JCA
VBScript and HTA to associate computer and add to specific collections
Hello everyone!
  1. Use IIS Pool for Authentication and not have Userid and Password in clear text. (Thank you Niall!)
  1. My goal is to allow a third party company to Migrate user state from XP to Windows 7 during our Windows 7 Migration project. Doing this tasks through SCCM console isn't worth it when the 3rd party staff will be changing during the project.
    I need to have the Source Computer and the Destination computer do the following when the "Create Computer Associatation" button is pushed.
    1. Add Source and Destination computer to the Computer Association in SCCM OSD
    2. Add Source Computer to the Collection I called Scanstate
    3. Add Destination Computer to the Collection I called Loadstate
The Computer Association Script that does work perfectly! ( I took this script from some ones blog and I added a little changes)
<html>
<head>
<title>USMT | Windows 7 Image</title>
<script language="VBScript">Window.ResizeTo 913,810</script>
<script language="VBScript">Window.MoveTo ((Screen.AvailWidth -913) / 2), 10</script>
<HTA:APPLICATION
ID="objOSDReg"
APPLICATIONNAME="OSD_Registration"
SINGLEINSTANCE="yes"
BORDER="thin"
ICON="Deploy.ico"
MAXIMIZEBUTTON="no"
MINIMIZEBUTTON="yes"
NAVIGABLE="yes"
</head>
<script LANGUAGE="VBScript">
'Set Variables: Site Server, Username and Password
Server = "sccm server name"
userName = "userid"
userPassword = "password"
Sub AssociateCompAandCompB
Dim computera, computerb, ResIDA, ResIDB
 strcomputera = document.getElementById("computera").value
 strcomputerb = document.getElementById("computerb").value
Set connection = Connect(Server, userName, userPassword)
ResIDA = GetResourceIDFromName (connection, strcomputera)
ResIDB = GetResourceIDFromNameB (Connection, strcomputerb)
AssociateComputer Connection, ResIDA, ResIDB', ResIDA, ResIDB
End Sub
' Associate Computers in SCCM Computer Association
Sub AssociateComputer(connection, referenceComputerResourceId, destinationComputerResourceId)
Dim stateMigrationClass
Dim inParams
Dim outParams
 'On Error Resume Next
' Get the state migration class.
Set stateMigrationClass = connection.Get("SMS_StateMigration")
' Set up the parameters.
Set inParams = _
 	stateMigrationClass.Methods_("AddAssociation").InParameters.SpawnInstance_
inParams.SourceClientResourceID = referenceComputerResourceId
inParams.RestoreClientResourceID = destinationComputerResourceId
  ' Call the method
Set outParams = connection.ExecMethod( "SMS_StateMigration","AddAssociation",inParams)
'connection.ExecMethod stateMigrationClass.AddAssociation,inParams
  ' MsgBox Err
if Err.number <> 0 Then
   	MsgBox "Failed to create a Computer Association, please try again or contact the GOC"
   	Exit Sub
   	Else
   	General_OnClick()
End If
  End Sub
' Utility function to search for the site code
Function Connect(server, userName, userPassword)
Dim net
Dim localConnection
Dim swbemLocator
Dim swbemServices
Dim providerLoc
Dim location
Set swbemLocator = CreateObject("WbemScripting.SWbemLocator")'
swbemLocator.Security_.AuthenticationLevel = 6 'Packet Privacy.
' If the server is local, don't supply credentials.
Set net = CreateObject("WScript.NetWork")
If UCase(net.ComputerName) = UCase(server) Then
   	localConnection = True
   	userName = ""
   	userPassword = ""
   	server = "."
End If
' Connect to the server.
Set swbemServices= swbemLocator.ConnectServer _
       	(server, "root\sms",userName,userPassword)
If Err.Number<>0 Then
 	'  Wscript.Echo "Couldn't connect: " + Err.Description
   	Connect = Null
   	Exit Function
End If
' Determine where the provider is and connect.
Set providerLoc = swbemServices.InstancesOf("SMS_ProviderLocation")
   	For Each location In providerLoc
       	If location.ProviderForLocalSite = True Then
           	Set swbemServices = swbemLocator.ConnectServer _
    			(location.Machine, "root\sms\site_" + _
               	location.SiteCode,userName,userPassword)
   	'	Wscript.Echo "Couldn't connect:" + Err.Description
               	Connect = Null
               	Exit Function
   	Else
       	'Wscript.Echo "Yay, we connected!!"
           	End If
           	Set Connect = swbemServices
           	Exit Function
       	End If
   	Next
Set Connect = null ' Failed to connect.
End Function
Function GetResourceIDFromName(connection, strcomputera)
' Build Query string.
query = "SELECT ResourceId FROM SMS_R_System WHERE NetbiosName = """ & strcomputera & """"
' Execute the query
Set result = connection.ExecQuery(query)
If Err then
   	CheckError
   	'MsgBox "error on a"
   	Exit Function
End If
' Walk through the elements of the enumerator.
' Assume there will only be 1 computer with the requested name, if any.
resourceID = 0  ' Assume the worst
For each r in result
   	GetResourceIDFromName = r.ResourceID
'MsgBox r.resourceID
Next
End Function
Function GetResourceIDFromNameB(connection, strcomputerb)
query = "SELECT ResourceId FROM SMS_R_System WHERE NetbiosName = """ & strComputerB & """"
' Execute the query
If Err then
   	CheckError
   	Exit Function
End If
For each b in result
   	GetResourceIDFromNameB = b.ResourceID
   	'MsgBox b.resourceID
Next
End Function
Sub General_OnClick()
   	strHtm = "<table class=""tbl"">"
   	strHtm = strHtm & "<tr><td>_________________________</td><td>_________________</td></tr>"
   	strHtm = strHtm & "<tr><td>Source Computer        	</td><td>" & document.getElementById("computera").value & "</td></tr><tr></tr>"
   	strHtm = strHtm & "<tr><td>Destination Computer    	</td><td>" & document.getElementById("computerb").value & "</td></tr>"
       	strHtm = strHtm & "</table>"
   	'Next
   	dataarea.innerhtml = strHtm
End Sub
</SCRIPT>
<!--  HTML Starts        -->
<body style="font-family: Arial; background-image: url('Win7_wallpaper-blue2.jpg'); background-repeat: no-repeat; background-color: black; color: white;">
<!--OSD Registration Header-->
<table style="text-align: left; width: 100px;" border="0" cellpadding="2" cellspacing="2">
 <tbody>
<tr>
<td><big><big><big><big><span>    OSD</span></big></big></big></big></td>
 	<td style="text-align: right;"><span> powered<br> by</span></td>
 	<td><span><img style="width: 301px; height: 64px;" alt="System Center" src="file:logo-system-center.gif"></span></td>
</tr>
 </tbody>
</table>
<!--Line Break-->
<hr style="color:#00B2EE">
<!--Deployment Scenario Selection-->
<table align="center" width="90%">
 <tr><td>
 <h3>    Computer Association</h3>
 <!-- HTA Text Input Box for Computer A (Source)--><!-- HTA Text Input Box for Computer B (Destination)-->
  <p> 	Source Computer = <input type="text" id="ComputerA" size="18">  Destination Computer = <input type="text" id="ComputerB" size="18"></p>
 <!-- A - AssociateCompAandCompB --> <!-- Resets Page -->
 	<p> 	<input id=runbutton type="button" value="Create Computer Association" name="run_button"  onClick="AssociateCompAandCompB">
    	<input type="button" value="Reset Page" onClick="window.location.reload()"></p><BR>
</td></tr>
</table>
<!-- Display Data on HTA screen -->
<table align="center" width="85%">
 <tr><td>
  <!--Line Break-->
 	<div style="margin: 200px 130px 0px 0px; background-color: transparent; padding: 10px;">
 	<div> <hr style="color:#00B2EE">
 	<div> <h4>Computer Association Output<h4>
 	<div id="dataarea"></div>
 	</div>
 </td></tr>
</table>
<br><br>
<!--Version #-->
<small style="color: rgb(100,100,100)">  #1v1.0</small>
<table align="center" valign="center" width="100%">
<tr><big><big><span id="msgTXT"> </span></big></big><br></tr>
<tr style="color:red;"><big><big><span id="msgERR"> </span></big></big><br></tr>
</table>
</body>
</html>
7 answers to this question
Hmm... I don't really get your code and what you're trying to do... You already got the resourceID of the two machines and that's what you need, so I've got no clue what you are trying to achieve in this for For Each Computerselect in Computerlisting.Options
When you already have the resourceID you can just say newDirectRule.ResourceID = referenceComputerResourceId
Also, why two times a function that does the same... GetResourceIDFromName and GetResourceIDFromNameB....
Peter, I typicaly don't write VBscript and HTA. I didn't mean to leave the section of code "Add Computer to Scanstate and Loadstate Collections in SCCM" to the first post. I found the code on the internet and have tried to modify this to do what I need.
I'll keep you posted.
I fixed it and it's finish! Here's the code if anyone wants it.
<html>
<head>
<HTA:APPLICATION
ID="objOSDReg"
BORDER="thin"
ICON="Deploy.ico"
MAXIMIZEBUTTON="no"
NAVIGABLE="yes"
</head>
'Server = "XXXXXXXXX"
'userName = "XXXXXXXXX"
'userPassword = "XXXXXXXXX"
 Dim computera, computerb, ResIDA, ResIDB, sccmserver, server, userid, userName, pswd, userpassword
 Dim strSourceResourceID, strDestinationResourceID, strCaptureCollectionID, strRestoreCollectionID, objSMS
'Server = document.getElementById("sccmserver").value
'username = document.getElementById("userid").value
'userpassword = document.getElementById("pswd").value
strCaptureCollectionID = "OKE0033E"
strRestoreCollectionID = "OKE0033D"
' connection to SCCM server
Set objSMS = Connect(Server, userName, userpassword)
ResIDA = GetResourceIDFromName (objSMS, strcomputera)
ResIDB = GetResourceIDFromNameB (objSMS, strcomputerb)
	'AddtoCollection
 If (ResIDA <> 0) And (ResIDB <> 0) Then
  AssociateComputer objSMS, ResIDA, ResIDB
  AddtoCollection strcomputerA, ResIDA, strCaptureCollectionID
  AddtoCollection strcomputerb, ResIDB, strRestoreCollectionID
  Else
  General_OnClick()
 End If
End Sub
Sub AssociateComputer(objSMS, referenceComputerResourceId, destinationComputerResourceId)
Dim inParams
Dim outParams
Set stateMigrationClass = objSMS.Get("SMS_StateMigration")
Set inParams = _
' Call the method
Set outParams = objSMS.ExecMethod( "SMS_StateMigration","AddAssociation",inParams)
  ' MsgBox Err
   	MsgBox "Failed to create a Computer Association, please try again or contact the Windows Deployment Team Lead"
   	Exit Sub
   	Else
   	General_OnClick()
End If
  End Sub
'AddtoCollection(name, ResourceID, collectionID)
Sub AddtoCollection(name, ResourceID, collectionID)
'Sub AddtoCollection(connection, referenceComputerResourceId, destinationComputerResourceId)
 	'Dim instColl
 	'Dim instDirectRule
'if one exists create a collection rule
Set instColl = objSMS.Get("SMS_Collection.CollectionID="&"""" & collectionID & """")
Set instDirectRule = objSMS.Get("SMS_CollectionRuleDirect").SpawnInstance_ ()
instDirectRule.ResourceClassName = "SMS_R_System"
instDirectRule.ResourceID = ResourceID
instDirectRule.RuleName = name & " - " & ResourceID
instColl.AddMembershipRule instDirectRule , SMSContext
instColl.RequestRefresh False
' log name & " Added to " & Instcoll.Name
' wscript.echo(name & " Added to " & Instcoll.Name)
MsgBox (name & " Added to " & Instcoll.Name)
  ' MsgBox Err
   	Exit Sub
   	Else
   	General_OnClick()
End If
End Sub
	Dim net
Dim localConnection
Dim swbemLocator
Dim swbemServices
Dim providerLoc
Dim location
'	Set net = CreateObject("WScript.NetWork")
'	If UCase(net.ComputerName) = UCase(server) Then
'    	localConnection = True
'    	userName = ""
'    	userPassword = ""
'    	server = "."
'	End If
   	Connect = Null
   	Exit Function
End If
               	Connect = Null
               	Exit Function
   	Else
           	End If
           	Exit Function
       	End If
   	Next
End Function
' GetResourceID From Name A
Function GetResourceIDFromName(objSMS, strcomputera)
' Execute the query
'Set result = connection.ExecQuery(query)
Set result = objSMS.ExecQuery(query)
If Err then
   	CheckError
   	Exit Function
End If
Next
End Function
' GetResourceID From Name B
Function GetResourceIDFromNameB(objSMS, strcomputerb)
' Execute the query
If Err then
   	CheckError
   	Exit Function
End If
Next
End Function
   	'Next
End Sub
</SCRIPT>
 <tbody>
<tr>
</tr>
 </tbody>
</table>
<!--Line Break-->
 <tr><td>
 <h3>    Server Connection</h3>
 <!-- HTA Text Input Box for Server-->
  <p>     Server:          <input type="text" id="sccmserver" size="18"><BR>
       UserName:   <input type="text" id="userid" size="18"><BR>
       Password:    <input type="password" id="pswd" size="18"></p>
 </td></tr>
</table>
 <tr><td> <BR>
  <p>     Source Computer:          <input type="text" id="ComputerA" size="15"><BR>
       Destination Computer:   <input type="text" id="ComputerB" size="15"></p>
	</td></tr>
</table>
 <tr><td>
  <!--Line Break-->
 	<div style="margin: 25px 100px 0px 0px; background-color: transparent; padding: 10px;">
 	</div>
 </td></tr>
</table>
<br><br>
<!--Version #-->
<small style="color: rgb(100,100,100)">  #1v1.1</small>
</table>
</body>
</html>
JCA, this looks awesome!
If I need to tweak this for my environment, where do I put the names in for my USMT Capture and Restore Collections?
Also, I'm not sure I understand where to use this tool.
Do I make this part of a Task Sequence as listed here (http://www.windows-n...display-my-hta/) then advertise it as a voluntary PXE advertisement to all of my systems? Then my tech guys just hit F12 for PXE boot and fill in the values on this HTA?
Thanks for posting this fantastic tool here, your peers thank you!
EDIT : I looked deeper into the matter, you would add this to your Task Sequence as one of the first steps.
I took this script and customized it to my environment. I changed it so that it will use the computer name of the computer it is running from as computer a, so the user only has to enter the destination computer. I also added an exit button.
I do have one problem though. The computer association gets created in SCCM, and the data is backed up to the SMP just fine. But, in the migrationstatus.xml that gets created, it has the same GUID for the source and destination computer, even though the SCCM console shows a computer association created with the correct source and destination computer names..
This causes the 'Request State Store' step on the data restore task sequence to fail. If I manually change the guid in the xml file to the correct guid of the destination computer, it completes perfectly..
