wessberg
Problems with PXE
RequestMPKeyInformation: Send() failed. SMSPXE 2012-04-21 14:58:44 4484 (0x1184)
Failed to get information for MP: sccm.local 80004005. SMSPXE 2012-04-21 14:58:44 4484 (0x1184)
PXE::DB_InitializeTransport failed; 0x80004005 SMSPXE 2012-04-21 14:58:44 4484 (0x1184)
PXE::DB_ReportStatus failed; 0x80004005 SMSPXE 2012-04-21 14:58:44 4484 (0x1184)
PXE::CPolicyProvider::InitializeDatabaseConnection failed; 0x80004005 SMSPXE 2012-04-21 14:58:44 4484 (0x1184)
The certificate is gone, something strange happend to my lab-server. How can I solve this issue? How can I issue a certificate for the SCCM - SQL
Found out that my ssl-certificate is missing,
Unable to load user-specified certificate [Cert Hash(sha1) "4E40B3552FFAC833C5A30EB589008BBC557FF30E"]. The server will not accept a connection. You should verify that the certificate is correctly installed. See "Configuring Certificate for Use by SSL" in Books Online.
How can I re-create the certificate? Is there any chance I can do this from my CA ?
