kvineets Posted May 21, 2012 Report post Posted May 21, 2012 hi I have spent several hours building the DC and trying to configure MP on it. DC part is fine, but SCCM installation is failing everytime, pre requisite check shows everything is fine. Oracle installation is also successful. I am not able to figure about the prob. please help error logs <05-20-2012 22:40:17> Found valid source for external dependency file 'msrdcoob_x86.exe' at 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\' <05-20-2012 22:40:17> Checking media: C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\i386\WindowsUpdateAgent30-x86.exe <05-20-2012 22:40:17> Verifying hash for file 'C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\i386\WindowsUpdateAgent30-x86.exe' <05-20-2012 22:40:17> File hash check failed for C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\i386\WindowsUpdateAgent30-x86.exe <05-20-2012 22:40:17> Checking alternate path: C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\WindowsUpdateAgent30-x86.exe <05-20-2012 22:40:17> Verifying hash for file 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\WindowsUpdateAgent30-x86.exe' <05-20-2012 22:40:17> Verifying signature for file 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\WindowsUpdateAgent30-x86.exe' <05-20-2012 22:40:35> Found valid source in folder: 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\' <05-20-2012 22:40:35> Found valid source for external dependency file 'WindowsUpdateAgent30-x86.exe' at 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\' <05-20-2012 22:40:35> Checking media: C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\i386\wmirdist.msi <05-20-2012 22:40:35> Verifying hash for file 'C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\i386\wmirdist.msi' <05-20-2012 22:40:35> File hash check failed for C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\i386\wmirdist.msi <05-20-2012 22:40:35> Checking alternate path: C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\wmirdist.msi <05-20-2012 22:40:35> Verifying hash for file 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\wmirdist.msi' <05-20-2012 22:40:35> Verifying signature for file 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\wmirdist.msi' <05-20-2012 22:41:35> Found valid source in folder: 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\' <05-20-2012 22:41:35> Found valid source for external dependency file 'wmirdist.msi' at 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\' <05-20-2012 22:41:35> Checking media: C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\ccmsetup.cab <05-20-2012 22:41:35> Verifying hash for file 'C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\ccmsetup.cab' <05-20-2012 22:41:35> File hash check failed for C:\TEMP\CONFIGMGR07SP2EVAL_RTM_ENU\SMSSETUP\Client\ccmsetup.cab <05-20-2012 22:41:35> Checking alternate path: C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\ccmsetup.cab <05-20-2012 22:41:35> Verifying hash for file 'C:\TEMP\ConfigMgr07SP2Eval_RTM_ENU\Update\ccmsetup.cab' <05-20-2012 22:41:35> File hash check failed: 0x80070002 <05-20-2012 22:41:35> VerifyExternalFile failed: 0x80070002 <05-20-2012 22:41:35> Failed to find valid source for required external file <05-20-2012 22:41:35> Unable to find valid source for required file 'ccmsetup.cab'. Aborting setup. <05-20-2012 22:41:35> Setup has encountered fatal errors while performing file operations. Quote Share this post Link to post Share on other sites More sharing options...
Eswar Koneti Posted May 21, 2012 Report post Posted May 21, 2012 VerifyExternalFile failed: 0x80070002 means The system cannot find the file specified. ensure you have used the correct source path with right version of SCCM updates files. hash check failed happens with incorrect update files Quote Share this post Link to post Share on other sites More sharing options...
kvineets Posted May 22, 2012 Report post Posted May 22, 2012 Finally got it all up and running Quote Share this post Link to post Share on other sites More sharing options...
