Kinom
problem deploying Vista with a task sequence.
Hallo everybody :rolleyes:
I’m new at this and I hope that someone can help me with this problem.
I’m working 2 days now on this one and I can’t figure it out <_<
I have a problem deploying Vista with a task sequence.
I imported the vista .wim file and drivers for a HP 8710w, so far so good :lol: .
I create the task sequence with te wizard and everything is ok, I added some programs en I advertised it to the collection.
The collection is also ok
I boot the laptop and it starts to run the PXE and installs Vista, at a certain time after applying the drivers from the driver package he start applying the SCCM client, then it reboots and start configuring Vista.
At the first time I taught it was ok but it did not install the SCCM client and the rest of the software.
I taught, it will reboot and resume with the task sequence but it did not.
Can someone help? :(
  anyweb said:
can you post the SMSTS.log file which is most likely DATED in the filename
look in c:\windows\system32\ccm\logs
At the moment I did not find it but I found something else in the Status summery of a specific task sequence advertisement.
Maybe you can understand it.
ce\Packages\F0100069 before releasing Delete source directory C:\_SMSTaskSequence\Packages\F0100069 Released the resolved source C:\_SMSTaskSequence\Packages\F0100069 Exiting ConfigureEx: 0x00000000 Process completed with exit code 0 Installing hookto 'C:\WINDOWS' Command line for extension .EXE is "%1" %* Set command line: "X:\sms\bin\i386\OSDSETUPHOOK.EXE" "/install:C:\WINDOWS" /version:6.0 Executing command line: "X:\sms\bin\i386\OSDSETUPHOOK.EXE" "/install:C:\WINDOWS" /version:6.0 InstallingOSD setup hook Setup hook install completed successfully Process completed with exit code 0 OfflineRegistry::Init("C:\WINDOWS") Loading offline registry hive "C:\WINDOWS\system32\config\software" into HKLM\OfflineRegistry1 Loading offline registry hive "C:\WINDOWS\system32\config\system" into HKLM\OfflineRegistry2 CurrentControlSet is mapped to ControlSet001 SMS Client is not installed Unloading offline SOFTWARE registry hive Unloading offline SYSTEM registry hive Exiting with code 0x00000000
Here is it, all of it.
LOGGING: Finalize process ID set to 856 TSBootShell 5/11/2008 18:59:13 860 (0x035C)
==============================[ TSBootShell.exe ]============================== TSBootShell 5/11/2008 18:59:13 860 (0x035C)
Succeeded loading resource DLL 'X:\sms\bin\i386\1033\TSRES.DLL' TSBootShell 5/11/2008 18:59:13 860 (0x035C)
Debug shell is enabled TSBootShell 5/11/2008 18:59:13 860 (0x035C)
Waiting for PNP initialization... TSBootShell 5/11/2008 18:59:13 884 (0x0374)
Booted from network (PXE) TSBootShell 5/11/2008 18:59:13 884 (0x0374)
Found config path X:\sms\data\ TSBootShell 5/11/2008 18:59:13 884 (0x0374)
Booting from removable media, not restoring bootloaders on hard drive TSBootShell 5/11/2008 18:59:13 884 (0x0374)
Executing command line: wpeinit.exe -winpe TSBootShell 5/11/2008 18:59:13 884 (0x0374)
The command completed successfully. TSBootShell 5/11/2008 18:59:32 884 (0x0374)
Starting DNS client service. TSBootShell 5/11/2008 18:59:32 884 (0x0374)
Executing command line: X:\sms\bin\i386\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\ TSBootShell 5/11/2008 18:59:32 884 (0x0374)
==============================[ TSMBootStrap.exe ]============================== TSMBootstrap 5/11/2008 18:59:32 1284 (0x0504)
Command line: X:\sms\bin\i386\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\ TSMBootstrap 5/11/2008 18:59:32 1284 (0x0504)
Succeeded loading resource DLL 'X:\sms\bin\i386\1033\TSRES.DLL' TSMBootstrap 5/11/2008 18:59:32 1284 (0x0504)
Succeeded loading resource DLL 'X:\sms\bin\i386\TSRESNLC.DLL' TSMBootstrap 5/11/2008 18:59:32 1284 (0x0504)
Processor Is IA64: 0 TSMBootstrap 5/11/2008 18:59:32 1284 (0x0504)
PXE Boot with Root = X:\ TSMBootstrap 5/11/2008 18:59:32 1284 (0x0504)
Executing from PXE in WinPE TSMBootstrap 5/11/2008 18:59:32 1284 (0x0504)
Loading TsPxe.dll from X:\sms\bin\i386\TsPxe.dll TSMBootstrap 5/11/2008 18:59:32 1284 (0x0504)
TsPxe.dll loaded TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Device has PXE booted TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Variable Path: \SMSTemp\2008.11.05.18.57.44.0023.{71090696-4898-4481-8B5F-A0D9F2D109B4}.boot.var TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Variable Key Len: 61 TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Succesfully added firewall rule for Tftp TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Executing: X:\sms\bin\i386\smstftp.exe -i 10.1.7.48 get \SMSTemp\2008.11.05.18.57.44.0023.{71090696-4898-4481-8B5F-A0D9F2D109B4}.boot.var X:\sms\data\variables.dat TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Command line for extension .exe is "%1" %* TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Set command line: "X:\sms\bin\i386\smstftp.exe" -i 10.1.7.48 get \SMSTemp\2008.11.05.18.57.44.0023.{71090696-4898-4481-8B5F-A0D9F2D109B4}.boot.var X:\sms\data\variables.dat TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Executing command line: "X:\sms\bin\i386\smstftp.exe" -i 10.1.7.48 get \SMSTemp\2008.11.05.18.57.44.0023.{71090696-4898-4481-8B5F-A0D9F2D109B4}.boot.var X:\sms\data\variables.dat TSPxe 5/11/2008 18:59:32 1284 (0x0504)
Process completed with exit code 0 TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Succesfully removed firewall rule for Tftp TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Successfully downloaded pxe variable file. TSPxe 5/11/2008 18:59:39 1284 (0x0504)
we are booted using PXE TSPxe 5/11/2008 18:59:39 1284 (0x0504)
we are booted using PXE and we use a generated password TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Loading Media Variables from "X:\sms\data\variables.dat" TSPxe 5/11/2008 18:59:39 1284 (0x0504)
CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sms_fre\sms\framework\smscrypt\windes.cpp,185) TSPxe 5/11/2008 18:59:39 1284 (0x0504)
SMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, wcslen(pszPassword)*sizeof(WCHAR), encryptedBuffer.getBuffer(), encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sms_fre\sms\framework\tscore\tsremovablemedia.cpp,386) TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Verifying media password. TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Found network adapter "Intel® 82566MM Gigabit Network Connection" with IP Address 10.1.12.80. TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Entering TSMediaWizardControl::GetPolicy. TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Environment scope "Global\{51A016B6-F0DE-4752-B97C-54E6F386A912}" successfully created TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Environment scope "Global\{BA3A3900-CA6D-4ac1-8C28-5073AFC22B03}" successfully created TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting LogMaxSize to 1000000 TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting LogMaxHistory to 1 TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting LogLevel to 0 TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting LogEnabled to 1 TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting LogDebug to 1 TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Loading variables from the Task Sequencing Removable Media. TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSMediaGuid TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSBootMediaPackageID TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSHTTPPort TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSHTTPSPort TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSIISSSLState TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSLaunchMode TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSMP TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSMPCerts TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSMPPort TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSMediaPFX TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSPublicRootKey TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSSiteCode TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSUseFirstCert TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSx64UnknownMachineGUID TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Setting _SMSTSx86UnknownMachineGUID TS environment variable TSPxe 5/11/2008 18:59:39 1284 (0x0504)
MP Public Certs=308201D930820146A003020102020F11EBD6D1FA918F43FD571FB5006D61300906052B0E03
021D0500302231123010060355040313094D502D5343434D3031310C300A06035504031303534D53
3
020170D3038303932383134333531335A180F32313038303930353134333531335A3022311230100
6
0355040313094D502D5343434D3031310C300A06035504031303534D5330819F300D06092A864886
F
70D010101050003818D0030818902818100A2FF1CBF743390B5B142810B41060A0BF20B8144C4F97
F
86EB20E9961C0FC61F685B9F6CE4156CC5275EAF2325420F66825CE16FC601FF1281B7FB05D2AD6D
7
0AFB6F42DCC0188B8DEE58B172668044FA227F891CF368143933D9C32A72927F77DF420C1D7D94B2
4
3BA74044FDB2E7A4A69BE5AC8E1C5CAFD379857BD6F98EC30203010001A317301530130603551D25
0
40C300A06082B06010401823765300906052B0E03021D0500038181003B623EA69A278FB3449B091
6
C032F291146D2CFE10BD6550E35DDEBA586C043DF4EE4727F3503E2340C1F4C10328A0F92F8ED141
8
3FF7B927DB091C7EFF7F711F72D36C09EF15F65A42C70C08170E0A7F4FCD53B35E8E69D61880DF2A
3
42CDE45D0282205394F800440D28417B063406AE3D08D7E61CDC49FAA714A9F6018AF4 TSPxe 5/11/2008 18:59:39 1284 (0x0504)
MP: server=MP-SCCM01.FERRANTI.BE, http=80, https=443, default=80 TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Root CA Public Certs= TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Missing root CA environment variable from variables file TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Custom hook from X:\\TSConfig.INI is TSPxe 5/11/2008 18:59:39 1284 (0x0504)
No custom hook found TSPxe 5/11/2008 18:59:39 1284 (0x0504)
No Need to create Authenticator Info TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Getting MP time information TSPxe 5/11/2008 18:59:39 1284 (0x0504)
Requesting client identity TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Formatted header: TSPxe 5/11/2008 18:59:40 1284 (0x0504)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>26735beb-e335-4b9c-9e9e-15f1b58af205</SourceID><SourceHost/><TargetAddress>mp:[http]MP_ClientIDManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-06T02:59:40Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="306"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>MP_ClientIDManager</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 CCM_POST /ccm_system/request TSPxe 5/11/2008 18:59:40 1284 (0x0504)
The request has succeeded. 200 OK TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Decompressing reply body. TSPxe 5/11/2008 18:59:40 1284 (0x0504)
::DecompressBuffer(65536) TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Decompression (zlib) succeeded: original size 403, uncompressed size 2436. TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Client identity reply: <ClientIDReply RequestReceivedTimeHigh="29966192" RequestReceivedTimeLow="1184410740" ReplySentTimeHigh="29966192" ReplySentTimeLow="1184410740" ReplyServerTimeZoneBias="-60" ReplyServerTimezoneStandardTimeHigh="31614544" ReplyServerTimezoneStandardTimeLow="31637280" ReplyServerTimeZoneStandardBias="0" ReplyServerTimezoneDaylightTimeHigh="31614544" ReplyServerTimezoneDaylightTimeLow="31637280" ReplyServerTimeZoneDaylightBias="-60" ReplyServerTimezoneStandardTimeYear="0" ReplyServerTimezoneStandardTimeMonth="10" ReplyServerTimezoneStandardTimeDayOfWeek="0" ReplyServerTimezoneStandardTimeDay="5" ReplyServerTimezoneStandardTimeHour="3" ReplyServerTimezoneStandardTimeMinute="0" ReplyServerTimezoneStandardTimeSecond="0" ReplyServerTimezoneStandardTimeMilliSeconds="0" ReplyServerTimezoneDaylightDateYear="0" ReplyServerTimezoneDaylightDateMonth="3" ReplyServerTimezoneDaylightDateDayOfWeek="0" ReplyServerTimezoneDaylightDateDay="5" ReplyServerTimezoneDaylightDateHour="2" ReplyServerTimezoneDaylightDateMinute="0" ReplyServerTimezoneDaylightDateSecond="0" ReplyServerTimezoneDaylightDateMilliSeconds="0" Unknown="0"><Identification><Machine><ClientID/><NetbiosName/></Machine></Identification></ClientIDReply>
-60 -60 TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Server time zone info: -60, , [0 10 0 5 3 0 0 0], 0, , [0 3 0 5 2 0 0 0], -60 TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Client Identity: TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Netbios name: TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Current time: 2008-11-06 02:59:40.077 TZ:Pacific Standard Time Bias:0480 TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Current time zone info: 480, Pacific Standard Time, [0 0 0 0 0 0 0 0], 0, , [0 0 0 0 0 0 0 0], 0 TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Adjusting the system time: -32399.039 seconds TSPxe 5/11/2008 18:59:40 1284 (0x0504)
Time zone info set to: -60, , [0 10 0 5 3 0 0 0], 0, , [0 3 0 5 2 0 0 0], -60 TSPxe 6/11/2008 3:59:40 1284 (0x0504)
New time: 2008-11-05 17:59:41.037 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Current time: 2008-11-05 17:59:41.037 TZ: Bias:-060 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Downloading policy from MP-SCCM01.FERRANTI.BE. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Initializing HTTP transport. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting URL = MP-SCCM01.FERRANTI.BE. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting Default Port = 80. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting SSL = false. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting CRL = false. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting Server Certificates. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting Media Certificate. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Preparing Client Identity Request. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting transport. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting SourceID = 26735beb-e335-4b9c-9e9e-15f1b58af205. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting site code = F01. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting SMBIOS GUID = 00000000-0000-0000-0000-000000000000. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Adding MAC Address 00:1E:EC:1D:0C:C2. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Executing Client Identity Request. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Requesting client identity TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Formatted header: TSPxe 5/11/2008 18:59:41 1284 (0x0504)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>26735beb-e335-4b9c-9e9e-15f1b58af205</SourceID><SourceHost/><TargetAddress>mp:[http]MP_ClientIDManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:41Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="412"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>MP_ClientIDManager</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 CCM_POST /ccm_system/request TSPxe 5/11/2008 18:59:41 1284 (0x0504)
The request has succeeded. 200 OK TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Decompressing reply body. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
::DecompressBuffer(65536) TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Decompression (zlib) succeeded: original size 472, uncompressed size 2580. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Client identity reply: <ClientIDReply RequestReceivedTimeHigh="29966192" RequestReceivedTimeLow="1188941990" ReplySentTimeHigh="29966192" ReplySentTimeLow="1188941990" ReplyServerTimeZoneBias="-60" ReplyServerTimezoneStandardTimeHigh="31738256" ReplyServerTimezoneStandardTimeLow="31896848" ReplyServerTimeZoneStandardBias="0" ReplyServerTimezoneDaylightTimeHigh="31738256" ReplyServerTimezoneDaylightTimeLow="31896848" ReplyServerTimeZoneDaylightBias="-60" ReplyServerTimezoneStandardTimeYear="0" ReplyServerTimezoneStandardTimeMonth="10" ReplyServerTimezoneStandardTimeDayOfWeek="0" ReplyServerTimezoneStandardTimeDay="5" ReplyServerTimezoneStandardTimeHour="3" ReplyServerTimezoneStandardTimeMinute="0" ReplyServerTimezoneStandardTimeSecond="0" ReplyServerTimezoneStandardTimeMilliSeconds="0" ReplyServerTimezoneDaylightDateYear="0" ReplyServerTimezoneDaylightDateMonth="3" ReplyServerTimezoneDaylightDateDayOfWeek="0" ReplyServerTimezoneDaylightDateDay="5" ReplyServerTimezoneDaylightDateHour="2" ReplyServerTimezoneDaylightDateMinute="0" ReplyServerTimezoneDaylightDateSecond="0" ReplyServerTimezoneDaylightDateMilliSeconds="0" Unknown="0"><Identification><Machine><ClientID>GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F</ClientID><NetbiosName>LPT00092</NetbiosName></Machine></Identification></ClientIDReply>
-60 -60 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Server time zone info: -60, , [0 10 0 5 3 0 0 0], 0, , [0 3 0 5 2 0 0 0], -60 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Client Identity: GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Netbios name: LPT00092 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Client GUID = GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F, Netbios name = LPT00092, State = Known TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Preparing Policy Assignment Request. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting client ID = GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Executing Policy Assignment Request. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Sending RequestAssignments TSPxe 5/11/2008 18:59:41 1284 (0x0504)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F</SourceID><SourceHost/><TargetAddress>mp:[http]MP_PolicyManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:41Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="738"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>MP_PolicyManager</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
Decompression (zlib) succeeded: original size 4848, uncompressed size 33400. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Retrieving Policy Assignments: TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {8d474c52-3696-4286-b5b3-bb9877834124}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {69e548cb-0024-4632-a690-4597d98f2e30}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {97f07d3e-ae1e-48e5-8e54-e6b987b9da17}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {61645298-936e-4d46-b675-a2b7f62e1828}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {f1c42703-d02c-4636-a063-1bb95ba1f295}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {7e88a2a6-0ff0-4638-b272-ed18370583dc}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {49002381-ff1b-4440-ba2f-7f5214d3eae5}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {0b8ff6ce-fe50-4033-876e-140434ab29d3}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {0a3f2871-7b1c-465f-ace2-3821b10cf418}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {1c017124-f8ba-4ba6-853a-02038d6c995c}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {de6a103b-bfb7-4ea4-a567-9069d13ccd6e}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {734dd049-a1eb-4fd4-a4fe-37f83e3dc750}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {184591de-4fe6-49df-8164-a738ae0f25f0}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {b107f567-8087-44e6-88b3-e7c7f6f4e496}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {813a990f-6f36-4937-96d8-2d200991ba40}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {27ac87f2-1e55-4301-9d44-e7232c08d673}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {a629748d-8d50-4ee2-8c89-39c0332e5506}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {4618034f-df36-4f19-88c6-8646b6ef03d8}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {1734b8fe-ceeb-484b-a601-f236a6c0cd89}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {0028ed72-c714-417a-938a-e26be0e77339}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {e859638e-9f80-45ca-9284-188f5ac02eff}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment {f14db1fd-15c8-41f3-8275-e7121594be71}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment F0100024-{d8a54ab4-e6a0-4c52-acce-2c75b28f1ed1}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment F012004B-F010006B-DBBBC9D6. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment DEP-F012004B-F0100001-DBBBC9D6. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment DEP-F012004B-F010003E-DBBBC9D6. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Processing Policy Assignment DEP-F012004B-F010006D-DBBBC9D6. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Successfully read 27 policy assignments. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Downloading policy body F012004B-F010006B-DBBBC9D6. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Preparing Policy Body Request. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?F012004B-F010006B-DBBBC9D6.18_00. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Executing Policy Body Request. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?F012004B-F010006B-DBBBC9D6.18_00 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
found a secure policy TSPxe 5/11/2008 18:59:41 1284 (0x0504)
decoding policy TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Reading Policy Body. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Parsing Policy Body. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
This Task sequence is set for DownloadOnDemand TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Found mandatory advertisement F012004B TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Using mandatory advertisement F012004B TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Retrieving collection variable policy. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Downloading policy body F0100024-{d8a54ab4-e6a0-4c52-acce-2c75b28f1ed1}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?F0100024-{d8a54ab4-e6a0-4c52-acce-2c75b28f1ed1}.1_00. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Using Authenticator for policy TSPxe 5/11/2008 18:59:41 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?F0100024-{d8a54ab4-e6a0-4c52-acce-2c75b28f1ed1}.1_00 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Found 0 collection variables. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Retrieving machine variable policy. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Found 0 machine variables. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting machine/collection variables in the task sequencing environment. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Exiting TSMediaWizardControl::GetPolicy. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
No content source files for selected task sequence. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Getting policy for CCM_SoftwareDistribution[AdvertID=F012004B", PackageID="F0100001", ProgramID="*] TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Downloading policy body DEP-F012004B-F0100001-DBBBC9D6. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?DEP-F012004B-F0100001-DBBBC9D6.2_00. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?DEP-F012004B-F0100001-DBBBC9D6.2_00 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Getting content hash value for reference package F0100001 from policy TSPxe 5/11/2008 18:59:41 1284 (0x0504)
(__hrMethodRetVal == ((HRESULT)0L)) || (bFailIfMissing == false), HRESULT=80070002 (e:\nts_sms_fre\SMS\common\inc\ccmxml.h,566) TSPxe 5/11/2008 18:59:41 1284 (0x0504)
PackageHash.SDMPackage node not found in the policy assignment property PRG_Requirements. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Successfully resolved policy for F0100001. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Resolving content location for F0100001 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Getting network access account. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Downloading policy body {a629748d-8d50-4ee2-8c89-39c0332e5506}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{a629748d-8d50-4ee2-8c89-39c0332e5506}.2_00. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{a629748d-8d50-4ee2-8c89-39c0332e5506}.2_00 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Network Access Account has a non-empty value TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Getting multicast config. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Downloading policy body {f14db1fd-15c8-41f3-8275-e7121594be71}. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{f14db1fd-15c8-41f3-8275-e7121594be71}.1_00. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{f14db1fd-15c8-41f3-8275-e7121594be71}.1_00 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Multicast retry count: 3 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Multicast retry delay: 60 TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Getting local network information. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
GetAdaptersAddressess entry point is supported. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
DhcpGetOriginalSubnetMask entry point is supported. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Adapter {BA6BF4EF-693E-4740-BE75-76BF717ED5DA} is DHCP enabled. Checking quarantine status. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Executing content location request for F0100001:42 as GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Sending RequestContentLocations TSPxe 5/11/2008 18:59:41 1284 (0x0504)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F</SourceID><SourceHost/><TargetAddress>mp:[http]MP_LocationManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:41Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="608"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>MP_LocationManager</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
Decompression (zlib) succeeded: original size 502, uncompressed size 2232. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Filtering Content Locations. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Adding \\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F0100001\ to Local DP list. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Adding \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F0100001\ to Local DP list. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Found 0 DPs in subnet, 2 DPs in local site, 0 DPs in remote location and 0 Multicast DPs TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Shuffling HTTP local DP list. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Shuffling Local DP list. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Skipping remote content locations. TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Attempting to connect to \\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F0100001\ TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Deleting any existing network connections to "\\MP-SCCM01.FERRANTI.BE\*". TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Attempting to connect to "\\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F0100001". TSPxe 5/11/2008 18:59:41 1284 (0x0504)
Successfully connected to "\\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F0100001". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to \\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F0100001\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F0100001\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Deleting any existing network connections to "\\MP-SCCM01.FERRANTI.BE\*". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to "\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F0100001". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to "\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F0100001". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F0100001\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
F0100001 content location: \\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F0100001\,\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F0100001\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Getting policy for CCM_SoftwareDistribution[AdvertID=F012004B", PackageID="F010003E", ProgramID="*] TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body DEP-F012004B-F010003E-DBBBC9D6. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Preparing Policy Body Request. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting transport. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?DEP-F012004B-F010003E-DBBBC9D6.2_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Executing Policy Body Request. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Using Authenticator for policy TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?DEP-F012004B-F010003E-DBBBC9D6.2_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
The request has succeeded. 200 OK TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Reading Policy Body. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Parsing Policy Body. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Getting content hash value for reference package F010003E from policy TSPxe 5/11/2008 18:59:42 1284 (0x0504)
(__hrMethodRetVal == ((HRESULT)0L)) || (bFailIfMissing == false), HRESULT=80070002 (e:\nts_sms_fre\SMS\common\inc\ccmxml.h,566) TSPxe 5/11/2008 18:59:42 1284 (0x0504)
PackageHash.SDMPackage node not found in the policy assignment property PRG_Requirements. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully resolved policy for F010003E. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Resolving content location for F010003E TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Getting network access account. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Network Access Account has a non-empty value TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Getting multicast config. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Multicast retry count: 3 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Multicast retry delay: 60 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Getting local network information. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
IPv6 entry points already initialized. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
DHCP entry points already initialized. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Adapter {BA6BF4EF-693E-4740-BE75-76BF717ED5DA} is DHCP enabled. Checking quarantine status. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Executing content location request for F010003E:4 as GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Sending RequestContentLocations TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Formatted header: TSPxe 5/11/2008 18:59:42 1284 (0x0504)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F</SourceID><SourceHost/><TargetAddress>mp:[http]MP_LocationManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:42Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="606"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>MP_LocationManager</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 CCM_POST /ccm_system/request TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Decompressing reply body. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
::DecompressBuffer(65536) TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Decompression (zlib) succeeded: original size 502, uncompressed size 2230. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Filtering Content Locations. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Adding \\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F010003E\ to Local DP list. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Adding \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010003E\ to Local DP list. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Found 0 DPs in subnet, 2 DPs in local site, 0 DPs in remote location and 0 Multicast DPs TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Shuffling HTTP local DP list. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Shuffling Local DP list. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Skipping remote content locations. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010003E\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to "\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010003E". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to "\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010003E". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010003E\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to \\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F010003E\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to "\\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F010003E". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to "\\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F010003E". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to \\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F010003E\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
F010003E content location: \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010003E\,\\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F010003E\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Getting policy for CCM_SoftwareDistribution[AdvertID=F012004B", PackageID="F010006D", ProgramID="*] TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body DEP-F012004B-F010006D-DBBBC9D6. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?DEP-F012004B-F010006D-DBBBC9D6.1_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?DEP-F012004B-F010006D-DBBBC9D6.1_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Getting content hash value for reference package F010006D from policy TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully resolved policy for F010006D. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Resolving content location for F010006D TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Executing content location request for F010006D:1 as GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Decompression (zlib) succeeded: original size 505, uncompressed size 2232. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Adding \\MP-SCCM01.FERRANTI.BE\SMSPKGC$\F010006D\ to Local DP list. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Adding \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006D\ to Local DP list. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to \\MP-SCCM01.FERRANTI.BE\SMSPKGC$\F010006D\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to "\\MP-SCCM01.FERRANTI.BE\SMSPKGC$\F010006D". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to "\\MP-SCCM01.FERRANTI.BE\SMSPKGC$\F010006D". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to \\MP-SCCM01.FERRANTI.BE\SMSPKGC$\F010006D\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006D\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Attempting to connect to "\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006D". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to "\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006D". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully connected to \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006D\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
F010006D content location: \\MP-SCCM01.FERRANTI.BE\SMSPKGC$\F010006D\,\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006D\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
No need to register providers TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Registering the Progress UI. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Command line for extension .exe is "%1" %* TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Set command line: "X:\sms\bin\i386\TsProgressUI.exe" /Register:WinPE TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Executing command line: "X:\sms\bin\i386\TsProgressUI.exe" /Register:WinPE TSPxe 5/11/2008 18:59:42 1284 (0x0504)
==========[ TsProgressUI started in process 1480 ]========== TsProgressUI 5/11/2008 18:59:42 1484 (0x05CC)
Command line: "X:\sms\bin\i386\TsProgressUI.exe" /Register:WinPE TsProgressUI 5/11/2008 18:59:42 1484 (0x05CC)
Registering COM classes TsProgressUI 5/11/2008 18:59:42 1484 (0x05CC)
sbModulePath = X:\sms\bin\i386\TsProgressUI.exe TsProgressUI 5/11/2008 18:59:42 1484 (0x05CC)
Unregistering class objects TsProgressUI 5/11/2008 18:59:42 1484 (0x05CC)
Shutdown complete. TsProgressUI 5/11/2008 18:59:42 1484 (0x05CC)
Process completed with exit code 0 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully registered TS Progress UI. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Creating the Task Sequencing Environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting Media Variables in Task Sequencing Environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting WinPE Flag in the Task Sequencing Environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting Media Type Flag in the Task Sequencing Environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting Local Computer Name in the Task Sequencing Environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting Selected Task Sequence Information Task Sequencing Environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting selected task sequence information in the environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
::CompressBuffer(65536,-1) TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 22298, compressed size 2826. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting source for F0100001 to \\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F0100001\,\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F0100001\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting _SMSTSHTTPF0100001 to http://MP-SCCM01.FERRANTI.BE/SMS_DP_SMSPKGF$/F0100001/ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting _SMSTSPKGFLAGSF0100001 to 67108864 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 22258, compressed size 2815. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting source for F010003E to \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010003E\,\\MP-SCCM01.FERRANTI.BE\SMSPKGF$\F010003E\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting _SMSTSHTTPF010003E to http://MP-SCCM01.FERRANTI.BE/SMS_DP_SMSPKGF$/F010003E/ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting _SMSTSPKGFLAGSF010003E to 67108864 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 22754, compressed size 2917. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting source for F010006D to \\MP-SCCM01.FERRANTI.BE\SMSPKGC$\F010006D\,\\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006D\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting _SMSTSHTTPF010006D to http://MP-SCCM01.FERRANTI.BE/SMS_DP_SMSPKGC$/F010006D/ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting _SMSTSPKGFLAGSF010006D to 536870912 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Initializing the local data path. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
User did not specify local data drive TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Volume C:\ has 110539554816 bytes of free space TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Volume D:\ is not a fixed hard drive TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Volume X:\ is not a fixed hard drive TSPxe 5/11/2008 18:59:42 1284 (0x0504)
TSM root drive = C:\ TSPxe 5/11/2008 18:59:42 1284 (0x0504)
C:\_SMSTaskSequence does not exist TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Creating directory C:\_SMSTaskSequence TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Updated security on object C:\_SMSTaskSequence. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting Task Sequence User State Path to "%_SMSTSMDataPath%\UserState". TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting Network Access Account Information in Task Sequencing Environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body {b107f567-8087-44e6-88b3-e7c7f6f4e496}. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{b107f567-8087-44e6-88b3-e7c7f6f4e496}.2_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{b107f567-8087-44e6-88b3-e7c7f6f4e496}.2_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body {813a990f-6f36-4937-96d8-2d200991ba40}. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{813a990f-6f36-4937-96d8-2d200991ba40}.2_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{813a990f-6f36-4937-96d8-2d200991ba40}.2_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Found property CCM_ClientAgentConfig.BrandingTitle = Ferranti Computer Systems TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting Client ID in Task Sequencing Environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting machine name from SMS database. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting SysHealthConfig policy in the environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body {4618034f-df36-4f19-88c6-8646b6ef03d8}. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{4618034f-df36-4f19-88c6-8646b6ef03d8}.1_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{4618034f-df36-4f19-88c6-8646b6ef03d8}.1_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 6152, compressed size 904. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting SoftUpdConfig policy in the environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body {184591de-4fe6-49df-8164-a738ae0f25f0}. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{184591de-4fe6-49df-8164-a738ae0f25f0}.6_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{184591de-4fe6-49df-8164-a738ae0f25f0}.6_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 6784, compressed size 910. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting SoftDistClient config policy in the environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body {27ac87f2-1e55-4301-9d44-e7232c08d673}. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{27ac87f2-1e55-4301-9d44-e7232c08d673}.2_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{27ac87f2-1e55-4301-9d44-e7232c08d673}.2_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 14462, compressed size 1385. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting software update policy in the environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Bad zlib compression ratio: original size 32, compressed size 38. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body {8d474c52-3696-4286-b5b3-bb9877834124}. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{8d474c52-3696-4286-b5b3-bb9877834124}.5_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{8d474c52-3696-4286-b5b3-bb9877834124}.5_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 372, compressed size 187. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting quarantine policy in the environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Downloading policy body {69e548cb-0024-4632-a690-4597d98f2e30}. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting policy location = http://<mp>/SMS_MP/.sms_pol?{69e548cb-0024-4632-a690-4597d98f2e30}.1_00. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 GET /SMS_MP/.sms_pol?{69e548cb-0024-4632-a690-4597d98f2e30}.1_00 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 2274, compressed size 570. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting NAAConfig policy in the environment. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Compression (zlib) succeeded: original size 3004, compressed size 804. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Launch mode is: PXE TSPxe 5/11/2008 18:59:42 1284 (0x0504)
BootpackageID: F0100001 AssociatedWInPE: F0100001 SourceVersion: 42 AssociatedSourceVersion: 42 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
WinPE assocated with task sequence is the same as the boot media. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Setting time zone info to TSPxe 5/11/2008 18:59:42 1284 (0x0504)
No TimeZone information to set. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
No pre-execution hook found TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Starting Task Sequence Manager. TSPxe 5/11/2008 18:59:42 1284 (0x0504)
executing TS Manager not in full media TSPxe 5/11/2008 18:59:42 1284 (0x0504)
executing TS Manager in x:\sms\bin\i386 TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Set command line: "TsManager.exe" TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Executing command line: "TsManager.exe" TSPxe 5/11/2008 18:59:42 1284 (0x0504)
Successfully intialized Logging for TS Manager. TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Commandline: "TsManager.exe" TSManager 5/11/2008 18:59:42 1500 (0x05DC)
/service parameter found at index: -1 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
/standalone parameter found at index: -1 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
/noclient parameter found at index: -1 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Successfully registered Task Sequencing COM Interface. TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Executing as a standalone exe TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Initializing TS Environment TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Opening Task Sequencing Environment TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Env variable _SMSTSProtectedPaths set to %OSDStateStorePath%;%_SMSTSClientCache%;%_SMSTSNewClientCachePathToCleanup% TSManager 5/11/2008 18:59:42 1500 (0x05DC)
!sVolumeID.empty(), HRESULT=80004005 (e:\nts_sms_fre\sms\framework\tscore\resolvesource.cpp,472) TSManager 5/11/2008 18:59:42 1500 (0x05DC)
DeleteFileW(sVolumeIDFile.c_str()), HRESULT=80070002 (e:\nts_sms_fre\sms\framework\tscore\resolvesource.cpp,513) TSManager 5/11/2008 18:59:42 1500 (0x05DC)
pwszPath && *pwszPath, HRESULT=80070057 (e:\nts_sms_fre\sms\framework\tscore\resolvesource.cpp,249) TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Executing in WinPE TSManager 5/11/2008 18:59:42 1500 (0x05DC)
_SMSTSReturnToGINA variable set to TSManager 5/11/2008 18:59:42 1500 (0x05DC)
No SMS client installed or in standalone mode. Skipping remediation check. TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Initializing TS Engine TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Getting TaskSequenceXML from environment TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing task sequence . . . TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Loaded TS from string TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing task sequence to get schema version TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Task sequence version 3.00 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Task sequence schema version is 3.00 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Current supported schema version is 3.10 and 3.00 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Processing get action table request TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Got root node now getting list of all child elements TSManager 5/11/2008 18:59:42 1500 (0x05DC)
There are 2 first level steps or groups TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Processing group TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing group node: Install Operating System TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: Actions to run in Windows PE to install and configure the image TSManager 5/11/2008 18:59:42 1500 (0x05DC)
ContinueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Disable: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
(__hrMethodRetVal == ((HRESULT)0L)) || (bFailIfMissing == false), HRESULT=80070002 (e:\nts_sms_fre\SMS\common\inc\ccmxml.h,566) TSManager 5/11/2008 18:59:42 1500 (0x05DC)
No condition is associated with the step. TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding begin group instruction at 0 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
There are 7 first level steps or groups TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Restart in Windows PE TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
SuccessCodeList: 0 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
A condition is associated with the step found TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Found and operator. TSManager 5/11/2008 18:59:42 1500 (0x05DC)
There are 1 operands TSManager 5/11/2008 18:59:42 1500 (0x05DC)
**Processing expression node TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Found SMS_TaskSequence_VariableConditionExpression expression. TSManager 5/11/2008 18:59:42 1500 (0x05DC)
**In ProcessBuiltInCondition node: expression TSManager 5/11/2008 18:59:42 1500 (0x05DC)
There are 3 operands in the built in action TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Operand Operator=equals TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Operand Value=false TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Operand Variable=_SMSTSInWinPE TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Successfully added 3 condition parameters TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Start in dir: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Run in attribute: WinPEandFullOS TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Timeout: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
DefaultVarlist found TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: SMSRebootMessage TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: SMSRebootTimeout TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsboot.exe /target:WinPE TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 1 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: OSDdiskpartCompatibility TSManager 5/11/2008 18:59:42 1500 (0x05DC)
No variables found in default variable list TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: tsenv.exe "OSDdiskpartCompatibilityMode=TRUE" TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 2 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Partition Disk 0 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: Actions to partition and format the new machine TSManager 5/11/2008 18:59:42 1500 (0x05DC)
There are 2 operands in the built in action TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Operand Operator=notExists TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Operand Variable=_SMSTSClientCache TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Run in attribute: WinPE TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDDiskIndex TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDDiskType TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDDiskpartBiosCompatibilityMode TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDGPTBootDisk TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitionStyle TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitions0Bootable TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitions0FileSystem TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitions0QuickFormat TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitions0Size TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitions0SizeUnits TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitions0Type TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitions0VolumeLetterVariable TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDPartitions0VolumeName TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: osddiskpart.exe TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 3 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Apply Operating System TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: Actions to apply operating system TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDImageIndex TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: OSDApplyOS.exe /image:F010003E,%OSDImageIndex% TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 4 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Apply Windows Settings TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: Actions to apply windows settings TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDLocalAdminPassword TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDComputerName TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDProductKey TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDRandomAdminPassword TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDRegisteredOrgName TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDRegisteredUserName TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDServerLicenseConnectionLimit TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDTimeZone TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: osdwinsettings.exe /config TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 5 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Apply Network Settings TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: Actions to configure network settings TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDDomainName TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDDomainOUName TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDJoinPassword TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDJoinAccount TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDNetworkJoinType TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: osdnetsettings.exe configure TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 6 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Apply Device Drivers TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Operand Operator=notEquals TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Operand Value=FullMedia TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Operand Variable=_SMSTSMediaType TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDAutoApplyDriverBestMatch TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDAllowUnsignedDriver TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: osddriverclient.exe /auto /bestmatch:%OSDAutoApplyDriverBestMatch% /unsigned:%OSDAllowUnsignedDriver% TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 7 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Processed all elements TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding end group instruction at 8 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
The next instruction after group will be at 9 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing group node: Setup Operating System TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: Setup Operating System TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding begin group instruction at 9 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Setup windows and ConfigMgr TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: Actions to setup windows and ConfigMgr client TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: SMSClientInstallProperties TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: _SMSClientPackageID TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: OSDSetupWindows.exe TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 10 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing group node: Install Software TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Description: Actions to customize the new operating system TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding begin group instruction at 11 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
There are 8 first level steps or groups TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Quick Launch Buttons TSManager 5/11/2008 18:59:42 1500 (0x05DC)
ContinueOnError: true TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Disable: true TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Run in attribute: FullOS TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: _SMSSWDProgramName TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsswd.exe /pkg:F010005B /install /basevar: /continueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 12 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Authentec Fingerprint Driver TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsswd.exe /pkg:F010005C /install /basevar: /continueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 13 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Install "Office 2007-Office 2007 Unattended Install" TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsswd.exe /pkg:F0100023 /install /basevar: /continueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 14 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Office 2007 SP1 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsswd.exe /pkg:F0100037 /install /basevar: /continueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 15 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Adobe Reader 9.0 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsswd.exe /pkg:F0100043 /install /basevar: /continueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 16 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: Roxio TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsswd.exe /pkg:F0100064 /install /basevar: /continueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 17 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: FCS_Templates TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsswd.exe /pkg:F0100066 /install /basevar: /continueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 18 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Parsing step node: HP 3D DriveGuard TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Action command line: smsswd.exe /pkg:F010005D /install /basevar: /continueOnError: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding instruction at 19 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding end group instruction at 20 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
The next instruction after group will be at 21 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Adding end group instruction at 21 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
The next instruction after group will be at 22 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Reading Global variable list TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Got root node now getting global var list TSManager 5/11/2008 18:59:42 1500 (0x05DC)
GlobalVarlist found TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDEnableTCPIPFiltering TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Variable name: OSDAdapterCount TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Starting Task Sequence Engine . . . TSManager 5/11/2008 18:59:42 1500 (0x05DC)
**************************************************************************** TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Set a global environment variable _SMSTSNextInstructionPointer=0 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Set a global environment variable _SMSTSInstructionTableSize=22 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Set a global environment variable SMSTSRebootRequested= TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Set a global environment variable SMSTSRebootDelay= TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Set a global environment variable SMSTSRebootMessage= TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Set a global environment variable SMSTSRebootReason= TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Set a global environment variable SMSTSRetryRequested= TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Succeeded loading resource DLL 'X:\sms\bin\i386\1033\TSRES.DLL' TSManager 5/11/2008 18:59:42 1500 (0x05DC)
The task execution engine started execution TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Sending status message . . . TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Send a task execution status message SMS_TSExecution_TaskSequenceStartInfo TSManager 5/11/2008 18:59:42 1500 (0x05DC)
MP server MP-SCCM01.FERRANTI.BE and port 80. SSL=false. CRL=false. TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Site code: F01 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Client machine name: LPT00092 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Client Identity: GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Advertisement ID: F012004B TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Package ID: F010006B TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Sending StatusMessage TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Formatted header: TSManager 5/11/2008 18:59:42 1500 (0x05DC)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>26735beb-e335-4b9c-9e9e-15f1b58af205</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:42Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="2090"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 CCM_POST /ccm_system/request TSManager 5/11/2008 18:59:42 1500 (0x05DC)
The request has succeeded. 200 OK TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Send a task execution status message SMS_TSExecution_TaskSequenceNonClientStartInfo TSManager 5/11/2008 18:59:42 1500 (0x05DC)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>26735beb-e335-4b9c-9e9e-15f1b58af205</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:42Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="2108"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
Start executing an instruciton. Instruction name: Install Operating System. Instruction pointer: 0 TSManager 5/11/2008 18:59:42 1500 (0x05DC)
Set a global environment variable _SMSTSCurrentActionName=Install Operating System TSManager 5/11/2008 18:59:42 1500 (0x05DC)
The group (Install Operating System) has been successfully started TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Sending status message . . . TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Send a task execution status message SMS_TSExecution_GroupStartInfo TSManager 5/11/2008 18:59:43 1500 (0x05DC)
MP server MP-SCCM01.FERRANTI.BE and port 80. SSL=false. CRL=false. TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Site code: F01 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Client machine name: LPT00092 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Client Identity: GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Advertisement ID: F012004B TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Package ID: F010006B TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Sending StatusMessage TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Formatted header: TSManager 5/11/2008 18:59:43 1500 (0x05DC)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>26735beb-e335-4b9c-9e9e-15f1b58af205</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:43Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="2124"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 CCM_POST /ccm_system/request TSManager 5/11/2008 18:59:43 1500 (0x05DC)
The request has succeeded. 200 OK TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Updated security on object C:\_SMSTaskSequence. TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSNextInstructionPointer=1 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a TS execution environment variable _SMSTSNextInstructionPointer=1 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSInstructionStackString=0 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a TS execution environment variable _SMSTSInstructionStackString=0 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Save the current environment block TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Successfully save execution state and environment to local hard disk TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Start executing an instruciton. Instruction name: Restart in Windows PE. Instruction pointer: 1 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSCurrentActionName=Restart in Windows PE TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable SMSRebootMessage TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable SMSRebootTimeout TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSLogPath=X:\WINDOWS\TEMP\SMSTSLog TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Evaluating an AND expression TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Evaluating a variable condition expression TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Variable = _SMSTSInWinPE TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Value = false TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Operator = equals TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: equals TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: _SMSTSInWinPE TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: false TSManager 5/11/2008 18:59:43 1500 (0x05DC)
The variable condition expression is evaluated to be FALSE TSManager 5/11/2008 18:59:43 1500 (0x05DC)
The AND expression is evaluated to be FALSE TSManager 5/11/2008 18:59:43 1500 (0x05DC)
The action (Restart in Windows PE) has been skipped because the condition is evaluated to be false TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Send a task execution status message SMS_TSExecution_SkipActionConditionFalseInfo TSManager 5/11/2008 18:59:43 1500 (0x05DC)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>26735beb-e335-4b9c-9e9e-15f1b58af205</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:43Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="2194"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
Clear local default environment TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Execution of the instruction (Restart in Windows PE) has been skipped TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Start executing an instruciton. Instruction name: OSDdiskpartCompatibility. Instruction pointer: 2 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSCurrentActionName=OSDdiskpartCompatibility TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSNextInstructionPointer=2 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: tsenv.exe "OSDdiskpartCompatibilityMode=TRUE" TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Command line for extension .exe is "%1" %* TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set command line: tsenv.exe "OSDdiskpartCompatibilityMode=TRUE" TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Start executing the command line: tsenv.exe "OSDdiskpartCompatibilityMode=TRUE" TSManager 5/11/2008 18:59:43 1500 (0x05DC)
!--------------------------------------------------------------------------------------------! TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: WinPEandFullOS TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Executing command line: tsenv.exe "OSDdiskpartCompatibilityMode=TRUE" TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Finished with error code 0 TSEnv 5/11/2008 18:59:43 1556 (0x0614)
Process completed with exit code 0 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Successfully complete the action (OSDdiskpartCompatibility) with the exit win32 code 0 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Send a task execution status message SMS_TSExecution_ActionCompleteInfo TSManager 5/11/2008 18:59:43 1500 (0x05DC)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>26735beb-e335-4b9c-9e9e-15f1b58af205</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:43Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="2236"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
Set a global environment variable _SMSTSLastActionRetCode=0 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSLastActionSucceeded=true TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: %_SMSTSMDataPath%\Logs TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSNextInstructionPointer=3 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a TS execution environment variable _SMSTSNextInstructionPointer=3 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Start executing an instruciton. Instruction name: Partition Disk 0. Instruction pointer: 3 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a global environment variable _SMSTSCurrentActionName=Partition Disk 0 TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDDiskIndex TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDDiskType TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDDiskpartBiosCompatibilityMode TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDGPTBootDisk TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitionStyle TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitions0Bootable TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitions0FileSystem TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitions0QuickFormat TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitions0Size TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitions0SizeUnits TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitions0Type TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitions0VolumeLetterVariable TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set a local default variable OSDPartitions0VolumeName TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Variable = _SMSTSClientCache TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Value = TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Operator = notExists TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: notExists TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: _SMSTSClientCache TSManager 5/11/2008 18:59:43 1500 (0x05DC)
The variable condition expression is evaluated to be TRUE TSManager 5/11/2008 18:59:43 1500 (0x05DC)
The AND expression is evaluated to be TRUE TSManager 5/11/2008 18:59:43 1500 (0x05DC)
The condition for the action (Partition Disk 0) is evaluated to be true TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: osddiskpart.exe TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Set command line: osddiskpart.exe TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Start executing the command line: osddiskpart.exe TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Expand a string: WinPE TSManager 5/11/2008 18:59:43 1500 (0x05DC)
Executing command line: osddiskpart.exe TSManager 5/11/2008 18:59:43 1500 (0x05DC)
==============================[ OSDDiskPart.exe ]============================== OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Command line: "osddiskpart.exe" OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Succeeded loading resource DLL 'X:\sms\bin\i386\1033\TSRES.DLL' OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Reading partition size info for partition 0 OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Remaining size before partition: 120031511040 OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
size units: SIZE_PERCENT OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
100% size specified. OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Remaining size after partition 0: 0 OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Checking volume 'C:' for BitLocker OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Volume 'C:' is on disk '0l' OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
0, HRESULT=80004005 (e:\nts_sms_fre\sms\framework\tscore\encryptablevolume.cpp,367) OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Volume 'C:' is not an encryptable volume OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Checking volume 'D:' for BitLocker OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Checking volume 'X:' for BitLocker OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Command line for extension .exe is "%1" %* OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Set command line: "X:\WINDOWS\system32\diskpart.exe" /s "X:\WINDOWS\TEMP\osddiskpart.txt" OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Executing command line: "X:\WINDOWS\system32\diskpart.exe" /s "X:\WINDOWS\TEMP\osddiskpart.txt" OSDDiskPart 5/11/2008 18:59:43 1568 (0x0620)
Executing command line: X:\WINDOWS\system32\cmd.exe /k TSBootShell 5/11/2008 18:59:45 860 (0x035C)
The command completed successfully. TSBootShell 5/11/2008 18:59:45 860 (0x035C)
Successfully launched command shell. TSBootShell 5/11/2008 18:59:45 860 (0x035C)
Process completed with exit code 0 OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Formatting partitions OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Formatting drive C: with NTFS filesystem, method quick OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Creating instance of service loader OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Loading service OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Waiting for service to initialize OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Querying for software providers OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Found a VDS software provider OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Querying for IVdsSwProvider OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Querying for packs OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Found a VDS pack OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Querying for IVdsPack OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Querying for volumes OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Found a VDS volume OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Querying for IVdsVolumeMF OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Querying for access paths OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Found a volume with access path 'C:\' OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
Querying for IVdsVolume OSDDiskPart 5/11/2008 18:59:53 1568 (0x0620)
OSDDiskPart.exe completed successfully OSDDiskPart 5/11/2008 18:59:58 1568 (0x0620)
Process completed with exit code 0 TSManager 5/11/2008 18:59:58 1500 (0x05DC)
!--------------------------------------------------------------------------------------------! TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Successfully complete the action (Partition Disk 0) with the exit win32 code 0 TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Sending status message . . . TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Send a task execution status message SMS_TSExecution_ActionCompleteInfo TSManager 5/11/2008 18:59:58 1500 (0x05DC)
MP server MP-SCCM01.FERRANTI.BE and port 80. SSL=false. CRL=false. TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Site code: F01 TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Client machine name: LPT00092 TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Client Identity: GUID:718FF89E-B7A2-44EF-9816-F2D3AF209C7F TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Advertisement ID: F012004B TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Package ID: F010006B TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Sending StatusMessage TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Formatted header: TSManager 5/11/2008 18:59:58 1500 (0x05DC)
<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>26735beb-e335-4b9c-9e9e-15f1b58af205</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2008-11-05T17:59:58Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="4204"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
CLibSMSMessageWinHttpTransport::Send: URL: MP-SCCM01.FERRANTI.BE:80 CCM_POST /ccm_system/request TSManager 5/11/2008 18:59:58 1500 (0x05DC)
The request has succeeded. 200 OK TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Set a global environment variable _SMSTSLastActionRetCode=0 TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Set a global environment variable _SMSTSLastActionSucceeded=true TSManager 5/11/2008 18:59:58 1500 (0x05DC)
Expand a string: %_SMSTSMDataPath%\Logs TSManager 5/11/2008 18:59:58 1500 (0x05DC)
ok i've looked through your log file using Tracer32 and can't find anything odd apart from the disk being formatted after you've installed software (if that's how i'm reading it...)
so... can you please take note of exactly WHERE in the task sequence it fails (what section, enabled F8 in boot.wim and press it at the start of the task sequence to STOP any reboot when it fails)
i need you to tell me what is the error message (if any) you see on screen when it fails
I found this in the SCCM console
the source \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006E\ before releasing Released the resolved source \\MP-SCCM01.FERRANTI.BE\SMSPXEIMAGES$\SMSPKG\F010006EExiting ConfigureEx: 0x00000000 Process completed with exit code 0 Installing hookto 'C:\WINDOWS' Command line for extension .EXE is "%1" %* Set command line: "X:\sms\bin\i386\OSDSETUPHOOK.EXE" "/install:C:\WINDOWS" /version:6.0 Executing command line: "X:\sms\bin\i386\OSDSETUPHOOK.EXE" "/install:C:\WINDOWS" /version:6.0 InstallingOSD setup hook Setup hook install completed successfully Process completed with exit code 0 OfflineRegistry::Init("C:\WINDOWS") Loading offline registry hive "C:\WINDOWS\system32\config\software" into HKLM\OfflineRegistry1 Loading offline registry hive "C:\WINDOWS\system32\config\system" into HKLM\OfflineRegistry2 CurrentControlSet is mapped to ControlSet001 SMS Client is not installed Unloading offline SOFTWARE registry hive Unloading offline SYSTEM registry hive Exiting with code 0x00000000
After that it is exit code 2.
I will send you a new file by mail, I think this one is complete <_<
Update
I think I found the solution :rolleyes: .
I did the test en it works
I found the answer at this link http://forums.microsoft.com/TechNet/ShowPo...7&SiteID=17
Thanks helping me :lol:
Kinom
