ChrisV
Need VB script to copy a folder and contents in Task sequence
3 answers to this question
Here's a VBScript code snippet that might help:
strScriptFileDirectory = objFSO.GetParentFolderName(wscript.ScriptFullName)
WinDir = objWshShell.ExpandEnvironmentStrings("%windir%")
If objFSO.FileExists (strScriptFileDirectory & "\MyFile.txt") Then
objFSO.CopyFile (strScriptFileDirectory & "\MyFile.txt"), (WinDir & "\Folder1\SubFolder2\MyFile.txt"), True
End If
You'll need to mess with variables or drop back to hard-coded paths, but see if that helps get you started...
