using SCCM 2012 RC in a LAB - Part 18. Deploying a UDI Client Task Sequence with MDT 2012 RC1 integrated in Configuration Manager 2012
  Quote
Question? Is there a way to customize and capture your WIM file with all your company's standard software, configuration and settings?
sure there is, you can build and capture in SCCM as described here
or do it with MDT as described by Johan and many others on Microsoft virtual academy
I opened this thread but so far have had no responses ... perhaps I should have posted in here :)
Having a nightmare getting the UDI applications to work!
http://www.windows-noob.com/forums/index.php?/topic/12539-deploying-apps-via-udi-issues/
Any help would be hugely appreciated, I'm about to give up on this entirely and just make a non-configurable ZTI deployment, which would not be as good but at least it would work !
