe Posted January 24, 2012 Report post Posted January 24, 2012 It is installed on my local site server. all roles are on the same server. Quote Share this post Link to post Share on other sites More sharing options...
StefanWe Posted January 24, 2012 Report post Posted January 24, 2012 Ok. my guest is booting to the pe environment. I uninstalled wds again and reinstall and then it works. rc1 is buggy But now, i am hanging on an abort in the pe env. I created a task sequence for the deployment. i choose my boot.wim and the windows 7 wim from the original dvd ( both x86). The system boots into the pe and format my local drive c, and then after the message output "Apply windows operating system" the task sequence abort with the error 0x80070002. Any ideas? I have no captured image. I only want to deploy a fresh win 7 image without a answer file. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted January 24, 2012 Report post Posted January 24, 2012 is it a vmware environment ? perhaps you have a vmware dhcp server causing issues... Quote Share this post Link to post Share on other sites More sharing options...
StefanWe Posted January 24, 2012 Report post Posted January 24, 2012 yes, it is a vmware vsphere 4.1 with esxi env. What did you mean with dhcp server causing issues? The task sequence is starting and my volume is formatting, only applying the os does not work Quote Share this post Link to post Share on other sites More sharing options...
StefanWe Posted January 24, 2012 Report post Posted January 24, 2012 ok, i did a test. my client is now a hardware pc. The network and hdd controller driver are in the boot pe image. But i have the same error as above 0x80070002. My sccm server runs on vsphere 4.1. The dhcp server is a virtual machine on that env. on a windows 2008 r2 server. After the disk is formated, i reboot my pc with a win 7 dvd and start cmd.exe to take a look on the drive. There is no smsts.log available. Only 20mb are copied. Have somebody any ideas? Quote Share this post Link to post Share on other sites More sharing options...
wmmayms Posted January 24, 2012 Report post Posted January 24, 2012 0x80070002 is a "file not found error". Check your network access account and also check dns etc.. Quote Share this post Link to post Share on other sites More sharing options...
StefanWe Posted January 24, 2012 Report post Posted January 24, 2012 yes, thx. That was the right answer I don#t configured a network access account I forgot it Big thanks.. Thanks thanks Quote Share this post Link to post Share on other sites More sharing options...
wmmayms Posted January 24, 2012 Report post Posted January 24, 2012 nice to hear that things started working Quote Share this post Link to post Share on other sites More sharing options...
Joohan Posted January 28, 2012 Report post Posted January 28, 2012 Perhaps somebody can help me to figure this out? I have a Task Sequense that suddenly stopped working. It was last used about a week ago, without any issuses. Yesterday evening, after a week on the road, I tried to reinstall my notebook just to learn that it now fails resolving dependencies. (0x8007000E) I have attached the smsts.log file, I have tried googling the error but that didn't help :-( smsts.logFetching info... Quote Share this post Link to post Share on other sites More sharing options...
