tmiller_hockey
Using Only Remote Distribution Point
You can remove the distribution point role from the box you'd like it off of by going into site systems and removing the role. However, during installation of CM2012 you can opt not to install the distribution point in the first place, and just add it in after installation. I ended up virtualizing my primary site, but set the distribution point and pxe role to be on a physical server.
