Ismail haider Posted October 29, 2008 Report post Posted October 29, 2008 need Some help I have 2 Systems on networks System 'A' and Syste, 'B'. On Systems 'A', I have Installed Windoes Server 2008 and Sme Applications. I Watnt this Configuration On System 'B' and want automated Process how I do this with MDT 2008,what are the steps . If I make a image on Systems 'A', Is it comitable with my Systems B. Which tools are Requried, Kindly tell Step by step Thanks. Quote Share this post Link to post Share on other sites More sharing options...
alaa_elmahdy Posted February 26, 2009 Report post Posted February 26, 2009 how I do this with MDT 2008,what are the steps . If I make a image on Systems 'A', Is it comitable with my Systems B. Which tools are Requried, Kindly tell Step by step Thanks. Dear ismail, you shuld have a look to this microsoft guid about the tool, http://www.microsoft.com/Downloads/details...;displaylang=en also other way to deploy windows is illustrated in details in here. http://briandesmond.com/blog/how-to-sysprep-in-windows-2008/ thanks. wish it helps solving your problem. Quote Share this post Link to post Share on other sites More sharing options...
