Hi, I'm trying to expand a hyper-v environments drive. I use a program called "Replay4" for our backup's and it created a snapshot of the full C:/ drive. I imported it into hyper-v and time went on, my problem is now I need to expand the hard drive size. My problem is the whole "hard drive" is being used, or what the snapshot considered a full drive. So I'm wondering if there's a way in hyper-v to manipulate the drive so that it think's it's bigger then what it is? The partition that hyper-v is on is 6 terra so there's plenty of room to work with. So far I've tried diskpart.exe in command prompt but that didn't work because it viewed the whole drive as all ready being used. I've also tried going into the VM's settings and then going to the hard drive and going to edit, but i don't have the expand option that I would normally have with a standard VM since I imported this VM. So is there a way to expand it because the VM views it as an independent drive and not as part of a partition?
Hyper-V Server Stats - Windows Server 2008 R2 standard 64 bit (with all updates as of 4/23/12)
VM stats - Windows Server 2003 standard 32bit (all updates as of 4/23/12)
Thank you.
