zenodj Posted March 5, 2012 Report post Posted March 5, 2012 Hy everybody i have some question 1) i deploy sccm 2012 client using the wizard, i receive no error Last installation error : 0 Last request attempt is : 02/03/2012 13.29 Last status : complete if i go via remote desktop, i see "Software Center" but if i go to option i need to manually configure working hour and remote control ; i tap all that i need but receive "Software Center cannot be loaded. There is a problem loading the required components for software Center" i restart pc a lot of time 2) The remote support does not work 3) On sccm 2012 console this computer has "none" on client type but site code is correct some client are displayed correctly , client type is "Computer" , client activity "Active" and Remote Control works fine the computer are on same boundary, all settings are the same Can someone explain me where is the error? In attachment my client and remote configuration thank you in advance Quote Share this post Link to post Share on other sites More sharing options...
zenodj Posted March 15, 2012 Report post Posted March 15, 2012 ok... find the solution. If you have this, please check your Group Policy and put the new Site Code. After that all working fine Zeno Quote Share this post Link to post Share on other sites More sharing options...
