mqh7
SCCM 2012 won't connect to SQL 2008 R2
I am trying to install SCCM 2012. I kick off the splash.hta and run Install. I answer all of the question and then I get to the SQL dialog. Our SQL server is on a different box and it is running the following.
SQL Server 2008 R2
Windows Server 2008 R2 (64-bit)
When I’m on the “database information” dialog I have tried to enter both the SQL server name and the IP address, and I get two totally different errros.
If I enter the computer name of the SQL server I get this error:
Configuration manager sites require a support SQL server version with required hotfixes for site database operations to succeed.
But if I enter the IP address I get this error:
Setup is unable to connect to SQL server with the connection information provided.
1) Why the different errors?
2) What hotfixes do I need to make this work?
Thanks.
