dinozoff Posted June 4, 2012 Report post Posted June 4, 2012 Hi, I just installed sccm2012 on Windows2008R2 and a remote SQL server (2008R2). My problem is I can't get the Package Conversion Tool to work. Everytime I run Convert Package (after analyzing) I get an error. (see SMSProv.log and PMTrace.log) I tried different packages (manual and automatic status). None of it will work. On my testenvironment it worked perfectly. As far as I can see my SQL security is also correct. SCCM is installed on a separate instance in SQL. Can someone help. Thanks PcmTrace.log SMSProv.log Quote Share this post Link to post Share on other sites More sharing options...
