tommy
How to monitor status of deployment
Hi.
I´m working on deploying software from command line/script with my sccm 2007 setup.
I´m still new with SCCM, so I’m seeking a bit of help.
My case is that I will deploy application A, and when it’s done I will deploy application B.
I will do this by adding the servers to different collection (one for each application).
My script looks like this: (based on WMI/vbscript)
Call Installapp (application A)
Loop until deployment of Application A is done. (log if error)
Call Installapp (application B)
Loop until deployment of Application B is done. (log if error)
Can someone help me doing this check? I mean, check the status of the deployment process through sccm. I want my script to wait until the application is installed before moving on with the next.
Exsamples, comments etc.
Thanks.
3 answers to this question
Hi.
Thanks for your comment.
My situation is that aplication B is a office language pack, and i have 8 different versions of this. Not the same should be used everytime.
Thats why i want some kind of logging to check and make sure that the first application has been successful installed before moving on.
/Tommy
  On 2/15/2012 at 8:09 PM, Peter van der Woude said:
If you are advertising to computers you can just use a Task Sequence to install the software.
Or just select Run another program first in the properties of application b.
Just create 2 custom collections for each language pack you want to deploy. The first one should hold the client names. In the second one create a query for the installed software, in your case Office XX, and link the query to the first collection.
After your office installation force a hardware inventory on your client, so the second collection is going to be filled.
