parko89
XP Build and Capture TS Failing
Hi guys,
I am trying to setup a Build and Capture for XP and seem to be have a few issues. I've managed to fix most of them but I'm stuck with with the task sequence failing once it reaches the second last step - "Prepare OS". All I have configured here is "Automatically build mass storage driver list" (which is selected).
I have the sysprep for SP3 package on the DP which contains all the files extracted from the deploy.cab file downloaded directly from Microsoft.
The final step in the TS is "Capture the Reference Machine which has the UNC path where to save the .WIM.
I've exported the TS and attached it to this post along with the smsts.log file.
Any help would be greatly appreciated.
Kind Regards,
Ben
Build & Capture WinXP x86 SP3.xml
smsts.log
smsts.log
4 answers to this question
