JWishbone
SMS_MP_Control_Management Problems
Over the past 6 months we have been running the evaluation version of Config Manager, and everything had been working fine. But within the past 2 weeks we upgraded to the full version as the 6 months evaluation was coming to an end. Everything seemed to be working as normal but I noticed a problem when I couldnt manually install the Client onto a machine on the network. With some investigation I found that we have a error with our SMS_MP_Control_Manager, the error which is being displayed is:
'SMS Site Component Manager failed to install this component, because the Microsoft Installer File for this component (MP.msi) could not install.
Refer to the MPSetup.log, the MPMSI.log, as well as the SMS documentation and the Microsoft Knowledge Base'
and also
'SMS Site Component Manager failed to reinstall this component on this site system'
this is a brief look at our MPSetup Log
<03-19-2012 13:08:23> SMSMP Setup Started....
<03-19-2012 13:08:23> Parameters: C:\PROGRA~2\MIE096~1\bin\i386\ROLESE~1.EXE /install /siteserver:IT-MONITOR SMSMP
<03-19-2012 13:08:23> Installing Pre Reqs for SMSMP
<03-19-2012 13:08:23> ======== Installing Pre Reqs for Role SMSMP ========
<03-19-2012 13:08:23> Found 1 Pre Reqs for Role SMSMP
<03-19-2012 13:08:23> Pre Req MSXML60 found.
<03-19-2012 13:08:23> No versions of MSXML60 are installed. Would install new MSXML60.
<03-19-2012 13:08:23> Enabling MSI logging. msxml6_x64.msi will log to C:\Program Files (x86)\Microsoft Configuration Manager\logs\msxml6_x64MSI.log
<03-19-2012 13:08:24> Installing C:\Program Files (x86)\Microsoft Configuration Manager\bin\x64\00000409\msxml6_x64.msi
<03-19-2012 13:08:27> msxml6_x64.msi exited with return code: 1618
<03-19-2012 13:08:27> Backing up C:\Program Files (x86)\Microsoft Configuration Manager\logs\msxml6_x64MSI.log to C:\Program Files (x86)\Microsoft Configuration Manager\logs\msxml6_x64MSI.log.LastError
<03-19-2012 13:08:27> ======== Completed Installion of Pre Reqs for Role SMSMP ========
<03-19-2012 13:08:27> Installing the SMSMP
<03-19-2012 13:08:27> Passed OS version check.
<03-19-2012 13:08:28> IIS Service is installed.
<03-19-2012 13:08:28> checking WebDAV configuraitons
<03-19-2012 13:08:28> WebDAV is configured
<03-19-2012 13:08:28> SMSMP already installed (Product Code: {B391E30E-C8BD-41FC-8B8C-540C4365DBE0}). Upgrading/Reinstalling SMSMP
<03-19-2012 13:08:28> New SMSMP is the same product code. This is a minor upgrade.
<03-19-2012 13:08:28> Enabling MSI logging. mp.msi will log to C:\Program Files (x86)\Microsoft Configuration Manager\logs\mpMSI.log
<03-19-2012 13:08:28> Installing C:\Program Files (x86)\Microsoft Configuration Manager\bin\i386\mp.msi REINSTALL=ALL REINSTALLMODE=vmaus CCMINSTALLDIR="C:\Program Files (x86)\SMS_CCM" CCMSERVERDATAROOT="C:\Program Files (x86)\Microsoft Configuration Manager" USESMSPORTS=TRUE SMSPORTS=80 USESMSSSLPORTS=TRUE SMSSSLPORTS=443 USESMSSSL=TRUE SMSSSLSTATE=63 CCMENABLELOGGING=TRUE CCMLOGLEVEL=1 CCMLOGMAXSIZE=1000000 CCMLOGMAXHISTORY=1
<03-19-2012 13:08:31> mp.msi exited with return code: 1618
<03-19-2012 13:08:31> Backing up C:\Program Files (x86)\Microsoft Configuration Manager\logs\mpMSI.log to C:\Program Files (x86)\Microsoft Configuration Manager\logs\mpMSI.log.LastError
<03-19-2012 13:08:31> mp.msi could not be installed. The return code was 1618
I have read some previous posts with a similar problem but have yet to find a solution that works for us in any of them..HELP!
Thanks In Advance.
