hans.swolfs
Problems inserting LAN-drivers into Bootimage
hey all,
i'm trying to figure out why I can't seem to inject a couple of LAN-drivers from our new desktop-mainboards into my SCCM bootimages. Since the LAN-drivers aren't known, it won't run any TS off course.
I have tried to use the built-in bootimage that comes with SCCM and I also created a new one per instructions found on www.ithastobecool.com.
When I inject the drivers and want to update my DP, I get this error in the end :
Error: The wizard detected the following problems when updating the boot image.
Failed to inject a ConfigMgr driver into the mounted WIM file
The ConfigMgr Provider reported an error.: ConfigMgr Error Object:
instance of SMS_ExtendedStatus
Description = "Failed to insert OSD binaries into the WIM file";
ErrorCode = 2152205056;
File = "c:\\qfe\\nts_sms_fre\\sms\\siteserver\\sdk_provider\\smsprov\\sspbootimagepackage.cpp";
Line = 4262;
ObjectInfo = "CSspBootImagePackage::PreRefreshPkgSrcHook";
Operation = "ExecMethod";
ParameterInfo = "SMS_BootImagePackage.PackageID=\"SJB0001D\"";
ProviderName = "WinMgmt";
StatusCode = 2147749889;
Any thoughts?
cheers!
