agarofalo Posted April 30, 2012 Report post Posted April 30, 2012 We have over 100 remote sites connected with a 1.5mb connection. Currently, we use Zenworks for pc management. One feature we use is automatic re-imaging. When a remote computer needs to be re-imaged, we assign the task in zenworks. The computers are set to PXE boot first. When this job has been set, the pc boots, sees the task and completes it. This has been easy to reproduce with SCCM (We are migrating from Novell to Microsoft). The hard part is when the machine re-images, it applies the image from a second partition on the local hard drive. I can't figure out how to do this with SCCM. It takes too long to push the image over the network. Since we only have 3 to 5 users in each office, I can't justify a separate machine as a distribution point. Any help would be greatly appreciated. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted April 30, 2012 Report post Posted April 30, 2012 have you looked into the prestaged media function in R3 ? it might help you with your problem, here's some info about that Quote Share this post Link to post Share on other sites More sharing options...
agarofalo Posted June 25, 2012 Report post Posted June 25, 2012 Did anyone come up with a solution? This is good for a new PC, but I am talking about re-imaging existing ones. My TS has command lines that format and apply the prestaged image from the D partition, then it applies the bootsect and reboots. When it reboots, the TS starts all over. How do I tell the TS to pick up where it left off after a system reboot? Quote Share this post Link to post Share on other sites More sharing options...
