using System Center 2012 Configuration Manager - Part 1. Installation - CAS
Hello ,
herewith I have listed the last set of log file .... appreciate if you could assist me further
MSI (s) (34:04) [00:25:36:453]: Product: ConfigMgr Management Point -- Installation operation failed.
MSI (s) (34:04) [00:25:36:453]: Windows Installer installed the product. Product Name: ConfigMgr Management Point. Product Version: 5.00.7958.1401. Product Language: 1033. Manufacturer: Microsoft Corporation. Installation success or error status: 1603.
MSI (s) (34:04) [00:25:36:453]: Deferring clean up of packages/files, if any exist
MSI (s) (34:04) [00:25:36:453]: MainEngineThread is returning 1603
MSI (s) (34:B4) [00:25:36:453]: RESTART MANAGER: Session closed.
MSI (s) (34:B4) [00:25:36:453]: No System Restore sequence number for this installation.
=== Logging stopped: 11/6/2014 0:25:36 ===
MSI (s) (34:B4) [00:25:36:453]: User policy value 'DisableRollback' is 0
MSI (s) (34:B4) [00:25:36:453]: Machine policy value 'DisableRollback' is 0
MSI (s) (34:B4) [00:25:36:453]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (34:B4) [00:25:36:453]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (34:B4) [00:25:36:453]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (34:B4) [00:25:36:453]: Destroying RemoteAPI object.
MSI (s) (34:84) [00:25:36:453]: Custom Action Manager thread ending.
MSI © (94:40) [00:25:36:453]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI © (94:40) [00:25:36:453]: MainEngineThread is returning 1603
=== Verbose logging stopped: 11/6/2014 0:25:36 ===
Hi, I have attached the fill log
MSI © (F8:78) [14:54:40:871]: Resetting cached policy values
MSI © (F8:78) [14:54:40:871]: Machine policy value 'Debug' is 0
MSI © (F8:78) [14:54:40:871]: ******* RunEngine:
******* Product: d:\Program Files\Microsoft Configuration Manager\bin\x64\mp.msi
******* Action:
******* CommandLine: **********
MSI © (F8:78) [14:54:40:872]: Client-side and UI is none or basic: Running entire install on the server.
MSI © (F8:78) [14:54:40:872]: Grabbed execution mutex.
MSI © (F8:78) [14:54:40:874]: Cloaking enabled.
MSI © (F8:78) [14:54:40:874]: Attempting to enable all disabled privileges before calling Install on Server
MSI © (F8:78) [14:54:40:874]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (04:98) [14:54:40:877]: Running installation inside multi-package transaction d:\Program Files\Microsoft Configuration Manager\bin\x64\mp.msi
MSI (s) (04:98) [14:54:40:877]: Grabbed execution mutex.
MSI (s) (04:24) [14:54:40:877]: Resetting cached policy values
MSI (s) (04:24) [14:54:40:877]: Machine policy value 'Debug' is 0
MSI (s) (04:24) [14:54:40:877]: ******* RunEngine:
******* Action:
MSI (s) (04:24) [14:54:40:878]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (04:24) [14:54:40:885]: Note: 1: 2203 2: C:\Windows\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (04:24) [14:54:40:888]: SRSetRestorePoint skipped for this transaction.
MSI (s) (04:24) [14:54:40:890]: File will have security applied from OpCode.
MSI (s) (04:24) [14:54:40:900]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'd:\Program Files\Microsoft Configuration Manager\bin\x64\mp.msi' against software restriction policy
MSI (s) (04:24) [14:54:40:900]: SOFTWARE RESTRICTION POLICY: d:\Program Files\Microsoft Configuration Manager\bin\x64\mp.msi has a digital signature
MSI (s) (04:24) [14:54:40:900]: SOFTWARE RESTRICTION POLICY: d:\Program Files\Microsoft Configuration Manager\bin\x64\mp.msi is permitted to run because the user token authorizes execution (system or service token).
MSI (s) (04:24) [14:54:40:900]: MSCOREE not loaded loading copy from system32
MSI (s) (04:24) [14:54:40:903]: End dialog not enabled
MSI (s) (04:24) [14:54:40:903]: Original package ==> d:\Program Files\Microsoft Configuration Manager\bin\x64\mp.msi
MSI (s) (04:24) [14:54:40:903]: Package we're running from ==> C:\Windows\Installer\1245d.msi
MSI (s) (04:24) [14:54:40:907]: APPCOMPAT: Compatibility mode property overrides found.
MSI (s) (04:24) [14:54:40:907]: APPCOMPAT: looking for appcompat database entry with ProductCode '{ACD1D219-6CF9-41EE-AFAB-5C7C4B2BDDE1}'.
MSI (s) (04:24) [14:54:40:907]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (04:24) [14:54:40:910]: Machine policy value 'TransformsSecure' is 1
MSI (s) (04:24) [14:54:40:910]: Note: 1: 2262 2: MsiFileHash 3: -2147287038
MSI (s) (04:24) [14:54:40:910]: Machine policy value 'DisablePatch' is 0
MSI (s) (04:24) [14:54:40:910]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (04:24) [14:54:40:910]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (04:24) [14:54:40:910]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (04:24) [14:54:40:911]: APPCOMPAT: looking for appcompat database entry with ProductCode '{ACD1D219-6CF9-41EE-AFAB-5C7C4B2BDDE1}'.
MSI (s) (04:24) [14:54:40:911]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (04:24) [14:54:40:911]: Transforms are not secure.
MSI (s) (04:24) [14:54:40:911]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'd:\Program Files\Microsoft Configuration Manager\logs\mpMSI.log'.
MSI (s) (04:24) [14:54:40:911]: Command Line: CCMINSTALLDIR=d:\Program Files\SMS_CCM CCMSERVERDATAROOT=d:\Program Files\Microsoft Configuration Manager USESMSPORTS=TRUE SMSPORTS=80 USESMSSSLPORTS=TRUE SMSSSLPORTS=443 USESMSSSL=TRUE SMSSSLSTATE=0 CCMENABLELOGGING=TRUE CCMLOGLEVEL=1 CCMLOGMAXSIZE=1000000 CCMLOGMAXHISTORY=1 CURRENTDIRECTORY=D:\Program Files\Microsoft Configuration Manager\bin\x64 CLIENTUILEVEL=3 MSICLIENTUSESEXTERNALUI=1 CLIENTPROCESSID=1016
MSI (s) (04:24) [14:54:40:911]: Product Code passed to Engine.Initialize: ''
MSI (s) (04:24) [14:54:40:911]: Product Code from property table before transforms: '{ACD1D219-6CF9-41EE-AFAB-5C7C4B2BDDE1}'
MSI (s) (04:24) [14:54:40:911]: Product Code from property table after transforms: '{ACD1D219-6CF9-41EE-AFAB-5C7C4B2BDDE1}'
MSI (s) (04:24) [14:54:40:911]: Product not registered: beginning first-time install
MSI (s) (04:24) [14:54:40:911]: Product {ACD1D219-6CF9-41EE-AFAB-5C7C4B2BDDE1} is not managed.
MSI (s) (04:24) [14:54:40:912]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (04:24) [14:54:40:912]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (04:24) [14:54:40:912]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (04:24) [14:54:40:912]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (04:24) [14:54:40:912]: Adding new sources is allowed.
MSI (s) (04:24) [14:54:40:912]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (04:24) [14:54:40:912]: Package name extracted from package path: 'mp.msi'
MSI (s) (04:24) [14:54:40:912]: Package to be registered: 'mp.msi'
MSI (s) (04:24) [14:54:40:913]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (04:24) [14:54:40:913]: Machine policy value 'DisableMsi' is 1
MSI (s) (04:24) [14:54:40:913]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (04:24) [14:54:40:913]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (04:24) [14:54:40:913]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (s) (04:24) [14:54:40:913]: Running product '{ACD1D219-6CF9-41EE-AFAB-5C7C4B2BDDE1}' with elevated privileges: Product is assigned.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CCMINSTALLDIR property. Its value is 'd:\Program Files\SMS_CCM'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CCMSERVERDATAROOT property. Its value is 'd:\Program Files\Microsoft Configuration Manager'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding USESMSPORTS property. Its value is 'TRUE'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding SMSPORTS property. Its value is '80'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding USESMSSSLPORTS property. Its value is 'TRUE'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding SMSSSLPORTS property. Its value is '443'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding USESMSSSL property. Its value is 'TRUE'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding SMSSSLSTATE property. Its value is '0'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CCMENABLELOGGING property. Its value is 'TRUE'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CCMLOGLEVEL property. Its value is '1'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CCMLOGMAXSIZE property. Its value is '1000000'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CCMLOGMAXHISTORY property. Its value is '1'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'D:\Program Files\Microsoft Configuration Manager\bin\x64'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding MSICLIENTUSESEXTERNALUI property. Its value is '1'.
MSI (s) (04:24) [14:54:40:913]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '1016'.
MSI (s) (04:24) [14:54:40:913]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (04:24) [14:54:40:914]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'e9dad9166983d844bad061c45f78f0ec'.
MSI (s) (04:24) [14:54:40:914]: RESTART MANAGER: Session opened.
MSI (s) (04:24) [14:54:40:914]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (s) (04:24) [14:54:40:914]: TRANSFORMS property is now:
MSI (s) (04:24) [14:54:40:914]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (04:24) [14:54:40:915]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming
MSI (s) (04:24) [14:54:40:916]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\Favorites
MSI (s) (04:24) [14:54:40:917]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (04:24) [14:54:40:918]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\Documents
MSI (s) (04:24) [14:54:40:918]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (04:24) [14:54:40:919]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (04:24) [14:54:40:920]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (04:24) [14:54:40:921]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (04:24) [14:54:40:921]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (04:24) [14:54:40:922]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Local
MSI (s) (04:24) [14:54:40:923]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\Pictures
MSI (s) (04:24) [14:54:40:924]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (04:24) [14:54:40:925]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (04:24) [14:54:40:926]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (s) (04:24) [14:54:40:927]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
MSI (s) (04:24) [14:54:40:928]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (04:24) [14:54:40:930]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (04:24) [14:54:40:931]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (04:24) [14:54:40:932]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Start Menu
MSI (s) (04:24) [14:54:40:933]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\Desktop
MSI (s) (04:24) [14:54:40:934]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (04:24) [14:54:40:934]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (s) (04:24) [14:54:40:935]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (04:24) [14:54:40:937]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (04:24) [14:54:40:938]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (04:24) [14:54:40:938]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (04:24) [14:54:40:938]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (04:24) [14:54:40:938]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Windows User'.
MSI (s) (04:24) [14:54:40:938]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\1245d.msi'.
MSI (s) (04:24) [14:54:40:938]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'd:\Program Files\Microsoft Configuration Manager\bin\x64\mp.msi'.
MSI (s) (04:24) [14:54:40:938]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (04:24) [14:54:40:938]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UI
MSI (s) (04:24) [14:54:40:938]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
MSI (s) (04:24) [14:54:40:938]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (04:24) [14:54:40:939]: Machine policy value 'DisableRollback' is 0
MSI (s) (04:24) [14:54:40:939]: User policy value 'DisableRollback' is 0
MSI (s) (04:24) [14:54:40:939]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
=== Logging started: 11/8/2014 14:54:40 ===
MSI (s) (04:24) [14:54:40:939]: Note: 1: 2203 2: C:\Windows\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (04:24) [14:54:40:940]: APPCOMPAT: [DetectVersionLaunchCondition] Launch condition already passes.
MSI (s) (04:24) [14:54:40:940]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (04:24) [14:54:40:940]: Doing action: INSTALL
Action start 14:54:40: INSTALL.
MSI (s) (04:24) [14:54:40:941]: Running ExecuteSequence
MSI (s) (04:24) [14:54:40:942]: Doing action: System64Folder.12C909B6_5F69_4C4D_8EC3_C225C1607933
MSI (s) (04:24) [14:54:40:942]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'System64Folder.12C909B6_5F69_4C4D_8EC3_C225C1607933'
MSI (s) (04:24) [14:54:40:942]: PROPERTY CHANGE: Adding System64Folder.12C909B6_5F69_4C4D_8EC3_C225C1607933 property. Its value is 'C:\Windows\system32\'.
Action start 14:54:40: System64Folder.12C909B6_5F69_4C4D_8EC3_C225C1607933.
MSI (s) (04:24) [14:54:40:943]: Doing action: SystemFolder.12C909B6_5F69_4C4D_8EC3_C225C1607933
Action ended 14:54:40: System64Folder.12C909B6_5F69_4C4D_8EC3_C225C1607933. Return value 1.
MSI (s) (04:24) [14:54:40:944]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SystemFolder.12C909B6_5F69_4C4D_8EC3_C225C1607933'
MSI (s) (04:24) [14:54:40:944]: PROPERTY CHANGE: Adding SystemFolder.12C909B6_5F69_4C4D_8EC3_C225C1607933 property. Its value is 'C:\Windows\SysWOW64\'.
Action start 14:54:40: SystemFolder.12C909B6_5F69_4C4D_8EC3_C225C1607933.
MSI (s) (04:24) [14:54:40:944]: Doing action: SystemFolder.A6940213_CD40_4753_8BA2_E803376DECC3
Action ended 14:54:40: SystemFolder.12C909B6_5F69_4C4D_8EC3_C225C1607933. Return value 1.
MSI (s) (04:24) [14:54:40:945]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SystemFolder.A6940213_CD40_4753_8BA2_E803376DECC3'
MSI (s) (04:24) [14:54:40:945]: PROPERTY CHANGE: Adding SystemFolder.A6940213_CD40_4753_8BA2_E803376DECC3 property. Its value is 'C:\Windows\SysWOW64\'.
Action start 14:54:40: SystemFolder.A6940213_CD40_4753_8BA2_E803376DECC3.
MSI (s) (04:24) [14:54:40:945]: Doing action: System64Folder.A6940213_CD40_4753_8BA2_E803376DECC3
Action ended 14:54:40: SystemFolder.A6940213_CD40_4753_8BA2_E803376DECC3. Return value 1.
MSI (s) (04:24) [14:54:40:946]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'System64Folder.A6940213_CD40_4753_8BA2_E803376DECC3'
MSI (s) (04:24) [14:54:40:946]: PROPERTY CHANGE: Adding System64Folder.A6940213_CD40_4753_8BA2_E803376DECC3 property. Its value is 'C:\Windows\system32\'.
Action start 14:54:40: System64Folder.A6940213_CD40_4753_8BA2_E803376DECC3.
MSI (s) (04:24) [14:54:40:946]: Doing action: SystemFolder.F65FD590_5BEA_48BE_8408_26F7244E8B61
Action ended 14:54:40: System64Folder.A6940213_CD40_4753_8BA2_E803376DECC3. Return value 1.
I am facing an issue after the installation.
it shows :
Site Component Manager failed to install this component on this site system.
MP Control Manager detected MPsetup has failed to create the CCM_Incoming Virtual Directory.
11/11/14 06:52:06> Backing up d:\Program Files\Microsoft Configuration Manager\logs\mpMSI.log to d:\Program Files\Microsoft Configuration Manager\logs\mpMSI.log.LastError
<11/11/14 06:52:06> Fatal MSI Error - mp.msi could not be installed.
Tried the below mentioned but still the issue is there. still I did not create boundaries since this issues arises.
<runtime>
<loadfromremotesources enabled="true"/>
</runtime>
hope your assistance .
best
Dnet
see
Hello My Name is Enrique and my problem is the next: I have Install SCCM 2012 in the Server 2012 whit SQL Server 2008 R" and taxes everything well set until Software Updates Point, The scenario presents WSUS role installed and configured , without selecting any products or upgrade for this to be set from the SCCM 2012 the version of WSUS is the 6.2.9200.16384. Now the instalation the rol in SCCM 2012 of Software Updates Point the selection the ports 8530, 8531, updates and products and the end is ok. But to start the sync does nothing to validate the following errors SCCM Shows.
I commented that all actions and do et seq nothing happened can someone help?
attachicon.gif1.jpgattachicon.gif2.jpgattachicon.gif3.jpgattachicon.gif4.jpgattachicon.gif5.jpgattachicon.gif6.jpgattachicon.gif7.jpgattachicon.gifL
Hello everyone, I believe this issue has not been resolved in this topic?
I just followed the instructions for server2012 with sql2012 from both http://prajwaldesai.com/installing-wsus-for-configuration-manager-2012-r2/and http://www.windows-noob.com/forums/index.php?/topic/9030-how-to-configure-wsus-on-sccm-2012-win-server-2012/#entry36655 (even removed both wsus and sup, rebooted, and manually removed the wsus db and iis website between installations), but unfortunately I still get the error that I need WSUS 3.0 .... :wacko:
Just as an update: I discovered that I was running SCCM2012, NOT 2012 SP1 or even R2...
I've upgraded the existing lab environtment to SP1, and after that to R2, and I just checked, the updates are now visible in SCCM.
For everyone's convience here's a blog to check your build # to check what version of SCCM 2012 you're running: http://sccmguy.com/2013/11/12/configuration-manager-2012-cumulative-updates-and-hotfixes/
BTW: unlike other MS SP's, this SP is a part of the full SCCM 2012 SP1 download. So if you want to upgrade from SCCM 2012 to SP1, or R2, you need to download the full SCCM 2012 SP1 download file, mount/extract the file, and use the installer to upgrade to SP1.
On ‎5‎/‎8‎/‎2012 at 8:08 PM, Rajiv said:
I have a question about step # 1. Why create all these accounts?
More specifically... I don't understand what is the need for this account - SMSadmin. Why not use a domain admin account for all these installs?
Hi Admin, Do we have complete set of hierarchy with CAS 2012R2 guide all in one zip pdf ? If so share the link please.
