using SCCM 2012 RC in a LAB - Part 18. Deploying a UDI Client Task Sequence with MDT 2012 RC1 integrated in Configuration Manager 2012
Good Evening,
I was wondering if someone could help me? I have followed Labs 16 - 18 but but unfortunately my computer still will not join the domain.
Can someone please direct me to the proper log files to examine? I've copied all the log files from x:\windows\temp\smstslog and from x;\smstslog
After pressing F8, from the command prompt, I am able to ping the domain controller.
I don't get the Deployment Complete notification as per your instructions.
This also might be related ... I'm receiving a Application Discover warning message - "Critical problems were encountered while processing the Application Master List. The approprate applications may not be selected."
Let me know what other information you would need to assist? I've been working on this for a couple of days now and I have a hard deadline for next Friday to have this complete and functioning.
Your help would be greatly appreciated.
Thanks in advance!
if the machine is not joining the domain then check the c:\windows\debug\netsetup.log file for domain join failure reasons.
This is the netsetup.log. Any ideas? Again your help is much appreciated.
05/21/2015 09:21:51:344 -----------------------------------------------------------------
05/21/2015 09:21:51:344 NetpDoDomainJoin
05/21/2015 09:21:51:344 NetpDoDomainJoin: using new computer names
05/21/2015 09:21:51:359 NetpDoDomainJoin: NetpGetNewMachineName returned 0x0
05/21/2015 09:21:51:359 NetpMachineValidToJoin: 'MININT-JRA7BL9'
05/21/2015 09:21:51:359 OS Version: 6.3
05/21/2015 09:21:51:359 Build number: 9600 (9600.winblue_rtm.130821-1623)
05/21/2015 09:21:51:359 SKU:
05/21/2015 09:21:51:359 Architecture: 64-bit (AMD64)
05/21/2015 09:21:51:359 NetpGetLsaPrimaryDomain: status: 0x0
05/21/2015 09:21:51:359 NetpMachineValidToJoin: status: 0x0
05/21/2015 09:21:51:359 NetpJoinWorkgroup: joining computer 'MININT-JRA7BL9' to workgroup 'WORKGROUP'
05/21/2015 09:21:51:359 NetpValidateName: checking to see if 'WORKGROUP' is valid as type 2 name
05/21/2015 09:21:51:359 NetpCheckNetBiosNameNotInUse: for 'WORKGROUP' returned: 0x858
05/21/2015 09:21:51:359 NetpCheckNetBiosNameNotInUse for 'WORKGROUP' [ Workgroup as MACHINE] returned 0x858
05/21/2015 09:21:51:359 NetpValidateName: name 'WORKGROUP' is valid for type 2
05/21/2015 09:21:51:359 NetpSetLsaPrimaryDomain: for 'WORKGROUP' status: 0x0
05/21/2015 09:21:51:359 NetpJoinWorkgroup: status: 0x0
05/21/2015 09:21:51:359 NetpDoDomainJoin: status: 0x0
I'm using All Unknown Computers Device Collection. Could that have something to do with it? Permissions Issue? I do have full admin rights.
Thanks again.
I found this post online. The last two entries explain what the individual did to resolve his/her issue but I'm not sure how to configure my Task Sequence with his/her suggestions. Could his be the possible cause and solution?
https://social.technet.microsoft.com/Forums/en-US/faa4591d-b3f6-44ec-b450-339062d30a88/using-udi-to-join-domain?forum=mdt
if you use TeamViwer i can remote in and have a look at your task sequence and help you edit it, contact me offline for this > niall@ windows-noob .com
So it ended up being my WIM file all along. I replaced the Operating System with a stock Windows 7 Enterprise x64 install.wim and MDT/UDI worked and the computer joined the domain.
Question? Is there a way to customize and capture your WIM file with all your company's standard software, configuration and settings?
Thank you so much for your help!!!!!!!!!
