cgk4
Capture and Build Not Creating WIM
Trying to follow your guide on how to capture and build a Windows image... when I get to the step where I specify the location to save the file, I enter \\<server name>\sources\os\captures\install.wim and provide the administrator account and password. The create task sequence wizard says that it completed successfully, but the install.wim file is never created in the directory I told it to save to. Is there a log file I can look at to see what is going on here?
