sweety_devil
Help with USMT 4 parameters
Dear all,
I will migrate my computers from XP to Windows 7 32 bits.
1. I created a task sequence (see below) but scanstate scans my D drive. How can I avoid that ? I used the metod 1 on this site http://blogs.technet.com/b/configurationmgr/archive/2010/06/30/how-to-use-usmt-4-hardlinking-in-a-configuration-manager-2007-task-sequence.aspx
2. Should I install applications after or before restoring data ?
Thank you.
4 answers to this question
add a custom XML file with exclusions like this one
  <!-- This component migrates Common Exclusions-->
   <component type="Documents" context="System">
       <displayName _locID="miguser.userdata">Common Exclusions</displayName>
       <role role="Data">
           <rules>
  	         <unconditionalExclude>
  		         <objectSet>
  			         <script>MigXmlHelper.GenerateDrivePatterns ("\Winnt\* [*]", "Fixed")</script>
  			         <script>MigXmlHelper.GenerateDrivePatterns ("\Windows\* [*]", "Fixed")</script>
  			         <pattern type="File">%CSIDL_WINDOWS%\* [*]</pattern>
  			         <pattern type="File">C:\MININT\*[*]</pattern>
  			     	<pattern type="File">D:\* [*]</pattern>
                   	<pattern type="File">E:\* [*]</pattern>
                   	<pattern type="File">F:\* [*]</pattern>
  			         <pattern type="File">G:\* [*]</pattern>
  			         <pattern type="File">H:\* [*]</pattern>
  			         <pattern type="File">I:\* [*]</pattern>
  			         <pattern type="File">J:\* [*]</pattern>
  			         <pattern type="File">K:\* [*]</pattern>
  			         <pattern type="File">L:\* [*]</pattern>
  			         <pattern type="File">M:\* [*]</pattern>
  			         <pattern type="File">N:\* [*]</pattern>
  			         <pattern type="File">O:\* [*]</pattern>
  			         <pattern type="File">P:\* [*]</pattern>
  			         <pattern type="File">Q:\* [*]</pattern>
  			         <pattern type="File">R:\* [*]</pattern>
  			         <pattern type="File">S:\* [*]</pattern>
  			         <pattern type="File">T:\* [*]</pattern>
  			         <pattern type="File">U:\* [*]</pattern>
  			         <pattern type="File">V:\* [*]</pattern>
  			         <pattern type="File">W:\* [*]</pattern>
  			         <pattern type="File">X:\* [*]</pattern>
  			         <pattern type="File">Y:\* [*]</pattern>
  			         <pattern type="File">Z:\* [*]</pattern>
  		         </objectSet>
  	         </unconditionalExclude>
           </rules>
       </role>
   </component>
copy it to the usmt folder(s) give it a name like MyCustomXml.xml and redistribute your USMT package to your distribution points. Once done add the file to your Capture User Files and Settings step by selecting Customize how user profiles are captured. Click on Files and add the filename you specified.
Thank you it works perfectly !
I have a problem with the utility usmtutils.exe. I created a package with this command line: echo y| usmtutils.exe /rd %systemdrive%\UserState but it doesn't work.
I don't know why. Do we run this application just after the user restore or at the end of the task sequence ?
Thank you.
