juice13610
SQL related error when installing SCCM 2012
I have installed SQL Server 2008 R2, Service Pack 1, and Cumulative Update 4. I am still having issues that I have no idea where to begin because the error message is useless.
When I get to the "Database Information" page, I enter the name of the server (LAB-SCCM.COntoso.com) where SQL is installed, database name of "CM_CAS" which I assume is created on installation, and SSB port is 4022 (default).
I get this error;
"Configuration Manager sites require a support SQL Server version with required hotfixes for site database operation to succeed. Before Setup can continue, you must install a support version of SQL server on the specified site database server. For more information, see "
Thanks in advance
Joey
NOTE: Due to my issues, I have now removed everything related to SQL Server on the server. This is a lab environment by the way, so I Have no problem installing SQL on the actual server that SCCM resides on.
