using System Center 2012 Configuration Manager - Part 3. Configuring Discovery and Boundaries
  Quote
Dear sir, please tell me the difference between CAS,PS & Secondary site . I am not able to understand diff between them clearly.
without going into details i'll reply in a very short version indeed:-
a CAS is only required if you want to support over 100,000 clients or need a hierarchy of primary sites (that means, more than one primary)
a PS is a Primary and is required to support the functions necessary for normal operations
a Secondary site is generally used to 'offload' the load on a wan (for example) when you have say 3000 or so clients at a remote location and don't want policy requests going over the wan to the primary, instead, they (the policy requests) will go to the secondary site.
for more information about all those different options refer to the Technet links i posted in part 1 of this guide pasted below for your pleasure:
Technet Recommended Reading:-
Release Notes for System Center 2012 Configuration Manager- http://technet.micro...y/jj870706.aspx
Fundamentals of Configuration Manager - http://technet.micro...y/gg682106.aspx
Supported Configurations for Configuration Manager - http://technet.micro...y/gg682077.aspx
Planning for Configuration Manager Sites and Hierarchy - http://technet.micro...y/gg682075.aspx
Example Scenarios for planning a simplified Hierarchy - http://technet.micro...y/gg712989.aspx
Site and Role Scalability - http://technet.micro...iteAndRoleScale
Getting Started with Configuration Manager 2012 - http://technet.micro...y/gg682144.aspx
What’s New in Configuration Manager - http://technet.micro...y/gg699359.aspx
Planning for Site Systems in Configuration Manager - http://technet.micro...y/gg712282.aspx
Install Sites and Create a Hierarchy for Configuration Manager - http://technet.micro...y/gg712320.aspx
Technical Reference for Site Communications in Configuration Manager - http://technet.micro...y/gg712990.aspx
Migrating from Configuration Manager 2007 to Configuration Manager 2012 - http://technet.micro...y/gg682006.aspx
Frequently Asked Questions for Configuration Manager - http://technet.micro...y/gg682088.aspx
