munta
Build and capture partition dependancy
Hi all. SCCM Noobie.
Can someone tell me if there is a direct correlation between the partition layout on the build and capture device and the partition layout on the OS target devices.
I am starting a build and capture and need to know if I should be worried about partitions or just worry about partitioning on the target machines after I have carried out the build and capture.
Jason.
