Please help me, ive tried to do the OSD with capture and restore USMT, everythings going fine , initially the user capture is done successfully as we have the file created of the data backup. OS is deployed and softwares are installed sucecessfully but when it comes to the restore part it give the error mesage 0x00004005 or 0x00002004.
Now in my TS im using the original source for windows installation and not the image and im specifying the drive letter c where the OS ahs to be installed. Just to let u know all this.
I have Waik installed and the source file is selected from the program files USMT folder, Ive also tried by extracting 3.0.1 USMT but it didnt work out same error mesasge it gives when the USMT was 3.0.1 selected as the source file. Even after changing the source file to C:Program files->WAIK->tools->USMT it still gives the same error message.
We not formatting the PC in the TS, The local drive on server which has 20Gb free sapace is selected as the backup location for the USMT.
The option of Restore only mode is unchecked in the USMT role.
Its so annoying to be so close but yet so far for the refresh to start in our Organization.
We have some 1000 PC's to refresh from windows XP to Windows7 with different desktops and laptop models. Please help as we are ready with everything but cannot go ahead until we have a solution for this.
The KB 974571 from the mahcines is uninstalled and OSD with USMT was tried. The other thing of the server KB977203 ive been going thru its complicated and i am unable to understand.
< ![LOG[send a task execution status message SMS_TSExecution_ActionFailError]LOG]!><time="11:26:28.520+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:314">
< ![LOG[MP server EMRHOSCCMGT.EMAAR.AE and port 80. SSL=false. CRL=false.]LOG]!><time="11:26:28.520+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:458">
< ![LOG[Let the parent group (User State Restore) decides whether to continue execution]LOG]!><time="11:26:28.738+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="instruction.cxx:3210">
< ![LOG[Let the parent group (Install Software) decide whether to continue execution]LOG]!><time="11:26:28.738+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="instruction.cxx:2461">
< ![LOG[Let the parent group (Setup Operating System) decide whether to continue execution]LOG]!><time="11:26:28.738+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="instruction.cxx:2461">
< ![LOG[The execution of the group (Setup Operating System) has failed and the execution has been aborted. An action failed.
< ![LOG[send a task execution status message SMS_TSExecution_TaskSequenceFailError]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:314">
< ![LOG[MP server EMRHOSCCMGT.EMAAR.AE and port 80. SSL=false. CRL=false.]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:458">
< ![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="11:28:33.258+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="commandline.cpp:229">
< ![LOG[==========[ TsProgressUI started in process 3380 ]==========]LOG]!><time="11:28:33.804+000" date="02-28-2012" component="TsProgressUI" context="" type="1" thread="604" file="winmain.cpp:327">
< ![LOG[setting program history for DXB00081:*]LOG]!><time="11:28:34.131+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="swdupdatescontroller.cpp:374">
Dear Experts,
Please Advice !!! CHAMPS!!
Here is the Log:
<![LOG[ExecuteRestoreRequest failed (0x80004005).]LOG]!><time="11:26:28.302+000" date="02-28-2012" component="OSDSMPClient" context="" type="3" thread="192" file="smpclient.cpp:2919">
< ![LOG[ExecuteRestoreRequest(), HRESULT=80004005 (e:\nts_sms_fre\sms\client\osdeployment\osdsmpclient\main.cpp,80)]LOG]!><time="11:26:28.395+000" date="02-28-2012" component="OSDSMPClient" context="" type="0" thread="192" file="main.cpp:80">
< ![LOG[OSDSMPClient finished: 0x00004005]LOG]!><time="11:26:28.395+000" date="02-28-2012" component="OSDSMPClient" context="" type="1" thread="192" file="main.cpp:120">
< ![LOG[Process completed with exit code 16389]LOG]!><time="11:26:28.411+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="commandline.cpp:1102">
< ![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="11:26:28.411+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="instruction.cxx:3010">
< ![LOG[Failed to run the action: Request State Store.
Unknown error (Error: 00004005; Source: Unknown)]LOG]!><time="11:26:28.504+000" date="02-28-2012" component="TSManager" context="" type="3" thread="1348" file="instruction.cxx:3101">
< ![LOG[sending status message . . .]LOG]!><time="11:26:28.520+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:292">
< ![LOG[site code: DXB]LOG]!><time="11:26:28.520+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:489">
< ![LOG[Client machine name: EHGCORPLT23]LOG]!><time="11:26:28.520+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:494">
< ![LOG[Client Identity: GUID:A7627241-0C11-451E-B066-2CC956B2FBD8]LOG]!><time="11:26:28.520+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:496">
< ![LOG[Advertisement ID: DXB20141]LOG]!><time="11:26:28.520+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:505">
< ![LOG[Package ID: DXB00081]LOG]!><time="11:26:28.520+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:507">
< ![LOG[sending StatusMessage]LOG]!><time="11:26:28.614+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="libsmsmessaging.cpp:3806">
< ![LOG[Formatted header:]LOG]!><time="11:26:28.614+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="libsmsmessaging.cpp:1500">
< ![LOG[<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>GUID:A7627241-0C11-451E-B066-2CC956B2FBD8</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2012-02-28T07:26:28Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="4222"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
]LOG]!><time="11:26:28.614+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="libsmsmessaging.cpp:1501">
< ![LOG[CLibSMSMessageWinHttpTransport::Send: URL: EMRHOSCCMGT.EMAAR.AE:80 CCM_POST /ccm_system/request]LOG]!><time="11:26:28.614+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="libsmsmessaging.cpp:7446">
< ![LOG[The request has succeeded. 200 OK]LOG]!><time="11:26:28.660+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="libsmsmessaging.cpp:7734">
< ![LOG[set a global environment variable _SMSTSLastActionRetCode=16389]LOG]!><time="11:26:28.660+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="executionenv.cxx:668">
< ![LOG[set a global environment variable _SMSTSLastActionSucceeded=false]LOG]!><time="11:26:28.660+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="executionenv.cxx:668">
< ![LOG[Clear local default environment]LOG]!><time="11:26:28.660+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="executionenv.cxx:807">
Operation aborted (Error: 80004004; Source: Windows)]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="3" thread="1348" file="instruction.cxx:2424">
< ![LOG[Failed to run the last action: Request State Store. Execution of task sequence failed.
Unknown error (Error: 00004005; Source: Unknown)]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="3" thread="1348" file="engine.cxx:214">
< ![LOG[sending status message . . .]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:292">
< ![LOG[site code: DXB]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:489">
< ![LOG[Client machine name: EHGCORPLT23]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:494">
< ![LOG[Client Identity: GUID:A7627241-0C11-451E-B066-2CC956B2FBD8]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:496">
< ![LOG[Advertisement ID: DXB20141]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:505">
< ![LOG[Package ID: DXB00081]LOG]!><time="11:26:28.770+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utility.cxx:507">
< ![LOG[sending StatusMessage]LOG]!><time="11:26:28.816+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="libsmsmessaging.cpp:3806">
< ![LOG[Formatted header:]LOG]!><time="11:26:28.816+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="libsmsmessaging.cpp:1500">
< ![LOG[<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>GUID:A7627241-0C11-451E-B066-2CC956B2FBD8</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2012-02-28T07:26:28Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="2114"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
]LOG]!><time="11:26:28.816+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="libsmsmessaging.cpp:1501">
< ![LOG[CLibSMSMessageWinHttpTransport::Send: URL: EMRHOSCCMGT.EMAAR.AE:80 CCM_POST /ccm_system/request]LOG]!><time="11:26:28.816+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="libsmsmessaging.cpp:7446">
< ![LOG[The request has succeeded. 200 OK]LOG]!><time="11:26:28.863+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="libsmsmessaging.cpp:7734">
< ![LOG[Execution::enExecutionFail != m_eExecutionResult, HRESULT=80004005 (e:\nts_sms_fre\sms\client\tasksequence\tsmanager\tsmanager.cpp,767)]LOG]!><time="11:28:31.869+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="tsmanager.cpp:767">
< ![LOG[Task Sequence Engine failed! Code: enExecutionFail]LOG]!><time="11:28:31.869+000" date="02-28-2012" component="TSManager" context="" type="3" thread="1348" file="tsmanager.cpp:767">
< ![LOG[****************************************************************************]LOG]!><time="11:28:31.869+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="tsmanager.cpp:789">
< ![LOG[Task sequence execution failed with error code 80004005]LOG]!><time="11:28:31.869+000" date="02-28-2012" component="TSManager" context="" type="3" thread="1348" file="tsmanager.cpp:790">
< ![LOG[Cleaning Up. Removing Authenticator]LOG]!><time="11:28:31.869+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="tsmanager.cpp:578">
< ![LOG[Clean up boot image stage path C:\_SMSTaskSequence\WinPE]LOG]!><time="11:28:31.869+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utils.cpp:1389">
< ![LOG[Cleaning up task sequence folder]LOG]!><time="11:28:32.447+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utils.cpp:1404">
< ![LOG[DeleteFileW(sVolumeIDFile.c_str()), HRESULT=80070002 (e:\nts_sms_fre\sms\framework\tscore\resolvesource.cpp,508)]LOG]!><time="11:28:33.164+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="resolvesource.cpp:508">
< ![LOG[successfully unregistered Task Sequencing Environment COM Interface.]LOG]!><time="11:28:33.258+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="environmentlib.cpp:869">
< ![LOG[set command line: "C:\Windows\system32\CCM\TsProgressUI.exe" /Unregister]LOG]!><time="11:28:33.258+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="commandline.cpp:707">
< ![LOG[Executing command line: "C:\Windows\system32\CCM\TsProgressUI.exe" /Unregister]LOG]!><time="11:28:33.258+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="commandline.cpp:805">
< ![LOG[Command line: "C:\Windows\system32\CCM\TsProgressUI.exe" /Unregister]LOG]!><time="11:28:33.804+000" date="02-28-2012" component="TsProgressUI" context="" type="0" thread="604" file="winmain.cpp:330">
< ![LOG[unregistering COM classes]LOG]!><time="11:28:33.804+000" date="02-28-2012" component="TsProgressUI" context="" type="1" thread="604" file="winmain.cpp:202">
< ![LOG[unregistering class objects]LOG]!><time="11:28:33.835+000" date="02-28-2012" component="TsProgressUI" context="" type="1" thread="604" file="winmain.cpp:503">
< ![LOG[shutdown complete.]LOG]!><time="11:28:33.835+000" date="02-28-2012" component="TsProgressUI" context="" type="1" thread="604" file="winmain.cpp:520">
< ![LOG[Process completed with exit code 0]LOG]!><time="11:28:33.835+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="commandline.cpp:1102">
< ![LOG[successfully unregistered TS Progress UI.]LOG]!><time="11:28:33.835+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utils.cpp:1963">
< ![LOG[Opening the task sequence key HKLM\Software\Microsoft\SMS\Task Sequence]LOG]!><time="11:28:34.147+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utils.cpp:3089">
< ![LOG[Deleting the package ID from registry key HKLM\Software\Microsoft\SMS\Task Sequence\Package]LOG]!><time="11:28:34.147+000" date="02-28-2012" component="TSManager" context="" type="1" thread="1348" file="utils.cpp:3095">
< ![LOG[kTaskSequence.DeleteValue(L"Package"), HRESULT=80070002 (e:\nts_sms_fre\sms\framework\tscore\utils.cpp,3099)]LOG]!><time="11:28:34.147+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:3099">
< ![LOG[Failed to delete registry value HKLM\Software\Microsoft\SMS\Task Sequence\Package. Error code 0x80070002]LOG]!><time="11:28:34.147+000" date="02-28-2012" component="TSManager" context="" type="2" thread="1348" file="utils.cpp:3099">
< ![LOG[start to cleanup TS policy]LOG]!><time="11:28:34.147+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2481">
< ![LOG[TS deleting 'CCM_ClientActions.PolicyID="{44aa0fb0-2d92-4a2d-9812-b0cc82079475}",PolicyInstanceID="{CB8B33D6-D361-47CE-937B-AE64BDC6A8AC}",PolicyRuleID="{4db6eaf3-9246-4ce5-8af4-e9cba263a45a}",PolicySource="CcmTaskSequence",PolicyVersion="16.00"'.]LOG]!><time="11:28:34.272+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_ClientActions.PolicyID="{44aa0fb0-2d92-4a2d-9812-b0cc82079475}",PolicyInstanceID="{1C62B792-B98E-42D9-978B-01ADC7D18E18}",PolicyRuleID="{4db6eaf3-9246-4ce5-8af4-e9cba263a45a}",PolicySource="CcmTaskSequence",PolicyVersion="16.00"'.]LOG]!><time="11:28:34.287+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_SystemHealthClientConfig.PolicyID="{6f0d9d6c-08c6-4c20-b391-7ac97b73e67e}",PolicyInstanceID="{B03DE448-10EC-4C1E-886A-F6D7A21721A3}",PolicyRuleID="{9afb0998-a3de-4fc7-af09-4e8f0f3f6a49}",PolicySource="CcmTaskSequence",PolicyVersion="1.00"'.]LOG]!><time="11:28:34.303+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_SystemHealthClientConfig.PolicyID="{6f0d9d6c-08c6-4c20-b391-7ac97b73e67e}",PolicyInstanceID="{1A303F6D-3511-435C-9217-4079A073D9F3}",PolicyRuleID="{9afb0998-a3de-4fc7-af09-4e8f0f3f6a49}",PolicySource="CcmTaskSequence",PolicyVersion="1.00"'.]LOG]!><time="11:28:34.350+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_SoftwareUpdatesClientConfig.PolicyID="{44aa0fb0-2d92-4a2d-9812-b0cc82079475}",PolicyInstanceID="{60758844-0FA3-4112-964B-A97F0A0BC8DE}",PolicyRuleID="{4db6eaf3-9246-4ce5-8af4-e9cba263a45a}",PolicySource="CcmTaskSequence",PolicyVersion="16.00"'.]LOG]!><time="11:28:34.350+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_SoftwareUpdatesClientConfig.PolicyID="{44aa0fb0-2d92-4a2d-9812-b0cc82079475}",PolicyInstanceID="{F231E516-2C4B-4079-B5F7-7801BA84D32B}",PolicyRuleID="{4db6eaf3-9246-4ce5-8af4-e9cba263a45a}",PolicySource="CcmTaskSequence",PolicyVersion="16.00"'.]LOG]!><time="11:28:34.381+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_SoftwareDistributionClientConfig.PolicyID="{28e5553e-4069-4942-a510-5779780e2989}",PolicyInstanceID="{24E4812A-148D-499D-A9AC-21DCF2BBD4E2}",PolicyRuleID="{f5d5f304-4a9d-4157-a8d3-a918cd1c7550}",PolicySource="CcmTaskSequence",PolicyVersion="3.00"'.]LOG]!><time="11:28:34.397+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_SoftwareDistributionClientConfig.PolicyID="{28e5553e-4069-4942-a510-5779780e2989}",PolicyInstanceID="{9052FBEC-CEA4-4C51-8874-B0E39A12FF7E}",PolicyRuleID="{f5d5f304-4a9d-4157-a8d3-a918cd1c7550}",PolicySource="CcmTaskSequence",PolicyVersion="3.00"'.]LOG]!><time="11:28:34.412+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_NetworkAccessAccount.PolicyID="{65ae98c8-096a-4acf-a8e4-2b1719fcb56d}",PolicyInstanceID="{AA619252-AC83-4C6E-B296-E6E542AE9349}",PolicyRuleID="{00891cea-76ac-4ace-b12a-9a2a67dc4e43}",PolicySource="CcmTaskSequence",PolicyVersion="6.00"'.]LOG]!><time="11:28:34.412+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_NetworkAccessAccount.PolicyID="{65ae98c8-096a-4acf-a8e4-2b1719fcb56d}",PolicyInstanceID="{A77CB429-BA7C-4F2A-997C-75966BC1B3A1}",PolicyRuleID="{00891cea-76ac-4ace-b12a-9a2a67dc4e43}",PolicySource="CcmTaskSequence",PolicyVersion="6.00"'.]LOG]!><time="11:28:34.428+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_Scheduler_ScheduledMessage.PolicyID="{44aa0fb0-2d92-4a2d-9812-b0cc82079475}",PolicyInstanceID="{8FA7C0CA-BD7A-4045-847C-0CF83B934368}",PolicyRuleID="{4db6eaf3-9246-4ce5-8af4-e9cba263a45a}",PolicySource="CcmTaskSequence",PolicyVersion="16.00"'.]LOG]!><time="11:28:34.443+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_Scheduler_ScheduledMessage.PolicyID="{44aa0fb0-2d92-4a2d-9812-b0cc82079475}",PolicyInstanceID="{6305AF4D-C828-4560-A703-48934782567B}",PolicyRuleID="{4db6eaf3-9246-4ce5-8af4-e9cba263a45a}",PolicySource="CcmTaskSequence",PolicyVersion="16.00"'.]LOG]!><time="11:28:34.443+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_Scheduler_ScheduledMessage.PolicyID="{44aa0fb0-2d92-4a2d-9812-b0cc82079475}",PolicyInstanceID="{FDE30BF8-10E0-462C-BB1C-D37711B804B7}",PolicyRuleID="{4db6eaf3-9246-4ce5-8af4-e9cba263a45a}",PolicySource="CcmTaskSequence",PolicyVersion="16.00"'.]LOG]!><time="11:28:34.443+000" date="02-28-2012" component="TSManager" context="" type="0" thread="1348" file="utils.cpp:2515">
< ![LOG[TS deleting 'CCM_Scheduler_ScheduledMessage.PolicyID="{44aa0fb0-2d92-4a2d-9812-b0cc82079475}",PolicyInstanceID="{43A2E
